walter2222
Photo Acceptance - Post-Screening (Walter2222)
Fri Mar 06, 2009 9:23 am
Hi All,
I had this shot rejected for double and motiv:
http://www.airliners.net/addphotos/r..._ebfn_19940703_scan_wvb_1200px.jpg
I understand the double, since I have another shot in the database (same day, same side of the aircraft), but I had decided to upload anyway, given that there are only three shots of this reg. in the database. I thought this motiv was different enough (close-up, showing some details which can be handy for aircraft modellers...).
The question I have is thus more related to the motiv rejection part. Is it because of the steps attached to the aircraft or is this type of close-up not wanted?
Thanks and regards,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
flyingzacko
Fri Mar 06, 2009 9:43 am
Hi Walter,
not sure about the motiv, but you might as well have gotten NOA_Quality or NOA_Overprocessed for your excessive use of the shadow highlight tool showing up right underneath the wing and on the belly. The photo is rather grainy right there.
Sebastian
Canon 40D + 24-70 f/2.8 L + 70-200 f/4 L + Speedlite 430EX
ZakHH
Fri Mar 06, 2009 10:03 am
Maybe, but as a matter of fact, it was rejected due to motiv, and Walter was wondering why.
In the end, that's a question only a screener could answer, but my guess would be the attached steps as well. The crop would work for me.
Tired of a.net? Join a friendly aviation community!
walter2222
Fri Mar 06, 2009 10:57 am
Quoting FlyingZacko (Reply 1):
If I remember well, I did not use the shadow/highlight tool. It is, however, a scan from a slide and most of my scans are indeed grainy and that is more or less linear with age (from the slide  Smile ...).
Quoting ZakHH (Reply 2):
Thanks for the feedback!
Walter
Lanas
Fri Mar 06, 2009 1:15 pm
Hi Walter
Quoting Walter2222 (Thread starter):
 checkmark
Yes, I believe that as well.
For me too!  Wink
Despite all this, I´m not sure you´ll pass the double cut. Be sure to include a message to the screeners explaining why you´re uploading this double shot.
Could you paste the link to the other photo from the aircraft, so we can see it?
Good luck with it.  thumbsup
Cheers Big grin
Gastón.-
"Faithless is he that says farewell when the road darkens." J.R.R. Tolkien
walter2222
Fri Mar 06, 2009 4:23 pm
Quoting Lanas (Reply 4):
Sure!
Photo © Walter Van Bel
and in order not to be egoistic, I will also include the two other pictures in the database:
Photo © Rogier Vermeulen
and
Photo © Stephane Moitry
I had put a note to the screener that I was aware that this would be a double (given that it was also my shot, on the same day and showing the same side of the aircraft), but I also noted that I thought this close-up shot was a different motiv.
I was not surprised with the double rejection, but I just want to learn more why the shot was a not acceptable motiv.
After all the feedback, I assume that it is indeed the steps that are attached to the aircraft ( as is often the case with Swedish aircraft) that caused the motiv rejection.
Case closed  Smile
Walter
