mnazarinia
Photo Acceptance - Help With Contrast And Overexposed Rejection
Wed Feb 25, 2009 8:51 am
Hi all,
I just got this one rejected for being overexposed and contrast. I guess this was my third trail ans yet got rejected for the same reason. Can I ask someone to help me what I need to do to fix the problem please?
http://www.airliners.net/procphotos/..._z1235389379.6248img_4389_ver1.jpg
Mehdi.
Chukcha
Wed Feb 25, 2009 8:55 am
Mehdi, the link doesn't seem to work - shows "Default Image".
mnazarinia
Wed Feb 25, 2009 9:25 am
Chukcha
Wed Feb 25, 2009 9:50 am
I don't see where it is overexposed, but the contrast is definitely low. The red on the tail is a bit washed out, no pure whites or black. The histogram shows that clearly at the both ends. Levels adjustment might help.
aussie18
Crew
Wed Feb 25, 2009 10:15 am
Id give the contrast a boost on it,exposure looks okay to me.
Chukcha
Wed Feb 25, 2009 10:25 am
It is actually very easy to check whether the shot is overexposed, using the Shadow/Highlight function. Just move the Shadow slider to zero, and the Highlight slider over to 100. If there are overexposed areas, they will remain unchanged white. But even the brightest areas with any data in them will go dark.
oly720man
Wed Feb 25, 2009 10:49 am
Setting the black and white point gives this. Seems you have a strong colour cast, or was the weather like that on the day?
http://i4.photobucket.com/albums/y120/oly720man/vh-ogb.jpg
mnazarinia
Wed Feb 25, 2009 10:57 am
Quoting Oly720man (Reply 6):
No the weather was like that. It was all smoky due to the recent bush fire!!
I will give it another go, thanks all.
Mehdi.
codeshare
RE: Photo Acceptance - Help With Contrast And Overexposed Rejection
Wed Feb 25, 2009 4:25 pm
I 've had a few contrasts recenlty myself actually.
Contrast is a bit too low. The whites seem gray. You can also try moving the middle pointer (or what's it called) in the Levels to have a darker feel. At the same time it should fix the exposure. Other than that great photo !
Ks/codeshare
How much A is there is Airliners Net ? 0 or nothing ?
timdegroot
Wed Feb 25, 2009 4:58 pm
The vast majority of contrast rejections are for contrast being too low.
I think this is because people tend to leave contrast as it is and not work the levels which is really necessary.
Contrast rejections for high contrast dont happen as often
Tim
Alderman Exit
mnazarinia
Wed Feb 25, 2009 9:50 pm
Thanks all.
Tim, I really touched the levels and even curves. I guess the problem is with my original image. That day the sky was so smoky due to our recent bush fire and I guess because of the white body the contrast doesn't show as white as it should be.
I have attached the original untouched but just reduced size photo here as well:
Big version: Width: 1024 Height: 683 File size: 288kb
timdegroot
Wed Feb 25, 2009 9:52 pm
yes hazy weather can definitely worsen the problem, those shots can often need a bigger kick
Tim
Alderman Exit
mnazarinia
Wed Feb 25, 2009 10:39 pm
Thanks Tim. I will try again and will post it here soon before uploading it.
Cheers, Mehdi.
ptrjong
Wed Feb 25, 2009 11:04 pm
Quoting TimdeGroot (Reply 11):
I know that it's often frowned upon, but Autocolor in PS will usually give a kick in the right direction. It will often exaggerate and even blow out highlights, but you can reduce the effects with the Fade function.
Peter Smile
Chukcha
Wed Feb 25, 2009 11:25 pm
Quoting Mnazarinia (Reply 10):
If you have a look at the histogram, you will see that on the both right and left hand side there is a flat area meaning no pixels for higher intensity whites and blacks. That accounts for the low contrast, and that's what every picture levels should really be checked for. If you move the sliders just past the flat areas, the image will already look better. That of course won't guarantee a perfect result, some further contrast adjustment might be needed. Then, as mentioned above, you could adjust brightness with the middle slider.
[Edited 2009-02-25 15:37:21]
Chukcha
Wed Feb 25, 2009 11:35 pm
Quoting Ptrjong (Reply 13):
Sometimes it will, and sometimes it will not, it is a bit of a 'hit' and 'miss'. But when it does, the effect may be a bit too much. In that case it pays to go to 'Edit' - 'Fade" and to play with the Auto Color intensity.
ptrjong
Wed Feb 25, 2009 11:47 pm
Quoting Chukcha (Reply 15):
Didn't I say that?  Wink
Anyway it doesn't replace looking at the levels and curve, I just often use this as an easy step in the right direction.
Peter Smile
Chukcha
Thu Feb 26, 2009 1:00 am
Sorry, Peter, I'm doing lots of things here on the run, trying to multitask, which I definitely have the wrong gender for  Smile . Only caught the first half of your post  sorry  . Anyway, some profound insights are worth repeating, aren't they :D ?
[Edited 2009-02-25 17:04:51]
dendrobatid
Thu Feb 26, 2009 8:00 am
This trick works for setting the black point.
Open levels (Ctrl+L) I have not checked but I would expect a gap on the left side to be indicated by the weak black.
Press and hold down Alt as you move the left slider in. The image will go blank, white. Keep moving the slider in until the merest trace of anything shows and that will set the black point.
The same happens at the white point though highlight spots almost always immediately show when you press Alt and move the right slider.
I found that simply looking at the histogram gave virtually identical results to this method, but that comes with a lot of experience, this way is a shortcut to it - dead simple
Mick Bajcar
ptrjong
Thu Feb 26, 2009 11:05 am
Quoting Chukcha (Reply 17):
No problem at all Andrei, I think it was maybe even you who taught me the Fade tool.
Peter Smile
mnazarinia
Mon Mar 02, 2009 6:42 am
Thanks all. It is now accepted!
Click Here to view the photo
[Edited 2009-03-01 22:44:31]
[Edited 2009-03-01 22:46:02]
