ocean773
Photo Acceptance - Pre Screeing
Fri Apr 10, 2009 7:14 am
Hello
I have two photo's and would welcome any suggestions for improvement before sending in que.
Any information will be appreciated.
http://www.airliners.net/uf/view.fil...=536943032&filename=php0BCV6e.jpeg
and
http://www.airliners.net/uf/view.fil...=536943032&filename=php3bP4zU.jpeg
Sam
dlowwa
RE: Photo Acceptance - Pre Screeing
Fri Apr 10, 2009 7:21 am
Quoting Ocean773 (Thread starter):
Well, to start with, you'll need much better crops. The first one is far too low in the frame, and has empty space to the left and right of the plane.
The second one is also far too low in the frame, and has empty space to the left and then part of the horizontal stabilizer cut off.
Both also seem to suffer from over sharpening.
Come back and try again with some better crops.
ocean773
Fri Apr 10, 2009 7:51 am
dlowwa
Fri Apr 10, 2009 7:56 am
Quoting Ocean773 (Reply 2):
let me know what you think of new ones below
uhhh... they look the same to me.
aussie18
Crew
Fri Apr 10, 2009 8:29 am
Both are oversharpened quite badly,Noticable jagged edges on Virgin tail,Virgin titling,wing etc,also backlit and centring is way off,try to centre the fuselage in centre of frame so you have equal amount of deadspace at top-top fuselage and bottom-bottom of fuselage.
ANZ A320 one is still low in frame,needs tighter crop on each end aswell,Jaggy edges quite noticable around wing,tail wing,engine and ANZ titling.
Cheers Mark.
Users browsing this forum: johnr and 2 guests
