EGTESkyGod
Photo Acceptance - Pre Screening (EGTESkyGod)
Sun Aug 30, 2009 5:12 pm
Third time lucky, with advised proper thread title, and ask for your advice on editing the following shots...
1) Red Arrows at EGTE. Levelled using wings and was told about a red colour cast...? I'm still fairly new to editing so what is colour casting and how can I improve the shot enough to stick it in the queue?
http://i268.photobucket.com/albums/jj8/EGTESkyGod/RedsExeter.jpg
2) Concorde at MAN... Told leading edge of wing was oversharpened...? Which wing?
http://i268.photobucket.com/albums/jj8/EGTESkyGod/AlphaCharlieMAN-1.jpg
3) BA 747 at SYD
http://i268.photobucket.com/albums/jj8/EGTESkyGod/BA747SYD.jpg
4) Qantas 747 at SYD
http://i268.photobucket.com/albums/jj8/EGTESkyGod/Qantas747Phillipine330.jpg
5) Trident at MAN
http://i268.photobucket.com/albums/jj8/EGTESkyGod/TridentManchester.jpg
6) BA 757 at MAN
http://i268.photobucket.com/albums/jj8/EGTESkyGod/BA757Manchester.jpg
7) Same BA 757 at MAN
http://i268.photobucket.com/albums/jj8/EGTESkyGod/BA757Manchesterside.jpg
Your help and advice on editing these shots to an acceptable standard would be greatly appreciated, and I hope the mods see fit to keep this thread live. Thank you.
[Edited 2009-08-30 10:15:20]
I came, I saw, I Concorde! www.gofundme.com/lineupandwait
dlowwa
RE: Photo Acceptance - Pre Screening (EGTESkyGod)
Sun Aug 30, 2009 5:38 pm
Quoting EGTESkyGod (Thread starter):
Yes, there seems to be a pretty severe color cast. See below for my partial attempt it from the right side.
http://img36.imageshack.us/img36/5130/redsexeter.jpg
As for level, I suggest using any horizontal/vertical lines in the background. In this case, they would suggest you need a little CW rotation (especially the verticals). You can always just leave it as is and see what the screeners think (but fix the color).
Both.. especially the right wing. Jaggies visible along the nose too.
3) BA 747 at SYD
Pretty strong color cast again, and the quality's not really there either (looks like due to heat haze/ jpeg compression)
Soft/Blurry, color, quality is lacking in this one too.
5) Trident at MAN
Best of the lot quality-wise, just needs a little brightening, and seems to suffer from compression too, but that could just be how you're saving it/uploading it. Motive probably is ok, but can't say for sure.
6) 7 7)BA 757 at MAN
Also better with the quality, but the lighting conditions make for hard work in the editing. If it were me, I'd go with the first one. There are a few things that need fixing up (color, CA, etc..), and it looks like it's suffering from some compression again, but it's probably fixable.
It seems that the case with your earlier shots is that they were taken with a camera that unfortunately wasn't up to the task. I see that you switched to a K10D recently, and that the quality of your shots correspondingly went up. Nearly all of my shots on a.net were taken with a K10D, so the camera is certainly capable enough. If you need help editing, let me know, as I've obviously had plenty of experience working with your camera. If you have the original files (raw/.pef/.dng preferable) I'd be happy to take a look and help you through the process.
Dana
EGTESkyGod
Sun Aug 30, 2009 6:04 pm
Quoting Dlowwa (Reply 1):
Not quite... I borrowed my Dad's for the day at Manchester. Last week I bought a Canon 500D so will be using that in future, just using some old shots to practice editing. The earlier shots you mentioned (No's 1, 3 and 4) were taken with a bog standard Konica Minolta Dimage Z6 and is probably the reason for the lower quality.
I have to admit, of the ones above I'd most like to see No 5 uploaded (front on shot of 757)...
New try... http://i268.photobucket.com/albums/jj8/EGTESkyGod/BA757Manchester2.jpg
And hows this now for the Reds? http://i268.photobucket.com/albums/jj8/EGTESkyGod/RedsExeter-1.jpg
[Edited 2009-08-30 11:22:18]
airkas1
Crew
Sun Aug 30, 2009 7:25 pm
Hiya,
Quoting EGTESkyGod (Reply 2):
Are you sure you didn't accidentally post the picture you showed in your first post? they look very much alike, but in any case there is still a huge red color cast.
Airliners.net Crew - Head Photo Screener
EGTESkyGod
Sun Aug 30, 2009 7:48 pm
Quoting AirKas1 (Reply 3):
Ah... quite right, what a dipstick I am... here you go...
http://i268.photobucket.com/albums/jj8/EGTESkyGod/RedsExeter-2.jpg
conoramoia
Sun Aug 30, 2009 7:53 pm
Quoting EGTESkyGod (Reply 4):
No...sorry...it's still there.
What are you doing in photoshop?
Conor
EGTESkyGod
Sun Aug 30, 2009 7:55 pm
Quoting Conoramoia (Reply 5):
I just played a bit with the levels, both as a whole and then just the red... messed around a little bit until I came up with the above... what do you think I should do?
conoramoia
Sun Aug 30, 2009 8:02 pm
Set a black point on the wheels and as stupid as it may sound I'd set a white point on the line on the nose.
I don't think levels will do the trick...You can add more blue which should neutralise it...but you should work it and compare to dlowwa's edit if your not sure.
Conor
airkas1
Crew
Sun Aug 30, 2009 10:19 pm
I just tried to fix your color cast in PS, but it didn't work. If you had a RAW file it might be possible to fix it, but otherwise I don't think this particluar photo can be salvaged.
cvervais
Mon Aug 31, 2009 1:16 am
Charlie,
Regarding your colour casts, have you calibrated your display lately? If it's not properly calibrated you might not see a colour case but, when those of us with calibrated displays looks at it there's a very clear colour cast.
