Spiderguy252
Can A Fuel Truck Ruin Your Motive?
Fri May 01, 2009 3:23 pm
Can a fuel truck in front of the engine ruin the motive of your photograph? Here's one I took recently:
http://i39.photobucket.com/albums/e168/Spiderguy252/Tryouts/30042009042-001.jpg
Isn't a fuel truck part of an aircraft operation while on the ground?
Vahroone
waketurbulence
RE: Can A Fuel Truck Ruin Your Motive?
Fri May 01, 2009 3:28 pm
Yes, it ruins it. This is not rampoperations.net. Fuel trucks, catering trucks, buses, cars, etc have ruined thousands of shots for many photographers.
-Matt
ANITIX87
Fri May 01, 2009 3:54 pm
A fuel truck is not an automatic rejection...
Quoting Spiderguy252 (Reply 2):
http://www.airliners.net/photo/Saudi...d=b790e23c12bf2a5ca1735ff05f4bbeaa
The focus is the rear 3/4 of the aircraft, and the fuel truck only blocks the front gear. It's small enough that the engine or other main components are not blocked.
http://www.airliners.net/photo/China...d=b790e23c12bf2a5ca1735ff05f4bbeaa
The truck isn't in front of the aircraft, and as the caption says, the size comparison is funny.
http://www.airliners.net/photo/KLM--...d=b790e23c12bf2a5ca1735ff05f4bbeaa
Old photo, and the importance is the classic aircraft and nature of the shot.
http://www.airliners.net/photo/SriLa...d=b790e23c12bf2a5ca1735ff05f4bbeaa
Again, not blocking any part of the aircraft.
http://www.airliners.net/addphotos/r...4_o1236734191.5443lvbbu_1edit3.jpg
Truck isn't blocking any part of the aircraft, and focus is on the artwork on the front, and the cockpit.
TIS
Silver1SWA
Crew
Fri May 01, 2009 4:07 pm
Most of the examples you posted were accepted a few years ago. The standards here are always changing so it's very possible that if submitted today, some would not make it.
Plainplane
Fri May 01, 2009 4:17 pm
Actually that 5th one was rejected, I think for motive relating to the jetway.
It is a bit annoying when special shots are rejected for motive simply because the jetway or a truck is in the picture. It is an unavoidable obstacle that often causes even the most precious and unique shots to be rejected.
I wish that A.net would lighten up on the equipment-causing motive rejection if it isn't blocking the main focal point, it is quite discouraging since it can often be hard at some airports to get shots of planes while they aren't in the gate area.
Unfortunately Spiderguy your main focal point (aircraft front view) is blocked by the truck.
Spiderguy252
Fri May 01, 2009 4:36 pm
Quoting Plainplane (Reply 5):
True. Just imagine how good this shot would look without those nagging trucks around:
http://i39.photobucket.com/albums/e168/Spiderguy252/Tryouts/30042009043-001.jpg
By the way, ignore that spot on the left. That was due to the dirty glass.  Wink
Vahroone
JakTrax
Fri May 01, 2009 4:48 pm
In both your examples I think the most worrying thing affecting the motive is level.....
Karl
2H4
Fri May 01, 2009 4:49 pm
Here's the shot that taught me the lesson:
MyAviation.net photo:
Photo © Jason McDowell
The tip of the cone caused a motive rejection.  banghead
2H4
Intentionally Left Blank
Spiderguy252
Fri May 01, 2009 4:54 pm
Quoting 2H4 (Reply 8):
 Wow! That's harsh, isn't it? That's a nice click, nevertheless.
Vahroone
Granite
Fri May 01, 2009 5:41 pm
Hello
Quoting Spiderguy252 (Reply 6):
Unfortunately no, the quality is ghastly.
Gary
JakTrax
Sat May 02, 2009 1:55 am
To be honest it is distracting and I agree with the rejection - the cone is obstructing part of the aircraft, however slight.
Personally I'd have seen that coming and would have reserved it for the personal collection. Could you not have found anything to stand on to elevate your position? Or just been a tad cheeky and move the cone for a second?
Karl
RonS
Sat May 02, 2009 2:58 am
There is a major difference from your shots compared to the examples you posted. Take a little time, look at the differences and they'll be evident.
Think about it, you have a fuel truck blocking one engine, and I believe an portable AC truck blocking another, with the cone in the middle partially obscurring the nose wheel.
Not knocking it, just over time it will become apparent the differences.
All opinions expressed by me are my own opinions & do not represent the opinions in any way of my employers.
