wilco737
Formation Pictures And The Double Rule
Tue May 19, 2009 1:27 pm
Hi Guys,
recently the Patrouille Suisse was here in Hamburg.
Now I have a question about the double rule. I read the rejection guide but it wasn't 100% clear for me if that is allowed or not. I want to upload a picture where it shows 4 airplanes in the formation and then I'd like to upload another one where it only shows one of the airplanes. It is same day, same airshow, just a couple of minutes apart from another.
I assume this is to be considered as double then?
Thanks for the help.
wilco737
 camera
timdegroot
RE: Formation Pictures And The Double Rule
Tue May 19, 2009 1:35 pm
If from the same side, yes.
Tim
Alderman Exit
wilco737
Tue May 19, 2009 1:38 pm
Quoting TimdeGroot (Reply 1):
Yes, they are.
But I just found out that on the formation picture there are 4 airplanes in it and the single side one shot is another one which is not part of the formation. Is that double as well? I mean it is a different registration.
wilco737
airkas1
Crew
Tue May 19, 2009 1:45 pm
Quoting WILCO737 (Reply 2):
Phil, then its not a double.
Airliners.net Crew - Head Photo Screener
wilco737
Tue May 19, 2009 1:49 pm
Quoting AirKas1 (Reply 3):
Kas, thank you. Just wanted to make sure.
wilco737
ptrjong
Tue May 19, 2009 2:45 pm
You can only have a double if it's the same airframe, as determined by the information.
So the close-up wasn't very likely to be a double, even if that aircraft was visible in the formation shot. For formation shots, the info should refer to the closest aircraft.
Peter Smile
walter2222
Tue May 19, 2009 8:22 pm
Quoting Ptrjong (Reply 5):
I agree with Peter here. Although I have to admit that I did it differently here:
Photo © Walter Van Bel
where I selected the registration of the leader (#1), I guess it is sometimes difficult to decide - in formation flying - which aircraft is closest to the photographer...
Anyway, I also think that the "motiv" of the formation shot is different enough from a "close-up of one aircraft" in order to avoid a double rejection, or am I wrong here?
I have another shot of the #8 in the database, but since the #8 is not present in the formation shot, I cannot proof my above statement  Smile (since different regs - in most cases - cannot lead to double rejection).
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
wilco737
Tue May 19, 2009 8:26 pm
True, just wanted to make sure  Smile
Quoting Walter2222 (Reply 6):
In my shot I cannot really make out which is the closest to me.
Thanks for the replies guys, I will wait and see.
wilco737
ptrjong
Tue May 19, 2009 8:59 pm
Quoting WILCO737 (Reply 7):
Then pick one that you don't want to upload a close-up of  Wink
wilco737
Tue May 19, 2009 9:03 pm
Quoting Ptrjong (Reply 8):
Done  Smile
wilco737
