RonS
Photo Acceptance - Pre Screening (RonS)
Wed Mar 11, 2009 9:40 pm
Hello guys.
I've been having a problem with sharpening. Kinda was in a groove with Smart Sharpening, but someone along the way I've changed my work flow trying new things, but I need to bet back on track. Is this oversharp? Jaggies?
Anything else wrong?
Thank you
http://picasaweb.google.com/lh/photo...KDkhF9TEyL4ZAlh52g?feat=directlink
All opinions expressed by me are my own opinions & do not represent the opinions in any way of my employers.
oly720man
RE: Photo Acceptance - Pre Screening (RonS)
Wed Mar 11, 2009 9:58 pm
Quoting RonS (Thread starter):
Contrast, perhaps. The snow could certainly be whiter.
http://i4.photobucket.com/albums/y120/oly720man/SATA.jpg
NIKV69
At first glance looks level and centered. As for sharpening seems like it could use just a little more. Not sure why you are using smartsharpen. USM works just fine and you can use selective sharpening after the first few passes to fix any problem areas. I would give the front part of the tail just a little more, maybe the front part of the fuselage in areas look like they can use a tad. I tend to use more USM than less so keep that in mind.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
RonS
Wed Mar 11, 2009 10:25 pm
Oly720Man - How much Contrast do you normally use? After adjusting the Histogram levels I simply adjust the contrast between +1 - +5 max. What do you use? Not even sure why I use that...
NIKV69 - I've read on here that Smart Sharpen is more advanced, or rather a more precise way to sharpen because of improvements the programmers at adobe made with it. I really am pretty basic when it comes to layers and that stuff. I mean I basically make a layer for Levels, Contrast, Saturation and then convert a duplicate layer to a Smart Object and commence Smart Sharpen then after I resized it. Sometimes I forgo the Smart Object and just Smart Sharpen a duplicate layer. That is about as advanced as I get, but trying to learn.
NIKV69
Thu Mar 12, 2009 4:30 am
Quoting RonS (Reply 3):
Again it's all relative. Things like smart sharpen and layers are basically tools used for captures that need a lot of work. Smart sharpen when used in lens blur and a small radius is great for fixing blur and getting great detail. Now like anything else if not used right or in conjunction with requirements here you can just comlicate things. Which is why I have gotten great results with the formula from the upload page. Begin with only your best captures and use very little photoshop. Which at the end when the sharpening takes place a very simple pass with USM usually does the trick. Not saying you shouldn't use smart sharpen but if you are going to just get a good understanding of it and how it applies here.
oly720man
Thu Mar 12, 2009 10:34 pm
Depends on the photo. Pretty well all of my photos are older slides and prints that need variable amounts of editing (curves, levels, etc). I don't usually use a lot of contrast.
RonS
Wed Mar 18, 2009 12:44 am
Thanks guys. I got this accepted and I'm sure the help I recieved, especially in regards to contrast contributed to getting this accepted in the first try. Thank you.
http://www.airliners.net/photo/SATA-...ok=&sort=&prev_id=&next_id=1499182
Yeah, I don't know how to insert photos.
Ron
Users browsing this forum: Samuel1 and 1 guest
