moderators
Pre-Screening Thread Number 7
Wed Feb 04, 2009 7:29 pm
Number 6 took already again quite some time to load, so here is number 7.
Once again the link to number 6, if you need to check there:
http://www.airliners.net/aviation-fo...on_photography/read.main/323879/1/
Thanks and happy uploading.
Please use moderators@airliners.net to contact us.
flipdewaf
RE: Pre-Screening Thread Number 7
Wed Feb 04, 2009 9:54 pm
1.
http://img207.imageshack.us/img207/3791/dsc1932ps3.jpg
2.
http://img238.imageshack.us/img238/5568/dsc1909rv7.jpg
3.
http://img443.imageshack.us/img443/6685/dsc3822mb6.jpg
4.
http://img443.imageshack.us/img443/2992/dsc3686rf1.jpg
I know the first two are probably not salvageable but I toiled in the extreme cold for them.
Fred
jetplaner
Thu Feb 05, 2009 12:28 am
Any luck on these?
http://i468.photobucket.com/albums/rr46/mr_jon_95/P1040192.jpg
http://i468.photobucket.com/albums/rr46/mr_jon_95/PC280066.jpg
http://i468.photobucket.com/albums/rr46/mr_jon_95/IMG_1577_2.jpg
-Jetplaner
bubbles
Screener
Thu Feb 05, 2009 1:48 am
Quoting Jetplaner (Reply 2):
Any luck on these?
Sorry, no. Many issues in your photos, such as, grainy, soft, level, dirty.
_Hongyin_
dlowwa
Thu Feb 05, 2009 3:01 am
Quoting Flipdewaf (Reply 1):
Actually, they're not bad. #1 is over-sharpened, and #2 is a bit grainy and a touch soft, but both only need a bit of work. I couldn't promise they'd get in, but it might be worth a shot after a bit of work.
#3 is also slightly over-sharpened, and needs a lot more contrast. #4 is just about right, but also suffers from a touch of over-sharpening (see the leading/trailing edges of the wing).
Overall, I think all four would stand a chance if you put a little time into fixing the minor issues they each have.
Any luck on these?
As Hongyin said, not a chance on the first two, the quality is way too low. The third one is better, but the contrast is too harsh, and you can see all the dirt spots on the window, so also no.
Dana
Plainplane
Thu Feb 05, 2009 4:59 am
This was taken on a cloudy, gloomy day but I think it has potential, what do you think?
http://img101.imageshack.us/img101/261/n706jbla4.jpg
Also what should I do to eliminate the noise here?
http://img516.imageshack.us/img516/4701/spmuo8.jpg
calisam
Thu Feb 05, 2009 6:22 am
How are these? Thanks
http://www.3d-realm.com/files/0117_NW.jpg
http://www.3d-realm.com/files/IMG_8523.jpg
Jetfreak
Thu Feb 05, 2009 8:26 am
Quoting Plainplane (Reply 5):
1: too dark (i know it's because of the weather, but if you lighten it just a bit, it's a perfect shot Smile)
2: I don't think it's that noisy, but unfortunately very blurry.
Quoting CaliSam (Reply 6):
1: not enough contrast (the "nwa" title isn't black enough, but you can easily correct this in Photoshop)
2: like number one; a bit to bright
btw: I love both shots, so please upload them  Smile
Regards;
Bernhard
bubbles
Screener
Thu Feb 05, 2009 3:10 pm
#1: dark, contrast
#2: grainy dark, contrast, center, and maybe border
I think ok to both. The second one's angle looks a little odd, maybe tiny CW rotation will help, but I am not sure.
_Hongyin_
Plainplane
Thu Feb 05, 2009 6:00 pm
Quoting Bubbles (Reply 8):
I don't think #2 is fixable. I will try to brighten #1. Would that fix the contrast issue also or is there something else I would have to do?
Plainplane
Thu Feb 05, 2009 9:24 pm
Updated:
I maxed the saturation and slightly increased the exposure. Am I going in the right direction with it?
http://img21.imageshack.us/img21/7761/n706jb2ao7.jpg
spurusho
Fri Feb 06, 2009 4:34 pm
Any chance of this making it through?
Click to enlarge.
http://img27.imageshack.us/img27/5536/qantas747vhojety9.jpg
othic
Fri Feb 06, 2009 5:20 pm
Quoting Spurusho (Reply 11):
the A/C is too low in frame
A boy learn's much more at the airport then he do at school
spurusho
Fri Feb 06, 2009 6:22 pm
Quoting Othic (Reply 12):
How about now? Also changed the PP a little.
Click to enlarge
http://img21.imageshack.us/img21/3032/qantas747vhojerecropvd1.jpg
airkas1
Head Screener
Fri Feb 06, 2009 7:26 pm
Quoting Spurusho (Reply 13):
Why make it so big? 1024 is enough. Personal choice however..
