deltabravo90
Photo Acceptance - Pre Screening (DeltaBravo90)
Sat Feb 28, 2009 5:51 pm
Took the following shot a few weekends ago at CYHZ. Could some of the more experienced members give advice on it? I'm not sure about it being dark, also is it sharp enough?
http://i6.photobucket.com/albums/y249/mario_123/Aircraft/C-FGLY3.jpg
DeltaBravo90
koryo
RE: Photo Acceptance - Pre Screening (DeltaBravo90)
Sat Feb 28, 2009 5:54 pm
Looks completely back lit I don't know what you could do about that.
This forum is as good as you make it. Never post a message in anger. Take the high road and others will follow.
codeshare
Sat Feb 28, 2009 6:37 pm
Backlit, you can try playing with the levels/curves, but looks most likely exposure or even dark.
KS/codeshare
How much A is there is Airliners Net ? 0 or nothing ?
Fly747
Sat Feb 28, 2009 8:31 pm
It's dark. Back lit images can be accepted but need to be exposed properly in the first place.
Ivan
deltabravo90
Sat Feb 28, 2009 8:56 pm
So do you guys think there's hope for this photo? I'm not very good with photoshop, or other image processing software. What would i have to do to properly expose it.
DeltaBravo90
koryo
Sat Feb 28, 2009 11:06 pm
its very backlit, as previously metioned expose it properly and maybe it has a chance, just maybe but don't count on it
Fly747
Sun Mar 01, 2009 3:28 am
Quoting DeltaBravo90 (Reply 4):
Not much hope I'm afraid.
Well, that is a good question. Back light is probably the toughest light to deal with, especially for a.net. You need to meter the light on the "dark" side of the fuselage to expose it correctly, but on a bright sunny day this will cause you to over expose everything else around it. Does that make any sense?
Ivan
aussie18
Crew
Sun Mar 01, 2009 3:56 am
One for the personal collection,backlit abit to much,need some sunlight on the side your shooting from.
koryo
Sun Mar 01, 2009 4:09 am
Conclusion:
This photo is otherwise good besides that is backlit which is would be the probable reason for rejection if put in the queue.
Case Closed.
Koryo
gabriel3630
Sun Mar 01, 2009 6:10 am
Hello,
I think the highlights are overexposed, that may happened editing or shooting, if edit is easy to fix.
The color cast at shadows are too blue and cyan.
I guess they are more gray than blue. take a look on this photo:
http://cdn-www.airliners.net/aviation-photos/photos/8/6/2/0977268.jpg
Take a look in a quick edit I did:
http://farm4.static.flickr.com/3586/3317730691_9a5aa8b4e9_o.jpg
To fix that, I used the highlights/shadows tool, and color balance, than I select the aircraft and used Hue/saturation tool selecting only the only blue e cyan (where is Master) than reducing the saturation.
You may do better with the original.
Gabriel Nogueira.
Brasila684
Sun Mar 01, 2009 3:23 pm
Also, it appears to me like the tail of the aircraft is slightly soft. I would try sharpening it a little bit, but don't oversharpen, as you just go back to square one.  Smile
Brasila684
SkyWest Baby!!
deltabravo90
Mon Mar 02, 2009 10:56 pm
Thanks for all your help guys. It looks like I won't be uploading this one, looks like theres more flaws than I thought with it. Again thanks a lot for taking your time to answer my questions.
DeltaBravo90
Brasila684
Tue Mar 03, 2009 3:51 am
Quoting DeltaBravo90 (Reply 11):
Hey no problem man, I'm always happy to help.
Good Luck,
Brasila684
SkyWest Baby!!!
koryo
Tue Mar 03, 2009 3:54 am
Anytime, Koryo is always here to help, if you have other questions on any photos fell free to post them.
Koryo
