Sketty222
Photo Accceptance - Pre-Screening (Sketty222)
Mon Mar 09, 2009 7:36 pm
Hi guys
As Ive probably mentioned to you before that Im pretty new to photography but am quite enthusiastic and want to try and progress further.
I decided that I would head out to NCL yesterday to try and get some shots whilst the weather was decent. Now I normally shoot using the auto settings on my Canon 450D so I thought I would try and use the advanced settings, in particular the TV setting.
I had the camera set up on TV with Auto White Balance, ISO at 100 and shutter speed at 1/3200. These are the images I was able to capture (unedited but reduced to 1MB to be uploaded at photobucket) and they are very dark.
Can anyone tell me where I have gone wrong and if these images could be saved in anyway?
Ive started to shoot in RAW also so I do have the CR2 image as well.
http://i196.photobucket.com/albums/aa135/Sketty22/IMG_1317.jpg
http://i196.photobucket.com/albums/aa135/Sketty22/IMG_1304.jpg
I know the images are quite soft but I believe that is because of the lens I am using at the minute (Tamron 70-300)
Thanks for any advice you can offer
timdegroot
Mon Mar 09, 2009 7:38 pm
1/3200 sound way too high a shutterspeed for these conditions. Are you certain you did not underexpose them because they are way too dark.
The softness looks salvagable with some PS but you need to work on your exposure first.
Tim
Alderman Exit
ake0404ar
Mon Mar 09, 2009 7:42 pm
They are both totally underexposed, care to share the EXIF.
For a newbie....just a few general tips:
Sun always in the back, f8 to f11 is a good aperture, shutter should more or less equal your focal length (300mm at least 1/250 sec or greater) and one important advice I would like to give you: read your manual and buy a book about photography to understand the basics.
Vasco
p.s come back and ask more questions and post your images, there are a ton of people who can help you out!
RonS
Mon Mar 09, 2009 11:44 pm
Anet member RudyC gave me the best advise! "Shoot in Manual and simply use your Exposure Meter." With the right conditions and trial and error, eventually it all just clicks!
All opinions expressed by me are my own opinions & do not represent the opinions in any way of my employers.
alevik
Crew
Tue Mar 10, 2009 5:24 am
Looks like you have already received advice from the experts.
I would never shoot aviation in shutter priority. For your next outing, set to aperture priority, select f8 or f9 and make sure the shutter speed automatically selected by your camera meter is equal to the inverse of the longest focal length of your lens. If you are shooting with a 100-400, the shutter speed should be at least 1/400 sec.
Your 450D is very capable of getting the right exposure. For editing ability, and depending on your camera meter, you may want to dial in an exposure compensation of -0.3, in other words intentionally underexpose by 1/3 of a stop. it is better to be under than over exposed during editing.
I would suggest for cropping that you are a bit "distant" - the aircraft is not filling the frame. Tighten up a bit. For my eye, the Thompson is low in the frame and the Thomas Cook is high.
I now have over 350 shots on anet (still just a beginner) but your first attempts here are as good as my first ones so keep at it and you will get there.
Improvise, adapt, overcome.
Sketty222
Tue Mar 10, 2009 7:47 pm
Quoting TimdeGroot (Reply 1):
I thought the higher the shutterspeed the better fr fast moving items but this isn't obviously isn't the case and just the way Ive interpreted it from my manual
Quoting AKE0404AR (Reply 2):
Quoting Alevik (Reply 4):
Thanks for the advice guys, I'll take this onboard and hopefully I will eventually get the results I am looking for
Vasco, its this attitude that makes me like a.net so much. You are such a friendly and helpful bunch of guys and willing to help even the amateur, amateur photographer like me
I hadn't cropped the photos at all and thats why they look so distant and low/high in the frame
Thanks again guys
ZakHH
Wed Mar 11, 2009 1:09 pm
Quoting Sketty222 (Reply 5):
Basically, that is correct. But (and that's a huge 'but'): in TV mode, the camera will automatically determine the correct aperture for the shutter speed you set, based on the available light.
But if the shutter speed is set too short, and the required aperture is bigger than the maximum your lens offers, then your shots will end underexposed. And that is exactly what happened to you here.
The minimum f-stop value (equaling the maximum aperture) that was available for your lens was probably around 4.0 or 4.5. But with that aperture, the shortest possible exposure time (for a correct exposure) would have been probably around something like 1/500 or 1/640.
However, you forced the camera to use 1/3200. The camera could not increase the aperture beyond the maximum, and so you ended up underexposed.
As mentioned above, you could have avoided it by using AV mode, instead of TV. But that's not a guarantee, either. No matter what mode you use, do always check the results after the shot.
If you shoot in TV, and you see that the camera used the maximum aperture (i.e. the smallest f-stop available for your lens), then you will need a slower shutter speed - or increase the ISO settings.
If you shoot in AV, and you see that the exposure times get too long, you will have to use a bigger aperture (smaller f-stop value) - or increase the ISO settings.
As for the ISO settings - you probably know that higher ISO settings will produce more grain, so that's not an ultimate solution, either. ISO 200 should be workable with your camera, but 400 and above will probably produce too much grain for the photos to meet this site's requirements.
You just can't buy more light without paying a certain price...  Wink
Tired of a.net? Join a friendly aviation community!
ruudb
Wed Mar 11, 2009 2:12 pm
I am sorry but I don't really agree with underexposing you are introducing noise, it is better to look on your histogram, on the camera keep the diagram to the right (normally it is the histogram of a Jpeg picture and in RAW you have enough headroom to compensate the eventually overexposure, which will be zero to none if your histogram doesnt end in a peak)
Sketty222
Wed Mar 11, 2009 7:31 pm
Quoting ZakHH (Reply 6):
Thanks for this advice. Hopefully we will have some decent weather here (North-East England) at the weekend so will hopefully put this advice to the test and see hwat results I get
ZakHH
Thu Mar 12, 2009 1:31 pm
Quoting Sketty222 (Reply 8):
Decent weather in north-east England - isn't that an oxymoron?  Wink
Seriously, practice is definitely the best you can do. Go out with your camera as good as you can, and try the different modes with different settings. Especially with static motives, try whatever setting would seem to make sense to you, and check the different results.
Are you familiar with reading EXIF data? Because that's an ultimate tool for such tests. It's basically the camera settings for each shot, that are stored within each file your camera produces.
Almost every photo software offers a function to view the EXIF data for a shot. It will then tell you everything, from the camera type over the focal length, shutter speed, aperture, ISO settings etc.
So if you shoot a motive with different settings, you can easily look the settings up later on, and draw your conclusions from it.
Some background information on EXIF can be found here: http://en.wikipedia.org/wiki/Exchangeable_image_file_format
Now - good luck with the weather...  Wink
Users browsing this forum: cypilot and 1 guest
