snecma
Best Lens Option
Tue Jul 28, 2009 8:41 pm
Hi. What would give you the best quality? A Canon 100-400mm L IS USM lens or a combination of a Canon 70-200mm f2,8 L IS USM lens with a 2x Canon convertor?
Jacobus
JohnKrist
Head Support
Best Lens Option
Tue Jul 28, 2009 8:53 pm
100-400 for sure. A 70-200 and 2x converter performs like a poorly adjusted 100-400.
BUT, the 70-200 2.8L IS is one of the best lenses on the market, and I use it with a 1.4 extender and that works pretty well the little I have tried it since I got it.
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS II, 50mm 1.4, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
NicolasRubio
Best Lens Option
You will get much better results with the Canon EF 100-400mm f/4.5-5.6L IS than with the Canon EF 70-200mm f/2.8L IS + Canon 2x II TC. Not only sharpness-wise, but you will have an IS optimized for that FL and faster AF.
Well, I was beaten by 32 seconds :p
Oh, by the way... it is lens, not lense!
[Edited 2009-07-28 13:55:53]
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
Astro777lover
Best Lens Option
Tue Jul 28, 2009 9:41 pm
Quoting NicolasRubio (Reply 2):
I dont have either one myself but reading in other forums that the Canon 100-400 is a dust sucker (because push/pull action) so you might want to consider that. I heard gets on sensor but with a blower its easy to clean and the 70-200 IS L USM is a great lens but i doint know about the teleconverter. I would personally go with 70-200/2.8 L IS USM. All up to you and what/where your shooting.
Austin
cvervais
RE: Best Lens Option
Wed Jul 29, 2009 3:02 am
Are you shooting with a crop body or a full frame? On a full frame body the 100-400 has some moderate vignetting at 400mm. If you're using a crop body it's much less noticeable.
I have this lens and a full frame body and if the only background for the plane is sky the vignetting is quite obvious. It is a dust pump but, I've found if you don't push or pull harshly it's not really too much of a problem. A rocket-air usually takes care of anything that might get on the sensor. I've also found that if I adjust the zoom while in rapid fire mode the dust has more of a chance to get to the sensor. If I adjust while not doing exposures it seems to help with this issue as well.
Despite all this, you could not pull this lens from my cold dead hands. It's a very good lens for doing this sort of photography.
spencer
Wed Jul 29, 2009 9:35 pm
Quoting Cvervais (Reply 4):
Maybe so, yet it can be worked in the RAW suite very well.
Spence.
cvervais
Thu Jul 30, 2009 2:45 am
Quoting Spencer (Reply 5):
Spence.
The Canon RAW suite or Photoshop?
spencer
Thu Jul 30, 2009 2:01 pm
Quoting Cvervais (Reply 6):
Can't answer for the Canon product as I don't use it, (even though I use Canon eqpt.). I meant for PS/CS.
Spence.
cvervais
Fri Jul 31, 2009 4:21 am
Ah, thanks Spence, that's what I thought. I use photoshop elements 6 and the vignetting isn't available to me in camera RAW :-. And right now I can't justify $700 USD for CS4.
ghajdufi
Crew
Fri Jul 31, 2009 9:06 am
Hi, I have or had all the stuff you are asking about.
For my non-aviation work the 70-200 2.8 is unbeatable. The only drawback for aviation photography is that it's only 200mm. If you can get close to the action you'll be fine with it. This lens with the 2x extender is OK but not great. I have photos even here on a.net that were taken by this setup. If the light is great the images will turn out to be quite OK but still slightly on the soft side. The advantage is that you can remove the extender and have a fantastic lens up to 200mm.
I had the 100-400 for a few months, only used it for aviation. between 100 and 300 it was quite nice but by far not as good as the 70-200. Above 300mm I found the pictures too soft.
I had no problems with the dust at all.
G.
Your photos are like your children, you will always find them perfect.
michlis
Fri Jul 31, 2009 10:55 am
Quoting Astro777lover (Reply 3):
Or you could go with the non-IS version and save a few hundred dollars that you could put towards a 1.4x tele if you're going to be shooting in mostly daylight conditions.
If you know the enemy and know yourself, you need not fear the outcome of a hundred battles.
