nwc100
Photo Acceptance - Pre Screening (nwc100)
Sat Aug 22, 2009 8:30 am
Hello, Wondering if you could take a look at these 2 for me and offer any help with them
http://www.airliners.net/addphotos/b.../z1250926644.507dagwm190809nwc.jpg
http://www.airliners.net/addphotos/b...1250926312.40769mxab2190809nwc.jpg
These two are in the queue but will pull them if general consensus is to do so!
Also I have a question about this picture....It still has its easy reg on it but obviously has new paint on it...so who's is it? easy or Aerolineas Argentinas and what does it go under in category's whilst uploading.
Big version: Width: 1024 Height: 683 File size: 389kb
And finally this one not in the queue but wondering if it might worth a re-edit and try later..
Big version: Width: 1024 Height: 683 File size: 424kb
Thanks very much as always for your advice and help.
Nick
Garyck
Crew
RE: Photo Acceptance - Pre Screening (nwc100)
Sat Aug 22, 2009 10:37 am
The German Wings look soft and sharp in places, I'd guess that the heat haze has got in the way, I also think the bottom of the fuselage is dark. Image taken early pm by any chance?
The Air Asia on my screen looks over sharpened.
According to Skyliner the 737 hasn't actually been delivered yet, so I'm not sure, Its in Aerolineas Argentinas so personally I'd go with that airline for as it is going there. The new reg has yet to be decided
http://www.skyliner-aviation.de/regdb.main?LC=nav4&page=3
The Etihad looks soft and dark on the underneath
Keep your Ladders close, but your camera closer
Sat Aug 22, 2009 12:32 pm
Germanwings - same thought. I don't think the quality's there.
Air Asia X - center - should be higher in the frame. You could also crop a bit tighter when you come to centering the plane a bit better. It also needs a little CCW rotation. I'm guessing it goes under AR rather than EZY as the plane is in the c/s of AR.
AR - could be brightened up a little more and a bit of contrast added when you brighten it.
EY- center, too low again and too far left - cropped too fine against the horizontal stabiliser. Jaggies on the horizontal stabiliser from oversharpening. Titles look rather soft/blurry and parts of it look overbrightened eg around the cockpit. You should try to get into a position where the sun is behind you and you won't have that problem with light.
bmibaby737
Sat Aug 22, 2009 1:28 pm
I believe the Boeing 737-700 should be uploaded as:
Aerolineas Argentinas (EasyJet Airline)
nwc100
Sat Aug 22, 2009 8:58 pm
Guys thanks for your help as always, I have pulled the two from the queue, I find it very hard to get the colours and sharpening to a good enough standard as I only have a laptop to work from, When I look on the computer I have at work the images often look quite different to the laptop, but my computer at work is a bit tin pot!! So I will add them into my.aviation and keep on persevering, Your notes about the time of day etc where spot on, sadly that is the way things are at my local airport!
And as 99.9% of flights from there are Ryanair and Easyjet to get 3 heavies in one afternoon is quite a treat!!!
Thanks again Nick
bmibaby737
Sun Aug 23, 2009 10:13 am
Nick,
Why not upload the original full sized, un-edited photograph of the 737-700 to somewhere - and one of us will have a go at editing it for you?
Try this website for advice on photography at Stansted:
http://www.adamrowden.co.uk/article-photography-at-london-stansted.asp
bmi.
nwc100
Mon Aug 24, 2009 9:48 am
bmi Thanks for the website is a long time since I had seen that..... I have been to all of the places on there but as usual security is the issue, The only place I dont get to much grief is where all the were taken!!
Here is the link to the unedited version Its been converted to jpeg and on photobox....is that ok...will be really intrested to see how someone gets on...
http://www.photobox.co.uk/my/photo?a...um_id=173084304&photo_id=242703955
Regards Nick
Users browsing this forum: 817Dreamliiner and 6 guests
