cvervais
To Tripod Or Not To Tripod.
Sat Mar 28, 2009 9:46 pm
A question for you folks, when shooting a aircraft on approach or departure are you going hand held or do you have the camera on a tripod?
I'm working on getting sharper images and I'm wondering if at SJC my shots are soft because I'm holding the camera to track the aircraft rather than doing it on a tripod.
The lenses I use are a 70-200 f/2.8 with a image stabilizer and a 100-400 f/4.5-5.6 with a image stabilizer.
timdegroot
RE: To Tripod Or Not To Tripod.
Sat Mar 28, 2009 9:49 pm
When shooting in daylight you wont need a tripod. What shutterspeeds are you using? With your equipment you should be able to get sharp results handheld very easily
Tim
Alderman Exit
Silver1SWA
Crew
Sat Mar 28, 2009 10:36 pm
I only use a tripod when doing long exposures at night. During the daytime, I hand-hold everything. Now that I got the 100-400, I might start looking into a monopod to help a little when shooting a lot at the long end. Check your other thread for something I posted regarding your softness issue.
Man, I need to do some photography at SJC again. Since I have become serious about this stuff, I have yet to return to my former "home airport" and subject of my first batch of photos here about 10 years ago...damn! And I'm even in town right now but did not bring my gear! Doh!  banghead
cvervais
Sun Mar 29, 2009 12:11 am
Well, I'll likely be at the San Jose state aviation parking lot tomorrow in the afternoon practicing. Drop by if you like. I'll gladly accept pointers.  Smile
soon7x7
Sun Mar 29, 2009 3:36 am
I believe your to disable the VR option when on a tripod...either way, no tripod during healthy lighting, panning at dusk yes, night ...absolutely!
cpd
Sun Mar 29, 2009 12:12 pm
Quoting TimdeGroot (Reply 1):
With a 100-400mm IS lens, as Tim says, you won't need a tripod even in dwindling light.
I was out with a photographer who was using that lens with IS turned on attached to a Canon 5D Mk.2, and the results he achieved were great considering the rapidly dwindling light. Both of us had no trouble hand-holding the cameras for departure shots. I didn't have any IS/VR, but I had no trouble either.
I think if you want to spend money on anything, the monopod is a slightly better option because they are less cumbersome. But I even find a monopod irritating to work with, they restrict your freedom of movement. They are best for static photos.
Kukkudrill
Mon Mar 30, 2009 3:46 pm
With the 100-400L you can get soft photos when shooting wide open at maximum zoom. I keep mine on f8 and go to ISO200 if necessary to keep the shutter speed up.
Heat distortion is another possibility. It can affect photos even if the weather is not particularly hot, especially when you are shooting at long range. Mild heat distortion won't produce the trademark wobbly lines but it can still kill detail and make photos look soft, leaving you scratching your head as to why your lens is not performing up to expectations.
Can you post a sample or two?
Make the most of the available light ... a lesson of photography that applies to life
michlis
Mon Mar 30, 2009 5:23 pm
Quoting Cvervais (Thread starter):
Believe it or not, using the image stablizer in daylight conditions at 1/100 plus shutter speeds can actually be counter-productive. Suggest you switch it off unless you are in low-light conditions. The added benefit is that you'll save on your battery.
[Edited 2009-03-30 10:24:19]
If you know the enemy and know yourself, you need not fear the outcome of a hundred battles.
sulman
Tue Mar 31, 2009 9:51 am
Quoting Michlis (Reply 7):
Not sure I agree. You shouldn't use full stab (manufacturers seem to recommend vertical only, or 'mode 2' in sigma-speak) but I've not really noticed much difference.
javibi
Tue Mar 31, 2009 10:39 am
Where do you get that info from?
j
michlis
Tue Mar 31, 2009 11:10 am
Quoting Sulman (Reply 8):
Not sure I agree.
Quoting Javibi (Reply 9):
I'm a professional sports photographer and a collegue who has been in the business longer than I (she currently works for an affiliate of CBS Sports) noted that in regular light conditons IS tends to try and over-compensate and can in fact work against you not to mention eat up your battery. You don't have to agree with me, but I found her advice to be sound. I'm sure the thought is that sports and aviation photography are different and that is true, but they are quite alike in a lot of ways too.
My rule of thumb: if I have lots of ambient light with a high shutter speed and low ISO (no more than 400) and I haven't drank a pot of coffee before I shoot, the IS is turned off. Low ambient light higher ISO with lower shutter speed (and no flash) I'll use the IS.
Getting back to the tripod issue, I hardly ever use either. The only time I would use one would be for a long exposure static shot or if I were spotting with a large prime (although I'm sure this would make airport security really paranoid considering the less than enthusiatic reception my 50D/70-200 2.8 combo gets when I'm at the perimeter.
[Edited 2009-03-31 04:22:09]
[Edited 2009-03-31 04:41:13]
cvervais
Wed Apr 01, 2009 3:27 am
Good advice, I'll be putting some of it to work this weekend.
