whisperjet
Crew
Watermark Tools
Mon Mar 23, 2009 11:48 pm
Hi,
I've been looking for a tool to get watermarks in my picture for a while now. Since I often share my picture in forums etc I would like to add a small watermark to my picture (my name or so in on of the corners). I found some programs but all of them were not really that good. Either the functions to create the watermark were very basic (was thinking a bout a half transparent watermark) or did not allow batch processing.
Does anybody here know a good program?
Thanks  Smile
Stefan
Nobody is perfect - not even a perfect fool.
ptrjong
RE: Watermark Tools
Mon Mar 23, 2009 11:51 pm
Stefan
I think you want to stress this is not for photos you're uploading
Peter Smile
Stealthz
RE: Watermark Tools
Mon Mar 23, 2009 11:59 pm
Stefan,
Do you use Photoshop?
If so, with a few minutes work you can create a small image file with your name and © symbol etc (basically anything you like really) and set it's transparency, special features etc.
This image can then be saved as a brush and applied whenever required.
The beauty of this approach is the watermark/brush can be resized, positioned or applied in whatever colour required
Chris
PS if there is enough interest in this I could write a short tutorial on how it is done.
[Edited 2009-03-23 17:02:05]
Moose135
RE: Watermark Tools
Tue Mar 24, 2009 12:50 am
Quoting StealthZ (Reply 2):
That would be great, Chris - I for one would love to see how that is done.
damien846
RE: Watermark Tools
Tue Mar 24, 2009 6:42 am
Yes please so would I!
Damien
Stealthz
RE: Watermark Tools
Tue Mar 24, 2009 9:38 am
Ah, knew someone would ask...
Quick & dirty Photoshop CS way! I know I am up for a hardware & software upgrade soon.
Copyright watermark
Create New file, size at this time is not important
Select Background content = transparent
Select text tool and type desired content e.g. DamienMoose © 2009
Font size s not critical as long as you can see what you are doing.
If you wish copyright symbol in PS it is ALT+0169(on Numeric keypad)
You can fade the text at this stage using opacity control on Layers control panel but I do not bother.*
At this point crop closely around your text and depending on your text size. resize the image to 200-300px wide. (if happy with result save file)
To make brush, Edit menu -> Define Brush patterns... ->name brush
That is it, now anytime you want to watermark an image just select that brush.
Size, colour and opacity are not an issue as these can all be selected to suit the image.
I tend to use a black or white watermark and use Edit-> fade brush tool (SHFT+CTRL+F) to get appropriate opacity.
* It is possible to create an Action to batch add watermarks to a number of images, if you do that it would be desirable to create the brush in the size and opacity you desire rather than adjusting later.
I hope that is all clear
Chris
whisperjet
Crew
RE: Watermark Tools
Tue Mar 24, 2009 9:53 am
Chris, thank you very much for your detailed tutorial. I'm still at work but I'll try it when I'm at home. If I have any question I'll come back to you again  Smile.
Of course the watermarks are not intended for a.net uploads  Wink
Stefan
Moose135
RE: Watermark Tools
Tue Mar 24, 2009 4:59 pm
How cool is that! I just gave it a try in CS3, and it worked like a charm. Thanks for the tutorial, Chris!
scottieprecord
RE: Watermark Tools
Tue Mar 24, 2009 5:42 pm
Awesome! Works perfectly!
damien846
RE: Watermark Tools
Tue Mar 24, 2009 6:57 pm
Great! Thanks for that Chris, but can anyone tell me if it can be done in Elements 5?
Quoting StealthZ (Reply 5):
can find this bit !
Damien.
scottieprecord
RE: Watermark Tools
Tue Mar 24, 2009 8:49 pm
Quoting Damien846 (Reply 9):
Hmm, I have Elements 4, and it was there.
When I click to open a blank document, a window pops up, and at the bottom is a drop-down menu saying "background contents". The transparent option was at the bottom of that list.
