A388
Photo Acceptance - Post Screening (A388)
Mon Apr 27, 2009 12:11 pm
Dear members/screeners,
My below photo got rejected:
http://www.airliners.net/procphotos/...9994335.4525usafe4rccur170409a.jpg
Is there a way to save this photo?
A388
varig767
RE: Photo Acceptance - Post Screening (A388)
Mon Apr 27, 2009 1:21 pm
Quoting A388 (Thread starter):
Depends on rejection reason. I suspect the fence is causing a motive rejection. It is more useful to announce the rejection-reason(s) in post-screening.
Kind regards, Martijn
airkas1
Crew
Mon Apr 27, 2009 1:53 pm
Hi Roger, what was the rej. reason?
Airliners.net Crew - Head Photo Screener
oly720man
Mon Apr 27, 2009 2:54 pm
Rejected for dark?
http://i4.photobucket.com/albums/y120/oly720man/b747.jpg
A388
Mon Apr 27, 2009 3:08 pm
How stupid of me, please find below the rejections reasons:
There is a problem with the contrasts in these photo(s). The whites in the
image are not pure white, or the blacks are not pure black.
There may be several reasons for this problem, and depending this, it may
or may not be possible to correct it. If you want to read more about this
problem, and about possible ways to correct it and hopefully attempt a
re-upload, please go to
http://www.airliners.net/procphotos/reasons.php#contrast
The transition between solid lines on these photos have a very jagged
appearance. This may be due to general oversharpening of the image, but
there may also be other reasons for this problem.
In some cases the jagged appearance can be corrected. If you want to read
more about this problem, and about possible ways to correct it and
hopefully attempt a re-upload, please go to
http://www.airliners.net/procphotos/reasons.php#oversharpened
Should I darken the photo a bit as mentioned already? I take it that the sharpening rejection lies in the letters on the fuselage but how can not sharpen that section selectively, the letters are just too thin to avoid jagged edges in that area.
A388
whisperjet
Crew
Mon Apr 27, 2009 3:18 pm
Hi Roger,
I think your picture could be saved if you start up with a new edit from scratch.
The titles and the vertical stabilizer are quite jagged and the contrast is off.
The picture also looks quite grainy to me.
Stefan
Nobody is perfect - not even a perfect fool.
A388
Mon Apr 27, 2009 3:43 pm
Quoting Whisperjet (Reply 5):
Hi Roger,
Stefan
Okay thanks Stefan. I will have a look at it. The graininess is an issue I sometimes have difficulty with. The fact that I also use an older version of PS (version 2.0) also plays its part. Editing photos with the newer versions seems to be far better than the relic 2.0 version it seems.
I will have a look at it again and thanks again  Smile
A388
airkas1
Crew
Mon Apr 27, 2009 3:57 pm
Quoting A388 (Reply 4):
He said, that the image might be a bit dark too, not that you should make it darker  Wink
A solution for the sharpening might be to sharpen in layers.
A388
Mon Apr 27, 2009 5:52 pm
Quoting AirKas1 (Reply 7):
Hi AirKas, it's been a long time hearing from you. Nice to see your reply here. I will also take into account your tip.
A388
whisperjet
Crew
Mon Apr 27, 2009 9:31 pm
Quoting A388 (Reply 7):
I still use some old Photshop Elements version that came with a scanner for jpg files and I'm still satisfied with it (though I also have CS3 for RAW files that I take from time to time).
Maybe you should consider getting a noise reduction programm, eg Neat Image. Properly used the output files look much better.
Stefan
