alasdair1982
Photo Acceptance - Pre Screening (Alasdair1982)
Wed Feb 25, 2009 3:30 pm
Is that correct for the new individual thread format?
Would like peoples opinion on this one which I might attempt an upload of. Note, that's a compressed version on photobucket, not the full size version
http://img.photobucket.com/albums/v31/bob_van_belgium/G-CIVC.jpg
Looks straight to me, red looks red, blue looks blue etc etc. Sharp enough?
acontador
Wed Feb 25, 2009 3:41 pm
Hi,
Suggest you don't post reduced size versions, as it will be very difficult to say anything regarding the quality, in particular sharpness.
AFAIK, photobucket allows bigger size images?
Andres
Just sit back, relax and have a glass of Merlot...enjoy your life!
wilco737
Wed Feb 25, 2009 3:49 pm
Quoting Alasdair1982 (Thread starter):
Perfect  thumbsup
As Andres said, use the full version not a compressed one. You can upload your image in your profile as well, then everybody is able to see the full version of the picture.
wilco737
airkas1
Crew
Wed Feb 25, 2009 4:19 pm
Quoting Acontador (Reply 1):
Yes.
Your shot is not centered btw, it's low in the frame.
Airliners.net Crew - Head Photo Screener
codeshare
Wed Feb 25, 2009 4:22 pm
..and looks a bit overexposed and contrast is too high. Shot around noon?
KS/codeshare
How much A is there is Airliners Net ? 0 or nothing ?
ANITIX87
Wed Feb 25, 2009 4:58 pm
As Codeshare said, it is a bit overexposed with a little too much contrast. Also, you'll probably get a distance rejection even though the aircraft fills the frame. There is a lot of stuff in the foreground.
Try a 3:2 crop instead of this weird one you're using now, which is between 3:2 and 4:3.
TIS
alasdair1982
Wed Feb 25, 2009 5:27 pm
Quoting Codeshare (Reply 4):
Shot around noon?
Just after 1pm local time
Thanks for the tips so far, dunno how much better this attempt is?
Big version: Width: 1551 Height: 1000 File size: 612kb
ANITIX87
Wed Feb 25, 2009 5:39 pm
Better, but you have a lot of heat haze, and some quality issues. It's not too big, funnily enough. I would say size it around 1024 pixels across with a 3:2 aspect ratio.
TIS
codeshare
Wed Feb 25, 2009 6:14 pm
Just a small tip, shooting around noon produces photos that are lit overall from the top, and as in your photo, the belly is darker. But sometimes the interesting stuff comes at bad times dont they?
KS/codeshare
alasdair1982
Wed Feb 25, 2009 8:39 pm
Quoting Codeshare (Reply 8):
Can understand, but if that is how screeners see it, it would be rather unfair if pictures taken only at certain times of the day when the belly and undercarriage is be lit up, are preferred?
I don't follow this 3:2 aspect ratio thing
alasdair1982
Wed Feb 25, 2009 8:48 pm
Quoting ANITIX87 (Reply 7):
is this more what you are suggesting?
Big version: Width: 1024 Height: 631 File size: 645kb
timdegroot
Wed Feb 25, 2009 8:49 pm
Quoting Alasdair1982 (Reply 9):
We dont have a "bad light" rejection but those photos can come with more problems than those shot in better light
Tim
Alderman Exit
ANITIX87
Wed Feb 25, 2009 9:52 pm
Quoting Alasdair1982 (Reply 10):
Yes and no. The dimension across is correct (1024 pixels) but now the image is too narrow. The 3:2 thing means that the ratio of width to height must be 1.5. Therefore, since your image is 1024 pixels across, it should be 683 pixels high. As of right now it's a tiny bit too narrow since it is 631 pixels high. In the application you use to crop, there should be an aspect ratio option, which you can select to hold it constant while you choose your crop.
Also, now that you've shrunk it, the quality has improved a little bit but the image is far too sharp. If you want to send me the original I can see what I can do with it, if you'd like.
TIS
viv
Wed Feb 25, 2009 10:15 pm
Overexposed, with ugly foreground.
alasdair1982
Wed Feb 25, 2009 10:33 pm
Quoting ANITIX87 (Reply 12):
Third and final attempt at 1024 x 683
Big version: Width: 1024 Height: 683 File size: 652kb
A couple of others to ask your opinions of at the same resolution
Big version: Width: 1024 Height: 683 File size: 445kb
Big version: Width: 1024 Height: 683 File size: 463kb
G-CIVP
Wed Feb 25, 2009 11:32 pm
G-CIVC is over-exposed. Both the Koreans are soft when enlarged.
alasdair1982
RE: Photo Acceptance - Pre Screening (Alasdair1982)
Thu Feb 26, 2009 6:53 pm
Quoting G-CIVP (Reply 15):
Did a bit of sharpening to both 777's and uploaded them to my profile, deleting the two previous versions. But I just get the 'default' image' thumbnail
alasdair1982
Fri Feb 27, 2009 3:49 pm
Here is the Korean 777 with a bit of sharpening
Big version: Width: 1024 Height: 683 File size: 753kb
Would like opinions on this shot of the Blue Angels
Big version: Width: 1024 Height: 683 File size: 436kb
Thanks again
koryo
Sat Feb 28, 2009 6:24 am
The Korean Air's right wing looks quite hazy and there is also haze in the quite a few other places.
As for the Blue Angels, there is something funky with the color of the sky.
Hope this helped,
Koryo
This forum is as good as you make it. Never post a message in anger. Take the high road and others will follow.
alasdair1982
Sat Feb 28, 2009 3:01 pm
Quoting Koryo (Reply 18):
is that meant to be a good or bad thing?  Smile
koryo
Sat Feb 28, 2009 6:01 pm
To be honest i don't know if it will affect you in a positive or negative way but the sky under the Blue Angels definitely has more yellow hue than the sky above them.
alasdair1982
Sun Mar 01, 2009 1:46 am
Just noticed it myself, I really don't understand how that happened
koryo
Sun Mar 01, 2009 2:25 am
Possibly there was some low lying haze the day you took the picture causing it be be yellowish only on the bottom?
