alasdair1982
Photography With A Telescope
Sun Mar 22, 2009 5:13 pm
I am looking at the option of a telescope plus adapters for long range photography of aircraft, above 30,000 ft etc
Can anyone on here recommend a particular scope, but not too expensive for magnification I would require? Also which adapters etc I would need to work with the Nikon D60?
Thanks again
oly720man
RE: Photography With A Telescope
Sun Mar 22, 2009 8:48 pm
Can't recommend a particular scope, but you'll be looking for something with a focal length of around 1000mm to 1500mm.
This photo was taken with a 1200mm f5.9 telescope which will be something like the skyquest XT8
Photo © Sergey Kustov
http://www.scsastro.co.uk/it030020.htm
and is £300, or the similar Skywatcher Skyliner 200
http://www.pulsar-optical.co.uk/prod...tcher/dobsonians/skyliner-200.html
for £269
http://www.telescopeplanet.co.uk/Vie...Details.asp?prod_code=PON07I000031
or £299
Then you'll need the Nikon adapter whch will probably be around £20
Users browsing this forum: hisham and 1 guest
