2H4
Photo Acceptance - Post Screening (2H4)
Fri Aug 28, 2009 2:31 pm
Well, these were all rejected for being soft. Not an uncommon rejection for me, but due to the rarity of these shots, I'd love to be able to fix them (if possible).
http://www.airliners.net/addphotos/rejections/big/20090827_e1250694216.4518trainyard8-17-2009064retouchedcropfinaljjm.jpg
http://www.airliners.net/addphotos/rejections/big/20090827_s1250693949.9827trainyard8-17-2009039retouchedcropfinaljjm2.jpg
http://www.airliners.net/addphotos/rejections/big/20090827_b1250715857.2314m1250693316.4527trainyard8-17-2009116retouchedcropfinaljjm3.jpg
I suspect they might be beyond repair, but welcome any tips or advice. Thanks in advance for any help.
2H4
Intentionally Left Blank
clickhappy
RE: Photo Acceptance - Post Screening (2H4)
Fri Aug 28, 2009 3:37 pm
They look almost OOF. What were the technical details of the shots?
2H4
Fri Aug 28, 2009 3:50 pm
Quoting Clickhappy (Reply 1):
First shot:
1/800
f7.1
200mm
Second shot:
1/1600
f5.6
200mm
Third shot:
1/1250
f5.6
105mm
All taken with a D50 and the Nikon 18-200 VR lens.
2H4
clickhappy
Fri Aug 28, 2009 4:41 pm
There is no need to shoot with a shutter speed so high, especially with marginal glass like the 18-200. You should be shooting in Aperture priority, with the Ap set to f/8. This will solve your constant 'soft' problem.
2H4
Fri Aug 28, 2009 4:49 pm
Quoting Clickhappy (Reply 3):
Good tip, thank you. I'm (obviously) still learning...
2H4
clickhappy
Fri Aug 28, 2009 5:02 pm
It is a common mistake - and one I learned the hard way (lots of poor shots).
MHO
Fri Aug 28, 2009 6:55 pm
I would suggest moving the f-stop to 8 or 9. That should give you more depth of field and help out with focus and soft spots.
Interesting photos - what's the story here?
It's better to be a little behind than a big ass
2H4
Sat Aug 29, 2009 12:01 am
Quoting MHO (Reply 6):
I found some fuselages on their way to final assembly at Renton.
2H4
cvervais
Sat Aug 29, 2009 5:07 am
Yeah, I also fell victim to the the higher the shutter speed the better mentality when I started. It seemed to make sense, the faster the shutter the less motion would affect the shot so it should be tack sharp right? Well, not so much.
I don't know if it's because the longer shutter speeds let more light in and therefore more detail but, when I slowed things down to 1/800 or below my images started coming alive.
Now, if I could just edit them worth a damn maybe I'd have more on here Big grin
ruudb
Sat Aug 29, 2009 7:46 am
I am not really sure if your problem will be solved by using f8, I have tried an 18-200 and it isn't the sharpest lens Nikon ever produced, especially loads of vignetting in the low end and sharpness is ok till 135mm, so using 200mm on this lens is one of the main causes I think.
You could have better opted for your 180mm lens  Wink
2H4
Mon Aug 31, 2009 2:51 pm
Quoting Ruudb (Reply 9):
Yes, I considered doing so, but I didn't think I'd be able to hold it steady enough. I didn't have my tripod and also wasn't able to use the ground, as I was standing among thorn bushes.  Smile
2H4
ruudb
Mon Aug 31, 2009 3:37 pm
I think the 180 at 2.8 is sharper as the 18-200 on 180 at 5.6 and as I see the shuttertimes you used it would have been not to difficult to do it without VR (kind of understatement  Big grin ).
2H4
Mon Aug 31, 2009 5:00 pm
Quoting Ruudb (Reply 11):
Well, I'll chalk this up to having learned the hard way.  ashamed
Thanks for the advice, though.
2H4