Hope you find it!
INNflight
RE: Watermark Tools
Tue Mar 24, 2009 9:44 pm
Great idea Chris.
What I do, and what I can recommend too, is making a Photoshop action.
On the lower right hand toolbar you have "history" and "actions". Click on actions, and you'll find a little bar on the very bottom with various icons, like "play", "stop", "trashcan" etc.
Click on the 2nd icon from the right, which is "create new action".
Then just do your watermark once like you want it, i.e. create a text field, select the style you want, the font you want, transparency etc... When you're happy, click on the "stop" icon in the toolbar.
You'll just have to give it a name you like ( i.e. "Watermark" ), and from now on it's there until you de-install Photoshop.....so all you have to do is run the action once with the "play" button from now on, you'll get the same watermark on any image / file you open.
Very handy, especially as you can create ANY action for anything, i.e sharpening, colour, etc....!
Jet Visuals
damien846
RE: Watermark Tools
Wed Mar 25, 2009 3:05 pm
Quoting Scottieprecord (Reply 10):
Cheers that works, just got to work out the copyright C insert, and I will be there!
cheers
Damien
ruudb
RE: Watermark Tools
Wed Mar 25, 2009 3:52 pm
In Photoshop you can make a brush of it, type the text you want, select it with the rectangele selectiontool add it to your brushes and you have a brush, you are able to place it wherever you want and make it as large and small as you want.
Stealthz
RE: Watermark Tools
Thu Mar 26, 2009 12:15 am
Quoting Damien846 (Reply 12):
Damien, I just tried my tutorial on a PC with Elements 5 and it works exactly the same as I wrote so you should have no difficulties
To enter a © symbol hold down the Alt key and type 0169 with the numeric keypad, Note this must be done with the numeric keypad. If using a laptop, most have an embedded Num keypad, you will need to enable that to enter the 0169. (on my ThinkPad, Shift+NumLk)
Another method is to use the Windows Character Map pound in All Programs->Accessories->System tools, simply select the character you wish to copy then paste it into the application where needed.
damien846
RE: Watermark Tools
Thu Mar 26, 2009 6:36 am
Chris,
Thanks for the information, i was using my laptop!! I will have a play with it on the main PC when I get home from work this evening.
Thanks Again for your help.
Damien
Stealthz
RE: Watermark Tools
Thu Mar 26, 2009 7:26 am
Quoting StealthZ (Reply 14):
OOPS, not paying attention this should of course read -
Windows Character Map found in All Programs->Accessories->System tools
Kereru
RE: Watermark Tools
Fri Mar 27, 2009 1:38 am
For the Mac users it is Option + G
Thanks it is most helpful.
Colin  old
Good things take Time.
whisperjet
Crew
RE: Watermark Tools
Fri Mar 27, 2009 7:57 am
Works!
Thank you for the tutorial  Smile
Stefan
damien846
RE: Watermark Tools
Sat Mar 28, 2009 2:50 pm
Chris,
Thanks for this I now have it sorted.
Great Thread!
Damien
topgun3
RE: Watermark Tools
Mon Mar 30, 2009 1:53 am
As pointed out in one of the replies, recording an ACTION in Photoshop is the easiest. Anytime after that I feel like including a watermark....I just click and play that option....takes about 2 sec. to do.
I'd rather be flying.
Stealthz
RE: Watermark Tools
Tue Mar 31, 2009 4:23 am
As InnFlight and TopGun3 have pointed out it is also possible to create a PS action to do this.
There are pros & cons for both and I use both, Actions are great if you want the watermark to be consistent in everyway or you are batch processing images.
The brush option allows you to better control the position, size, opacity and colour of the watermark.
No right or wrong way just choice.
Chris
RE: Watermark Tools
Tue Apr 14, 2009 1:34 am
Brilliant, thanks Chris! Very helpful.
Is there an easier way to have it as a single stamp rather than a brush that is saved in the pattern stamp tool?
