MHO
Photo Acceptance - Pre-Screening (MHO)
Wed Jul 22, 2009 10:38 pm
I happened to have my camera as this C130 was doing some low passes over the runway at Davis-Montham AFB in Tucson AZ. I am experimenting with some exposures, speeds and zoom settings, trying to work out some issues I've had in earlier photos, and using some advice I've gotten here in the past. So, how are these?
Big version: Width: 1200 Height: 800 File size: 491kb
Big version: Width: 1080 Height: 720 File size: 406kb
It's better to be a little behind than a big ass
Luftfahrer
Wed Jul 22, 2009 11:16 pm
Both are blurry/soft, the second one also has some dust spots/other stains.
PWMRamper
Seems like a tighter crop on both would be in order.
MHO
RE: Photo Acceptance - Pre-Screening (MHO)
Wed Jul 22, 2009 11:35 pm
Worked with sharpening, cropped tighter, and used healing tool for the dust spots. Any better?
Big version: Width: 1058 Height: 705 File size: 428kb
Big version: Width: 869 Height: 579 File size: 294kb
Stackhouse007
Thu Jul 23, 2009 12:13 am
The second one seems blurry on the nose to me.. Im not sure maybe its the weird windows.
Nikon D60: 18-55mm - 55-200mm / Canon 50D: 100-400mm
acontador
Thu Jul 23, 2009 1:55 pm
Hi MHO,
Both are too blurry, no need to continue waisting your time trying to edit those for A.net. You need to start trying to detect blurriness in your pictures, which is different to softness. Blurry pictures very seldom can be edited into an acceptable quality, and in my case, I always delete them right away!
Just sit back, relax and have a glass of Merlot...enjoy your life!
MHO
Thu Jul 23, 2009 9:13 pm
Acontador,
Thanks for the criticism. Is it that the props are too blurry, or the nose also? I guess I should use a faster shutter speed. Here is one taken at 1/800 sec. It seems sharper, to my eyes, anyway.
Big version: Width: 1024 Height: 683 File size: 326kb
acontador
Fri Jul 24, 2009 12:13 am
Hi MHO,
It also looks blurry and veeeeery soft, and it has not to do with your shutterspeed - I usually shoot props with 1/100 sec or less. What is your lens-camera combo? Maybe it's rather your lens becoming very soft wide open/on the long end, what was the aperture on these shots?
Btw, the high sun in your pics doesn't help either, try to go out for shooting either early morning or late afternoon, and the sun will become your best friend instead of your worst enemy  Wink !
MHO
Fri Jul 24, 2009 1:21 am
Well, this was a target of opportunity, so the sun was out of my control. I am using a SONY alpha350 with a Sigma DG 70-300 zoom lens. The last photo was done at f/7.1, 1/800 shutter speed, and 210 mm.
I must admit it's getting a little frustrating. They look OK when I first examine the images, but after getting the comments and looking again, I see the softness, etc. Back into the field, I guess.
Thanks for your help.
michael
MHO
Wed Aug 05, 2009 12:06 am
OK, so it turns out I've been rather timid in sharpening, as I was afraid to over-sharpen. Here is a different picture, same airplane, with more aggressive sharpening:
Big version: Width: 1024 Height: 683 File size: 341kb
