Rimantas
Photo Acceptance - Post Screening
Tue Jul 21, 2009 5:11 pm
Hi,
I've got two photos rejected due to the different reasons. It's confusing because both of them have been shot with the same camera settings and the same lighting conditions (shot in the same direction within few minutes, so lighting conditions are identical). Image size and compression settings are the same as well.
Rejection reason of first photo: color soft
http://www.airliners.net/addphotos/r...n1247408894.3208rojunai09ec135.jpg
I don't understand what is wrong with color here - is it oversaturated or white balance adjustment is wrong ?
What must be sharpened to fix softness rejection?
Rejection reason of second photo: grainy compression
http://www.airliners.net/addphotos/r...719_t1247391046.9938rojunai09w.jpg
I don't find what areas should be corrected to fix grainy rejection - sky or aircraft surfaces ? Compression rejection is also confusing because compression settings are the same as in all recently uploaded my photos.
Your opinions will be appreciated.
Rimantas
JohnKrist
Crew
RE: Photo Acceptance - Post Screening
Tue Jul 21, 2009 5:56 pm
1st one has a greenish cast, and it's softness is apparent around the tail logo and the SC135
2nd one, jpeg compression or oversharp artefacts, most noticeable under the wings.
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
Rimantas
Tue Jul 21, 2009 7:20 pm
Thanks for your opinion, JohnKrist.
I think it is probably impossible to avoid impression of under wings oversharp artefacts in 2nd photo, because flaps and ailerons of this aircraft are made of corrugated metal.
Users browsing this forum: jdando and 1 guest
