sovietjet
Photo Acceptance - Post-screening (sovietjet)
Fri May 15, 2009 7:16 am
Hello all. Usually when I get rejections I catch the error. But here I am confused about both of these.
This one is for quality and oversharpened. I guess I can see some jagged oversharpened edges, but quality? What's wrong with the quality? Or is the quality rejection due to the oversharp?
http://www.airliners.net/addphotos/r.../20090514_y1241767395.00971113.jpg
And this one is for dark. It was at sunset and is a white plane. How is it dark?
http://www.airliners.net/addphotos/r.../20090514_s1241767090.85531501.jpg
aussie18
Crew
RE: Photo Acceptance - Post-screening (sovietjet)
Fri May 15, 2009 7:37 am
Quoting Sovietjet (Thread starter):
1st one i can see some jaggies,quality does seem okay so try re edit and use eraser tool abit more on top of tail wing,wing where jags can be seen.
2nd one just adjust the curves to make it abit more brighter,does look dark to be honest.
Cheers Mark.
sovietjet
Wed May 27, 2009 7:21 am
Here's another rejection I just got. The only reason given was "color" with a personal message that said there is a red cast. This was taken right at sunset so of course there is going to be a red cast. Should I appeal?
http://www.airliners.net/procphotos/...=20090526_q1242719929.94821443.jpg
dlowwa
Wed May 27, 2009 8:07 am
First one, you can definitely see the jaggies along the top of the horizontal stabilizer. As for quality, can't really say...
Second one could probably stand to benefit from an increase in brightness...
http://img33.imageshack.us/img33/9724/20090514s12417670908553.jpg
Third one, although it loses some of the effect I'm sure you were going for, does look a little more natural if you dial-down the red/saturation a bit...
http://img25.imageshack.us/img25/7078/20090526q12427199299482.jpg
There's also a smudge of some sort in the botttom-left of the frame...another plane in the clouds? Hard to tell...
I personally wouldn't appeal, but hey, it's your choice.
Dana
sovietjet
Wed May 27, 2009 9:04 am
Thanks Dana. I'll try resubmitting it with your type of edit. The smudge is another plane
