Stackhouse007
Photo Acceptance - Post-Screening (Stackhouse007)
Thu Jul 30, 2009 3:21 am
Well this shot just got rejected for the following reason:
These photo(s) have blemishes on them. If the image is from a digital
single-lens reflex camera (DSLR), these blemishes may be dust spots ("dust
donuts"), which are often difficult to see. If the image is from a regular
digital camera, the blemishes are probably caused by dirt on the lens. If
the image is from a scanner, the blemishes may be dust, dirt or scratches.
http://www.airliners.net/procphotos/...29_y1248325766.0918coerjn13958.jpg
Please help me with this. I do not see any and I have no idea how to remove them.
Stackhouse007
Kyle
Nikon D60: 18-55mm - 55-200mm / Canon 50D: 100-400mm
dlowwa
RE: Photo Acceptance - Post-Screening (Stackhouse007)
Thu Jul 30, 2009 8:00 am
Sent you an email. It's above the 'C' in Continental. Just use the clone stamp to remove it. Next time you can use the 'equalize' function to check for dust spots.
Dana
Stackhouse007
Thu Jul 30, 2009 1:09 pm
Alright thanks. Will do that.
Kyle
Stackhouse007
Sun Aug 02, 2009 11:17 pm
Alright I tried that.. Is this all I needed to do? Or can you still see it?
http://i157.photobucket.com/albums/t76/Stackhouse007/COERJN13958b.jpg
That is my first time ever doing that so I have no idea if I did it right..
Kyle
dlowwa
Mon Aug 03, 2009 7:21 am
Quoting Stackhouse007 (Reply 3):
You've got the right idea, you've just got to be a little more subtle. It's ok to clone dust/blemishes out as long as it's not too obvious where you've done it. Try it again, and instead of cloning the cloud above the dust spot, clone the sky around it. It's a lot harder to tell you've cloned something if it's uniform like the sky. Clouds are tricky because you can usually see if you've obviously duplicated part of one.
Dana
Stackhouse007
Mon Aug 03, 2009 3:07 pm
Alright this is pretty hard.. lol. I tried it again but Im not sure if it looks good... Here it is.
http://i157.photobucket.com/albums/t76/Stackhouse007/COERJN13958c.jpg
Kyle
dlowwa
Mon Aug 03, 2009 8:47 pm
I'll put you out of your misery  Wink...
I just emailed you a touched-up version that should be fine.
Dana
RonS
Mon Aug 03, 2009 9:00 pm
I've played around for almost an hour on one tough dustspot one time. Practice helps
All opinions expressed by me are my own opinions & do not represent the opinions in any way of my employers.
