Sketty222
Photo Acceptance - Pre Screening (Sketty222)
Thu Feb 26, 2009 10:23 pm
Hi guys
Looking for some advice on this pic Is it good enough to try and upload it or if not what can I do to improve it
Thanks in advance
[Edited 2009-02-26 14:47:10]
NIKV69
RE: Photo Acceptance - Pre Screening (Sketty222)
Fri Feb 27, 2009 6:25 am
Am I the only one having trouble opening the full size version?
Hard to tell with the version in the thread.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
Silver1SWA
Crew
Fri Feb 27, 2009 7:42 am
You're not the only one, Nick. I can't view it either.
koryo
Fri Feb 27, 2009 7:44 am
the photo is extremely noisy try using Neat Image
This forum is as good as you make it. Never post a message in anger. Take the high road and others will follow.
dlowwa
Fri Feb 27, 2009 8:08 am
Quoting Koryo (Reply 3):
No, actually it's not. While there is a little grain in the darker areas, I'd hardly say it was extreme.
It is somewhat overexposed and a has had a little too much sharpening applied (see around edges of tail/wings, reg., front gear doors, etc...). Not too bad but it is noticeable. I'd also suggest a 2x3 crop rather than 3x4, and then re-size to 1024 to hide any more imperfections.
Dana
timdegroot
Fri Feb 27, 2009 8:53 am
Definitely too grainy and a little oversharpened too
Tim
Alderman Exit
flyingzacko
Fri Feb 27, 2009 10:22 am
What is it with you and NeatImage, if you had used it before you wouldn't give such random advice. Neat Image is only to be used with care, because otherwise your photo will look overprocessed, therefore easy on NeatImage, it's a great tool if you know how to handle it.
Sebastian
Canon 40D + 24-70 f/2.8 L + 70-200 f/4 L + Speedlite 430EX
Sketty222
Fri Feb 27, 2009 1:00 pm
Ive tried changing the crop size and less sharpening
Big version: Width: 1024 Height: 683 File size: 467kb
Silver1SWA
Crew
Fri Feb 27, 2009 1:24 pm
I can't view the large version of this one either.  Confused
Sketty222
Fri Feb 27, 2009 6:59 pm
Quoting Silver1SWA (Reply 8):
I've just clicked on the above pic and I cant view the larger version either. I think its a site problem as Ive tried to look at pictures in other people profiles and I get the same thing, a new pop up with the only thing showing "Close Window"
koryo
Sat Feb 28, 2009 6:20 am
Quoting FlyingZacko (Reply 6):
trust me Neat image has worked me wonders but I have to agree on you it over processes images most of the time
Psych
Sat Feb 28, 2009 7:58 am
Lee.
The image opens for me okay.
Unforunately I think you would have a rejection there - the sky remains pretty grainy and the overall aircraft is not as sharp as A.net like it to be. I am afraid the quality is not 100% here, so I would give this one a miss, due to its subject matter.
Cheers.
Paul
Sketty222
Sat Feb 28, 2009 12:02 pm
Quoting Psych (Reply 11):
Thanks Paul
