wilco737
Photo Acceptance - Post- Screening Level(wilco737)
Fri Jun 26, 2009 8:18 am
Hello everybody,
this is rejected for level:
http://www.airliners.net/addphotos/rejections/big/20090626_b1245436963.1744img_5668_u.jpg
I played around in PS a bit and not sure how I could make it level or what take as reference as level.
Should I take the glareshield as reference? Then it looks like this (ignore the quality, I just rotated the already edited shot to see how it works):
Big version: Width: 1024 Height: 683 File size: 498kb
I am not sure, but somehow this doesn't look right as well. Maybe something in between? The angle makes it difficult for me to make it level so that it could get accepted.
Any feedback/ opinions/ help appreciated.
wilco737
 expressionless
JohnKrist
Crew
RE: Photo Acceptance - Post- Screening Level(wilco737)
Fri Jun 26, 2009 9:28 am
New edit is much more balanced IMO, first one looks awkward, I am involuntarily tilting my head.
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
dazbo5
Fri Jun 26, 2009 9:30 am
That looks better to me level wise. It's often tricky leveling those with the distortion cause by wide angle lenses. I normally use the horizontal on the top of the panel or the verticle on one of the displays in the centre of the frame. After that, it's just judgement as to what looks level. I think your main problem it quality, it's looks blurry so I don't think there's much you can do with this one. It's a great insight in the flight deck from the right seat though.
Darren
wilco737
Fri Jun 26, 2009 9:38 am
Quoting JohnKrist (Reply 1):
Quoting Dazbo5 (Reply 2):
Ok, thanks for the feedback. I'll take another try later today.
Maybe, maybe not. It was rejected for level only after being in screening for 13 hours. I don't know...  confused
wilco737
Stil
Fri Jun 26, 2009 9:45 am
Hi.
I think the second attempt is much better as well. If you stare to the second picture and then, return to the first one, you'll see the difference.
Stil
....... Gueropppa! ......
timdegroot
Fri Jun 26, 2009 10:45 am
Level on the centre verticals, which in the first shot are leaning heavily to the right
Tim
Alderman Exit
IL76
Fri Jun 26, 2009 11:27 am
A cockpit dashboard is tilted upwards a bit. Putting the instruments vertical doesn't make any sense to me. The first edit gives you the impression your actually sitting in the seat looking down at the dash, the second one look like you're looking at it from a beachchair. Maybe it can use a slight rotation CCW, but not that much as shown above.
wilco737
Fri Jun 26, 2009 11:31 am
Thanks everybody for the feedback.
Looks like I will not be able to get it 100% level. Tim said using the centre verticals as reference, but that doesn't look right to me as well. That's somehow not the way I see it when I am sitting in the seat.
Off to my personal collection.
Thanks again.
wilco737
Users browsing this forum: 727LOVER and 1 guest
