wilco737
Photo Acceptance - Pre-Screening Double (wilco737)
Sat Jun 20, 2009 9:55 am
Hi guys,
have a question about double. I have a picture of D-ALCP in the database:
Photo © Wilco737
Now I want to upload another shot of the MD11, this time the engine, but it is same airplane, same day. Is this double or is the motiv different enough?
http://www.airliners.net/addphotos/b...eady/h1245491548.548img_0542_u.jpg
Thanks.
wilco737
 camera
JohnKrist
Crew
Sat Jun 20, 2009 10:03 am
Has it moved or is it in the same spot? If it has not moved it's double.
Love the shot though, and think that there should be exceptions to the double rule.
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
wilco737
Sat Jun 20, 2009 10:06 am
Quoting JohnKrist (Reply 1):
Same spot, same place, same everything, just a very different motiv. I know that pictures from one side and then the other side are allowed from the same day, so why not the nose and the engine? Is it really that double?
Thanks.
wilco737
JohnKrist
Crew
Sat Jun 20, 2009 10:12 am
Mmm, reading that different sides might be OK, so maybe it would be OK. Try!  Smile
Jalap
Sat Jun 20, 2009 10:30 am
Quoting JohnKrist (Reply 3):
Well, this engine is on the other side of the plane than the nose shot so I would say that an exception to the double rule is not even needed here.
wilco737
Sat Jun 20, 2009 10:33 am
Quoting Jalap (Reply 4):
I haven't seen it from that point of view.  thumbsup
It is in the queue  Smile
wilco737
dazbo5
RE: Photo Acceptance - Pre-Screening Double (wilco737)
Sat Jun 20, 2009 11:52 am
wilco737,
It's a totally different motive so double won't apply in my opinion. I would question the motive and lighting though, it's dark at the rear of the engine there's not much of the engine to look at. It's a great perspective and not often seen by us that don't have airside access and get this close to the moving parts, but maybe it would have been better taken from in front of the engine rather than the rear to get the fan blades and maybe the leading edge of the wing?
Darren
wilco737
Sat Jun 20, 2009 12:01 pm
Quoting Dazbo5 (Reply 6):
Thank you for your opinion. I had a picture rejected which showed a different motive as well, so this time I wanted to make sure.
I like the way looking at the engine. Usually it is from the front towards the rear where you can see the fanblades. I liked to show the whole engine with the exhaust instead of the fanblades.
So I did this intentionally Big grin
wilco737
acontador
Sat Jun 20, 2009 3:14 pm
Hi Phill,
That would not be a double, as long as those are the only two you upload! However, I feel the overexposed background kills the shot for me. In this case, probably you should have chosen exposure such as to have the background correctly exposed, and then use fill flash to attack the shadows.
I am sure you will get more opportunities to try this kind of shot again, so why not wait and get it right?
Just sit back, relax and have a glass of Merlot...enjoy your life!
wilco737
Sat Jun 20, 2009 3:45 pm
Quoting Acontador (Reply 8):
Hi Andrés,
thanks for making this clear, I wasn't sure.
Thanks for the advice. It will not get too easy as I recently more and more be questioned by security why I am taking pictures at the airport being airside. That's why I uploaded several shots with "unknown location" already. Same with this shot.
But I will keep on trying.
I will pull it from the queue.
Thanks.
wilco737
Users browsing this forum: michaelgri and 1 guest
