sovietjet
Photo Acceptance - Post-screening(sovietjet)
Sun Jul 05, 2009 12:04 pm
Another level rejection I do not understand. Can someone direct me as to why it isn't level?
http://www.airliners.net/addphotos/r.../20090705_v1246174816.87711744.jpg
I have done the levelling based on the horizontal piece in the middle but also the vertical line that's part of the control panel. Here I have attached an edit with a horizontal and vertical line added in and they both are straight.
Big version: Width: 1024 Height: 683 File size: 832kb
TransIsland
RE: Photo Acceptance - Post-screening(sovietjet)
Sun Jul 05, 2009 12:24 pm
needs CCW
filler, filler, filler, filler
I'm an aviation expert. I have Sky Juice for breakfast.
sovietjet
Mon Jul 06, 2009 4:13 am
Why? The red lines I drew seem to match the ones on the panel. Can you help me edit it correctly?
Quoting TransIsland (Reply 1):
needs CCW
aussie18
Crew
Mon Jul 06, 2009 8:16 am
Definately agree,does need some CCW rotation,Just look at the image and can see it seems to be leaning to the right abit.
sovietjet
Mon Jul 06, 2009 5:12 pm
OK I will try it again with some CCW.
What about this one? Rejected for level also, but there was nothing to level it against..this is the angle at which I overflew the base. There is no horizon.
http://www.airliners.net/procphotos/...=20090706_j1246259434.59791506.jpg
[Edited 2009-07-06 10:13:39]
TransIsland
Tue Jul 07, 2009 3:30 am
Quoting Sovietjet (Reply 4):
No, but there are buildings, and yours are all falling over. Needs plenty CCW.
gabik001
Tue Jul 07, 2009 4:12 am
I Agree with Translsland. Find one building and rotate to set this building vertically. If the building will be 0.1 - 0.2 deg. out of vertical axle (CW or CCW) that's OK , nobody can see that difference. Buildings are too small. Thats the only way you can get a level.
Regards , Gabriel
Canon 50D gripped + Canon 70D + 17-40 L + 24-105 L IS + 50 f/1.8 STM + 100-400L IS USM + Minolta X300 w/ 35-70 f/3.5
sovietjet
Tue Jul 07, 2009 5:08 pm
Thanks. I will try a different edit. The problem is that with too much CCW the frame of the window will become visible.
sovietjet
Wed Jul 08, 2009 6:22 pm
How about this one? Rejected only for motiv. What's wrong with the motiv? We can't upload double takeoffs?
http://www.airliners.net/addphotos/r.../20090705_l1246257630.55011038.jpg
TransIsland
Wed Jul 08, 2009 6:55 pm
Quoting Sovietjet (Reply 8):
Runway light blocking the wheel.
gabik001
Fri Jul 10, 2009 1:25 am
Yes , the light...
But Ivan , I know you are shooting series so you got another shot w/o light? Right?  Smile
If so upload another... BTW very good and interesting shot. However i have a shot thar the light was at the same place and blocks the shot. I removed it using PS...
TransIsland
Fri Jul 10, 2009 2:44 am
Quoting Gabik001 (Reply 10):
Which, if memory serves right, is not allowed on a.net.
gabik001
Fri Jul 10, 2009 6:49 pm
Yeah , but I never uploaded on any website. It's just my try with some stuff removal.
sovietjet
Sat Jul 11, 2009 7:18 am
Damn that light  Smile
I guess I will try it again with a different photo.
sovietjet
Thu Jul 23, 2009 9:58 am
Can somebody tell me why this was rejected for motiv?
http://www.airliners.net/addphotos/r...90720_n1247473458.7665img_1837.jpg
conoramoia
Thu Jul 23, 2009 10:33 am
My guess is that you either have to keep in the whole nose cone or lower down the flight deck windows,
Conor.