IMHO the hor.stab. is too closely cropped.
spurusho
Sat Feb 07, 2009 2:11 am
Quoting AirKas1 (Reply 14):
Thanks for the tip on the hor.stab., I shall recrop it.
Larger it is, easier to edit on my 24" LCD (1920x1200). At 1024x768 some of the details are too small to see/edit clearly. Actually 1600x1063 or thereabouts would be ideal for me.
On the flip side, these larger images lose this advantage on my notebook's smaller LCD which has a max res of 1280x800  Sad
Plainplane
Sat Feb 07, 2009 2:26 am
I submitted my modified JetBlue into the queue, if somebody has last-minute advice for that one I will pull it and work on it some more.
I am also wondering if this might also have a chance if I edit it, but I doubt it. (It was taken on a day with even worse weather than the B6 pic):
http://img17.imageshack.us/img17/5387/img0655eo9.jpg
spurusho
Sat Feb 07, 2009 2:47 am
Smaller images.
Opinions welcome.
Click to enlarge.
http://img10.imageshack.us/img10/997/imgp4105acr2wb1200qa5.jpg
http://img7.imageshack.us/img7/1047/imgp4156acr2wb1200by3.jpg
[Edited 2009-02-06 18:48:00]
conoramoia
Sat Feb 07, 2009 3:52 pm
conoramoia
Sat Feb 07, 2009 9:20 pm
conoramoia
Sat Feb 07, 2009 10:20 pm
thanks for veiwing in advance
[Edited 2009-02-07 14:31:28]
airkas1
Head Screener
Sun Feb 08, 2009 8:39 am
Quoting Plainplane (Reply 16):
It's too dark and you cut off the tip of the tail.
Quoting Spurusho (Reply 17):
Nice shots, they look fine to me.
Quoting Conoramoia (Reply 19):
#1 looks unlevel (see verticals in the background)
#2 looks ok, besides the fact that it might get motive
conoramoia
Sun Feb 08, 2009 12:02 pm
I tried to re-level it but the runway is unlevel aswell but have a look and see what you think!!thanks ...conor.
http://www.airliners.net/addphotos/b...4220.9076imgaar4724editedited1.jpg
ruudb
Sun Feb 08, 2009 1:50 pm
Quoting Conoramoia (Reply 18):
any chance?
No, I think it doesn't have a chance, the quality isn't there and the crop looks awkward.
spurusho
Sun Feb 08, 2009 3:18 pm
Since I am new here and I don't have any photos in the databases (first 2 got rejected) I need to be careful what I upload, so I am trying to get an idea here.
Would any of these stand a better chance of acceptance? Any comments are most welcome. Thanks for your time and help  Smile
BTW, the green 'shadow' on the underside of the fuselage is the reflection of the sea. These were shot from the coastline. Weather was lousy yesterday, to add to the misery (all white cloud cover...sigh), it was hot too. I am finding it very difficult to get the WB right on these :/
Click to enlarge
#1
http://img10.imageshack.us/img10/491/imgp4432acr2wbfeb7pp150ni5.jpg
#2
http://img25.imageshack.us/img25/5681/lufthansa747dabvuku6.jpg
#3
http://img7.imageshack.us/img7/107/imgp4418acr2wbusmee8.jpg
#4
http://img7.imageshack.us/img7/7977/imgp4440acr2wbcrrq3.jpg
#5
http://img10.imageshack.us/img10/7991/imgp4675acr2wbfeb71500ah2.jpg
#6
http://img10.imageshack.us/img10/1816/imgp4587acr2wbfeb71500ri7.jpg
spurusho
Sun Feb 08, 2009 3:19 pm
Quoting AirKas1 (Reply 21):
Thank you for the kind words, AirKas1. You input is greatly appreciated.
Plainplane
Sun Feb 08, 2009 4:24 pm
Evil weather, and yes the shot cut the tail off. That one was just resized to 1024.
When I take more shots I will post for advice.
arjenp
Sun Feb 08, 2009 5:46 pm
One for the pre-screening
http://img338.imageshack.us/img338/4484/img1755neteof4.jpg
dazbo5
Sun Feb 08, 2009 5:53 pm
Quoting Arjenp (Reply 27):
It'll get a motive rejection I'm afraid because of the loader blocking the front landing gear. I'm not sure it's level either (looks like it could do wih a bit of clockwise rotation).
Darren
deltabravo90
Sun Feb 08, 2009 8:49 pm
What about these two?
http://i6.photobucket.com/albums/y249/mario_123/Aircraft/N497CA.jpg
http://i6.photobucket.com/albums/y249/mario_123/Aircraft/N8925E.jpg
DeltaBravo90
Nozilla
Sun Feb 08, 2009 10:37 pm
Can I have your opinion about this picture.
http://img7.myimg.de/airfrance66ff2.jpg
NicolasRubio
Mon Feb 09, 2009 12:59 am
Is this one too dark?
http://www.airliners.net/addphotos/big/ready/h1234134939.2571img_2910_edit.jpg
Thanks guys!
