JThompson
Question On Sharpening.....
Sun Jun 21, 2009 5:26 am
Hi all,
I have been reading the Masterclass thread and other's on Sharpening, where a lot of people use multiple passes at the same percentage of USM, or different percentages of USM.
My question is, does everyone that uses this method Expand before each new pass, as Fergul describes in his Tutorial, if so, by how much, Fergul says by "1", is this the general rule of thumb?,......also, is this all done on the one Duplicate Layer, or are there more than one Duplicate Layer being used?
Any help on the process of this will be very much appreciated.
Jeff.
NicolasRubio
RE: Question On Sharpening.....
Sun Jun 21, 2009 5:42 am
I use an action I made up myself by following a tutorial I once read. It goes something like this:
- Duplicate layer
- Select all and copy
- Create alpha channel
- Paste
- Filter -> Stylize -> Find edges
- Bump up the levels to get things "blacker"
- Select with the tool that is to the left (first one) where the trash can to delete layers is
- Invert selection
- Delete the channel
- Go to the duplicated layer, apply USM to your personal taste
- Select none
- Flatten image
Hope it helps!
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
locsta
Sun Jun 21, 2009 6:17 pm
I haven't read the tutorial you are refering too, but each pass of sharpening should be done on its own layer so you can erase any parts from that specific layer that become over sharpened after the action is completed. Expanding or contracting the selection between layers is to prevent a noticable "line" where the sharpened areas meet the non sharpened areas.
Hope that helps!
Kevin
Missed 4 chasing 1
RonS
Mon Jun 22, 2009 12:40 am
Yep, that's what I do. Create the Duplicate Layer, Expand by 1 pixel. Then do my Sharpening (in my case Smart Sharpen). Basically every time now I run the eraser around the edges and fuselage to erase any jaggies, even if I don't really see any. I just always do it as routing because I hate getting a jaggie rejection. In the rare case I need more sharpening, I create another Duplicate Layer and add a little more.
All opinions expressed by me are my own opinions & do not represent the opinions in any way of my employers.
JThompson
Mon Jun 22, 2009 6:28 am
Thank you everyone for the information and advice!
That makes it a lot clearer for me what the process is.
Jeff.
klemmi85
Mon Jun 22, 2009 7:47 am
One more thing...
If you don't want to worry about jagged edges, try this:
Open your original image,
duplicate Layer
apply highpass filter with 1-3px (depends on picture, just try)
set highpass layer to "soft light" within the blending modes.
To get a stronger result, just duplicate the highpass layer again until you are satisfied.
I do sharpening only that way as it doesn't come up with the jagged edges. Keep in mind that you can get halos at high contrast edges if your highpass pixel setting is to high. Depending on image size, anything more than 8-10px makes the result unusable.
If there are further questions, feel free to post.
quit a.net 07/2016
JThompson
Mon Jun 22, 2009 8:21 am
Thanks Klemmi85, that is a process I have not come across!.......much appreciated.
Jeff.
jid
Mon Jun 22, 2009 8:46 am
Hi Jeff.
A couple of ways to sharpen here
http://www.jid.me.uk/workflow/Workflow2/sharp.html
On a similar tone to some of the above.
Jid
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
JThompson
Tue Jun 23, 2009 8:46 am
Thanks for the link Jid!......that is an excellent Tutorial.
Jeff.
cpd
Sat Jun 27, 2009 7:33 am
If you use Nikon and have Capture NX2, try the high-pass sharpening method in Capture NX2. It works very well. See the circled part in my screenshot:
http://www.totalnfs.net/cpd/images/cnx_sharpening.jpg
To use it go to:
Adjust > Focus > High Pass
It will appear on the adjustments palette. Set the blending mode to overlay. When you export to Photoshop, you'll still have some scope to apply a bit extra sharpening once you've resized down to 1280px wide or whatever you are using if you need to, without making many jagged edges.
[Edited 2009-06-27 00:34:24]
JThompson
Sat Jun 27, 2009 10:47 pm
Thanks Cpd, but I'm actually using a Canon and its DPP and I don't think there are any similar setups like what you have shown there, but thanks a lot for the input, much appreciated!
Jeff.
dvincent
Sun Jun 28, 2009 1:42 am
Make sure to set the sharpening layer to luminance blend mode so you don't get color fringing when sharpening...
From the Mind of Minolta
JThompson
Sun Jun 28, 2009 11:03 pm
Thanks for the tip Dvincent!!
Jeff.
