robertuk22
Help Needed For Sharpening Pictures
Tue Dec 16, 2008 10:37 pm
Lately ive been having real problems trying to sharpen my pictures
People say use 150 at 0.3 on photoshop and i do but see no effects
i then submit my photos and they get rejected for being soft
and if i play about with it i make them to jaggered or oversharpened
can someone please help me out
Here is a llink to a selection of my photos i edited myself
i have all the originals if someone can really give me some help on how to edit my pictures from start to finish i just dont seem to get it and i love doing it?
Thank you
http://spotting.biagrouponline.co.uk...iewtopic.php?f=14&t=137&p=633#p633
Rob
Visit my Aviation blog featuring Larnaca Airport at http://robertnoel.blogspot.co.uk/
Stealthz
RE: Help Needed For Sharpening Pictures
Wed Dec 17, 2008 12:08 am
Rob,
I had a play with the only one of the photos in your link that, with all due respect, I felt worthy of an attempt.
I pretty much used Fergul McClean's process as linked on the Photo Upload page-
http://www.airliners.net/addphotos/PsProc.pdf
This will only give you a guide as I was working on your already processed image so results were not great.
http://www.pbase.com/chrisg/image/107158315/original.jpg
If you would like me to have a go at the original please contact me via my profile.
For the others, I don't understand your composition or cropping, chopping off small parts of an aircraft rarely works.. noses almost never.
Chris
dlednicer
Crew
Wed Dec 17, 2008 1:50 am
Soft doesn't necessarily mean "not sharpened enough". It can also mean that you have low contrast edges or areas of weak color. I use the burn tool to work on these areas. Set it to at 5 or 10% and work the areas that fit this criteria. I almost always burn canopies - I set the burn tool on Shadows and pass the tool over the canopy a bit to eliminate glare, which could be considered softness.
On this shot I lassoed the tail and burned the blue areas and I burned the plexiglass on the nose:
Photo © David Lednicer
On this one I burned the left wing, particularly near the tip, including the insignia:
On this one, I burned the "soft" areas on the top of the fuselage:
On this one, I burned the canopy and the parts of the top of the glider that are visible:
Regarding sharpening, here are some helpful threads:
http://www.airliners.net/aviation-fo...tion_photography/read.main/246391/
http://www.airliners.net/aviation-fo...tion_photography/read.main/219246/
robertuk22
Wed Dec 17, 2008 10:36 am
Thank you for your reply's
Im gonna take all your helpful info on board and see how i get on
Thanks again
Rob
Trackcharlie
Sat Dec 20, 2008 10:35 am
Just a thought, but you mentioned that when you used 150% 0.3 you saw no effect. Perhaps you need to downsize the jpeg first as the sharpening settings will have a greater effect then.
Users browsing this forum: Baidu [Spider] and 1 guest
GZIP: Off