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
withak
Mon Feb 09, 2009 1:17 am
Quoting DeltaBravo90 (Reply 29):
I'll have to pass on the first one but the second would certainly be rejected for dark at least.
Quoting NicolasRubio (Reply 31):
I love the shot but I think your right in saying it's a bit dark.
I've been having a lot of problems with colour rejections recently so I thought I better check this one. Should I leave it in the queue?
http://www.airliners.net/addphotos/big/ready/l1234141143.533220090206_9mxxb_2_b1.jpg
Kris
NicolasRubio
Mon Feb 09, 2009 3:56 pm
Fixed it... what about this version?
http://www.airliners.net/addphotos/big/ready/z1234194537.446lv-mfx_tail.jpg
stevemchey
Mon Feb 09, 2009 6:10 pm
Hello everybody,
I am new to the photographer section of Airliners and have already submitted images that were rejected. Now I just found this thread and hope to gain some insights before submitting any more.
Here is one I took last weekend. The interesting part about this one was that it was just pulling up because it was instructed to do a go-around due to traffic on the runway.
http://farm1.static.flickr.com/236/3267310480_37dd00d90a_o.jpg
othic
Mon Feb 09, 2009 6:41 pm
Is there any chance for this one
http://img26.imageshack.us/img26/5906/hbjzklv0.jpg
/othic
timdegroot
Mon Feb 09, 2009 11:17 pm
Quoting Othic (Reply 35):
Needs ccw rotation
Quoting Stevemchey (Reply 34):
Looks blurry and oversharpened to compensate. Also lacks contrast and is grainy (shadow highlight tool used?) and could do with some centering
Alderman Exit
calisam
Tue Feb 10, 2009 12:33 am
Thoughts on these 3? Thanks!
http://www.3d-realm.com/files/IMG1.jpg
http://www.3d-realm.com/files/IMG2.jpg
http://www.3d-realm.com/files/IMG3.jpg
cpd
Tue Feb 10, 2009 2:04 am
Distance/motive for the AA I believe.
AviatorG
Tue Feb 10, 2009 2:27 am
VS744 @ TLPL. Any chance? Thanks in advance. http://www.airliners.net/addphotos/big/ready/a1234230586.6987gvrom_tlpl_250109_editedlowlight12.jpg
G  cool
bubbles
Screener
Tue Feb 10, 2009 3:39 am
Quoting CaliSam (Reply 37):
#1: Blurry, oversharpened
#2: Looks ok.
#3: Grainy, distant, soft
Quoting AviatorG (Reply 39):
Grainy, oversharpened, contrast
_Hongyin_
spurusho
Tue Feb 10, 2009 1:28 pm
I have finalized two for submission. Do either stand a chance?
Both taken under cloudy conditions. Resized to 1500px and post-processed.
Is the WB off in these photos?
http://img18.imageshack.us/img18/944/lufthansaa340dajgycorretc8.jpg
http://img18.imageshack.us/img18/7597/ana767ja608av2tj4.jpg
AviatorG
Tue Feb 10, 2009 2:58 pm
Thanks Hongyin! It originally got rejected for contrast only.  Sad
How's this one? http://www.airliners.net/addphotos/big/ready/e1234277502.1196yv155t_tapa090209_edited.jpgcool
PRM
Tue Feb 10, 2009 3:39 pm
Quoting AviatorG (Reply 42):
How's this one?
I'd say it's too dark (too much contrast?), and could take some more USM
Paul
timdegroot
Tue Feb 10, 2009 5:19 pm
Quoting Spurusho (Reply 41):
Quality is good. Did you by any chance use the shadown/highlight tool or fiddle with the contrast? The bellies look a bit washed out
Alderman Exit
spurusho
Tue Feb 10, 2009 6:02 pm
Quoting TimdeGroot (Reply 44):
Thanks for the input Tim; very much appreciated.
I did adjust the levels in Photoshop CS3 to increase the contrast, but have not used any highlight/shadow tool. There is also some reflection from the sea (green waters) on to the bellies, since these were taken from the beach.
Should I increase the contrast some more to darken the bellies before I submit?
Thank you once again.
Neophyte
Tue Feb 10, 2009 6:30 pm
Hey guys,
I found a picture from DL accident in HAM (1995) it´s just a paperscan. I can´t find the negatives.
Should I try an upload?
Timo
NicolasRubio
Tue Feb 10, 2009 7:14 pm
Quoting NicolasRubio (Reply 33):
Nobody?
timdegroot
Tue Feb 10, 2009 7:30 pm
Quoting Spurusho (Reply 45):
That would explain it
Quoting Neophyte (Reply 46):
Yes, looks like a rare shot
Alderman Exit
conoramoia
Tue Feb 10, 2009 10:08 pm