2H4
Sat May 02, 2009 4:00 am
Quoting JakTrax (Reply 11):
When I shot that photo, I wasn't thinking about it at all. That rejection taught me to watch for obstructions, and I now do everything I can....including moving the obstructions.....to make the shot work. I'll even ask museum staff for permission to move barriers and barricades out of the way.
Overall, this is one rule that I wish would be relaxed for rare shots and for shots of aircraft that aren't already in the database. It's one thing for a cone to be blocking part of a tire on a British Airways A320 at LHR. It's quite another for a cone to be blocking part of a tire on a newly-documented aircraft that might venture out of a hangar only a few times a year.
2H4
Plainplane
Sat May 02, 2009 4:16 am
Quoting 2H4 (Reply 13):
Overall, this is one rule that I wish would be relaxed for rare shots and for shots of aircraft that aren't already in the database. It's one thing for a cone to be blocking part of a tire on a British Airways A320 at LHR. It's quite another for a cone to be blocking part of a tire on a newly-documented aircraft that might venture out of a hangar only a few times a year.]
Agreed. On Thursday I saw the newest A320 in the JetBlue fleet. So new that it did not have a name yet, and while I was standing there photographing it, all the aircraft lights were turned on at one point. The problem is that the jet bridge was attached to the door, an unavoidable circumstance. I am hoping that if I try to submit it to the database, that the screeners would make an exception for the special situation, but I am doubtful.
JakTrax
Sat May 02, 2009 10:52 am
Quoting Plainplane (Reply 14):
There are two sides to this story.
An Il-76 never before seen by human eyes perhaps should warrant some flexibility, but on the other hand too many obstructions will effectively make it a poor photo, which obviously would be detrimental to the A.net philosophy. A jetblue A320, however new, is still a Jetblue A320 and therefore should warrant no special treatment what-so-ever. It's like new Ryanairs - the next looks very much like the last.
Come on folks, use common sense here - while we do moan about certain things this site has undoubtedly built up the reputation of hosting only the very best images, and anything which could jeopardise that ain't worth thinking about. You know the rules by now - if there's any doubt, why risk your ratio needlessly? To keep the site going forward we need to consistently supply the best images we can.
Karl
Silver1SWA
Crew
Sat May 02, 2009 8:07 pm
Quoting JakTrax (Reply 15):
Exactly. And give a brand new jetBlue aircraft about a week or two before someone out there catches it in proper airliners.net fashion.
EZEIZA
Sat May 02, 2009 9:32 pm
By coincidence, that picture is mine ... I guess I must have opened a thread about the rejection because if not I have no idea how it ended up here  Big grin
And yes, I still don't understand, months later, why I got a motive rejection. I can understand other reasons,but motive? It is so sensitive as to who is uploading that it's not worth "fighting" anymore  Wink
Carp aunque ganes o pierdas ...
Plainplane
Sun May 03, 2009 2:47 am
My ratio is already in the garbage, and if I didn't think the shot would a chance then I wouldn't upload it. My idea is that if the shot is bad, then the screeners would simply reject it, but if the reasons are potentially correctable, I would attempt to rework it until the shot is considered worthy, as now I have good editing software available to me that I didn't have before.
Before I got my Canon Powershot G10 and CS4, I often just attempted to upload any shot that I made without any regard to quality or motive. However now I have a better idea of the subject and I take photos whenever I am able to. I still think the shot has potential but I will probably post a thread with it before submitting it.
LHRTOSFO
Sun May 03, 2009 4:23 am
I think you also need to work on the quality of your pics getting the right motive isn't the only thing that makes a picture good.
lhrtosfo
EZEIZA
Sun May 03, 2009 4:37 am
Quoting LHRTOSFO (Reply 19):
Absolutely, but how many times have we seen good shots rejected for motive? And I can show you average shots with dubious motives that do get in. So it's a matter of taste sometimes
JohnJ
Mon May 04, 2009 2:13 am
Has anyone here really gotten a motive rejection for ramp clutter that didn't obstruct the aircraft? I love taking pictures from airport terminals and I have a fair number of shots with plenty of ramp lice. I can't remember getting a motive rejection for the equipment unless it did block a portion of the main subject.
mhtspotter
Mon May 04, 2009 6:23 am
I don't think its to obstructive at all and love the shot, but there is a problem with level. Other than that I love a little clutter. This site needs to change this. This picture should be added as long as the level is corrected. Shot is too soft also.
[Edited 2009-05-03 23:25:05]
Users browsing this forum: 727LOVER and 2 guests
