jollyroger77
Do You Know The Owner Of The Planes?
Fri Jan 30, 2009 3:03 pm
I have some shots taken from the ground. I want to know the owner of the planes (Airline). Anybody knows that, please tell me…
http://i39.tinypic.com/2r6i7f7.jpg
Saeed
INNflight
RE: Do You Know The Owner Of The Planes?
Fri Jan 30, 2009 3:18 pm
Hello Saeed,
Number one is Qatar Airways, an A340-600.
Number three is Qatar Airways too, but an A330, and in a special Doha colour scheme,
and number four is Singapore Airlines, a B747.
Jet Visuals
TupolevTu154
Fri Jan 30, 2009 3:32 pm
I'm inclined to say number 5 is an Edelweiss A330 and number 2 is China Airlines 744?
I assume these were taken over Iran somewhere?
Tom
jollyroger77
Fri Jan 30, 2009 4:44 pm
Quoting TupolevTu154 (Reply 2):
They are taken in west of Iran somwhere near Kermanshah
JakTrax
Fri Jan 30, 2009 5:07 pm
No. 5 perhaps a China Eastern A330-200?
No. 6 looks to me like a 747 classic (can't see any winglets) but I can't tell whose it could be. Iran Air new scheme perhaps? One no-one's photographed yet with blue engines? Or Aerolineas Argentinas?
Karl
jollyroger77
Fri Jan 30, 2009 6:12 pm
Classic Iran air with blue engines?
[Edited 2009-01-30 10:21:18]
JakTrax
Fri Jan 30, 2009 6:43 pm
Quoting Jollyroger77 (Reply 5):
The IR Cargo A300 in the revised scheme has blue eingines - since aircraft in Iran are rarely photographed could it possibly be a 747 classic in the new livery? Just a thought. Otherwise I'm inclined to say Aerolineas Argentinas.
Karl
Plainplane
Fri Jan 30, 2009 7:26 pm
I think number 6 is Atlas Air. Some of their 747-200s are white with blue engines and incredibly dirty.
oly720man
Fri Jan 30, 2009 7:32 pm
6 may be
Photo © Weimeng
JakTrax
Sat Jan 31, 2009 3:26 pm
I thought about Atlas but figured the the blue band around the rear fuselage would be visible if it was one of theirs. Didn't know thay had that hybrid thing! My money's on that!
Still think 5 is more likely China Eastern than Edelweiss.
Karl
unattendedbag
Sat Jan 31, 2009 8:08 pm
number 2 looks like Cathay.
Slower traffic, keep right
TupolevTu154
Sat Jan 31, 2009 11:03 pm
Quoting JakTrax (Reply 9):
I beg to differ
Unfortunately the database is up to it's old tricks so can't provide pictures, but China Eastern's livery has a red cheat line that would show as a band round the rear fuselage, similar to the SQ shot. The red doesn't cover nearly enough of the nose either. Edelweiss is painted to the exact same extent as in the photograph in the original post.
Feel free to prove me wrong as I am totally unfamiliar with Edelweiss' routes but I'm personally quite confident that's what it is
Edit: Here's a couple of pictures to hopefully clear things up a little:
Photo © Denis Roschlau - AirTeamImages
Photo © Alejandro Pérez
[Edited 2009-01-31 15:16:29]
Phoenix9
Sun Feb 01, 2009 1:57 am
Paging 2H4...2H4 to av. photography.
Any chance #2 could be BA?
[Edited 2009-01-31 17:58:34]
Life only makes sense when you look at it backwards.
unattendedbag
Sun Feb 01, 2009 4:33 am
Quoting Phoenix9 (Reply 12):
British Airways? don't they have blue engines and blue underbellies?
unattendedbag
Sun Feb 01, 2009 4:43 am
Quoting JakTrax (Reply 4):
Quoting JakTrax (Reply 6):
Quoting Plainplane (Reply 7):
Quoting Oly720man (Reply 8):
6 may be
I don't see the regestration on the underside of the wing, so I am inclined to think it is U.S. regestered.
Dazed767
Sun Feb 01, 2009 5:07 am
#2 KLM 744 maybe? You can make out some reg under the wing, KLM's would be in the same spot.
INNflight
Sun Feb 01, 2009 6:11 am
Quoting TupolevTu154 (Reply 11):
I think you're quite correct, would match the Maledives flight I guess!
Jet Visuals
unattendedbag
Sun Feb 01, 2009 6:16 am
Quoting UnattendedBag (Reply 10):
I stand corrected, number 2 is either China Airlines or China Airlines Cargo.
Good eye Tom!
EMA747
Mon Feb 02, 2009 2:14 pm
Number 6 could be Air Atlanta Icelandic? They have the classic 747.
Failing doesn’t make you a failure. Giving up and refusing to try again does!
JakTrax
Mon Feb 02, 2009 4:49 pm
Quoting EMA747 (Reply 18):
As far as I know not in that scheme any more. I agree it's 99.9% got to be the Atlas hybrid.
Karl
simfanatic
Wed Feb 04, 2009 11:04 am
Quoting JakTrax (Reply 19):
Same with me. Probably the MAA routing...
Don't be a fool, think about what you're writing!
jollyroger77
Thu Feb 05, 2009 12:46 pm
Thanks for the helps.
I will post another shots for recognitions. Because I'm not so familiar with civil planes.
I have on question. To capturing full screen shots with high quality of this birds which equipments is required?
oly720man
Thu Feb 05, 2009 1:52 pm
Quoting Jollyroger77 (Reply 21):
For getting towards full frame, a telescope with a focal length of perhaps 1200mm, for example
http://www.flugzeugbilder.de/show.php?id=722013
There are a few groups online with photos, but I can't find any links at the moment.
For photographic lenses you need at least a 500mm lens with a 2x converter, but then you'll be pushing the exposure limit and will probably need 400-800ISO to get a decent shutter speed. That is unless you've got a very expensive 500mm lens.
jollyroger77
Thu Feb 12, 2009 3:22 pm
Although I think it is impossible, But I want to know: Is it possible to take images throgh telescope with compact images like S5IS?
dazbo5
Thu Feb 12, 2009 5:06 pm
Quoting Jollyroger77 (Reply 23):
Yes, very possible. Do a search for 'digiscoping'. A lot of bird watchers (the feathered variety!) use spotting scopes with compact cameras attached to them with a converter / mounting bracket. You can get focal lengths up to 3,000 - 4,000 mm + with the right system and a big enough budget!
Darren
Users browsing this forum: PeterB and 16 guests