Here are some links that might help you:
http://www.google.com/search?client=...splay+calibrator&ie=UTF-8&oe=UTF-8
dlowwa
Mon Aug 31, 2009 1:19 am
Quoting AirKas1 (Reply 8):
I'd have to agree. It'll be pretty difficult to fix with just the Jpeg.
The BA 757 looks better, but still has a few issues, most notably the color is still off.
Dana
EGTESkyGod
Mon Aug 31, 2009 9:06 am
Quoting Dlowwa (Reply 10):
That's fine, no worries... like I say, I am just playing around and editing what photos I do have before going and using my new camera to get the better photos. I guess what I'm really asking is "How's my editing?"
I don't really mind if the Red Arrows doesn't make it to be honest... but the 757 at MAN...
OK, how can I improve the colours? And with a bit of play, do you think I could potentially get this picture uploaded?
Thank you all for your advice, I appreciate it and will even more so if I can add to my solitary picture in the database!
Charlie.
PS, Yes my monitor is calibrated, I just clearly didnt take enough of the colour cast away!  Wink
dlowwa
Mon Aug 31, 2009 9:21 am
Quoting EGTESkyGod (Reply 11):
Don't worry too much about colours... when I first started uploading last year, I had a horrible time with colour casts with my first dozen or so shots. Once you get an eye for it, it gets easier. You'll just need to play around with them and compare your shots to others... no easy/instant fix really...
The only way I could give you a more definite answer would be to see the original, and as myself and others have mentioned, a RAW file would be preferable. You can contact me through my profile if you want to send me the original, and I'll have a look and see if it's worth trying to come up with a better edit.
Dana
Psych
Mon Aug 31, 2009 9:53 am
Charlie.
My feeling is that the BA 757 head on shot is a pretty good edit overall - the problem you have, as I mentioned in the other thread - is the direction of the lighting. You just have too much contrast in this photo, because of the backlighting, and I think that means the screeners will not be satisfied come what may. Backlighting is not necessarily an automatic rejection, but it has to add to the photo somehow. In this example of a common aircraft on the database, it simply presents too many issues - very dark shadows in too big areas and highlights that are almost burned out on the fuselage.
Now your Trident tail is very nicely exposed and the lighting is right for you there - I think you should easily be able to get that one accepted. If you want any help just ask. The difference in quality in the photos above due to the different cameras is really evident - not your fault.
Cheers.
Paul
P.S. The Concorde problems is the wing on the left as we look - notable jaggies - easily resolved. Also I agree something went badly worng with your Reds photo and it has had it, I am afraid. The colour temperature/white balance is wrong in the original.
EGTESkyGod
Mon Aug 31, 2009 10:25 am
Quoting Psych (Reply 13):
Thank you.  Smile
Based on this, (and the original I will post below) is it still worth tinkering with in an effort to please the mods?
Quoting Dlowwa (Reply 12):
Original Image... http://i268.photobucket.com/albums/jj8/EGTESkyGod/IMGP2052.jpg
I thought the Trident tail was the best, but I think there are already quite a few tail shots in the database and didn't want it to be rejected for that reason.
Easily resolved? If I start again with the edit and don't sharpen the nose and wings so much, this would make it in?
EGTESkyGod
Mon Aug 31, 2009 4:46 pm
Wish me luck... have included the Trident in the upload queue...
http://www.airliners.net/addphotos/b...51736891.1547tridentmanchester.jpg
Also have found some more pics from MAN with the Sun behind me... here's the first I've found.
http://i268.photobucket.com/albums/jj8/EGTESkyGod/ThomasCookManchester.jpg
[Edited 2009-08-31 10:07:03]
Psych
Mon Aug 31, 2009 5:06 pm
Charlie.
I have re-read my post and should have added a few key words - I think the Trident is a good shot with a little reworking of the edit. The lighting is excellent, but I think it can look even better if you address a few elements of oversharpening (jaggies where the blue of the tail meets the white of the fuselage and also the top of the engine cowling) and slight softness in other areas (frustrating I know, but there it is - e.g. the lettering of 'Trident Three'). The red of the tail logo looks slightly oversaturated, and I would be interested to see if this is in the original or due to editing. At the square on angle that you have taken the image, I would also be tempted to crop it closer, beyond the registration, but that is a personal thing.
I would be happy to do an edit for you from the original if you wish.
Paul
EGTESkyGod
Mon Aug 31, 2009 5:17 pm
Quoting Psych (Reply 16):
Paul... Have sent you my email address.  Smile
dlowwa
Mon Aug 31, 2009 5:32 pm
Quoting EGTESkyGod (Reply 14):
Original Image...
... I don't think that's the original image... from the K10, the file should be 3800+ pix across... this is a re-sized version, no? And I assume that means you don't have a RAW version... the reason I asked for the RAW version (file ending in .pef or .dng) is that it's a lot easier to fix color/exposure problems.
There aren't many free hosting sites that will host a full-size image, so if you do want me to take a look you'll have to contact me and send it by email.
Dana
EGTESkyGod
Mon Aug 31, 2009 5:36 pm
Quoting Dlowwa (Reply 18):
In that case if you PM me your email, I'll send you the original... No I don't have it in RAW format, just JPG I'm afraid. I have adjusted my new camera to use RAW so when I get chance to use it, hopefully the results will be clearer for all to see.
dlowwa
Mon Aug 31, 2009 7:46 pm
The Thomas Cook looks much better than the BA, though it still needs the contrast and colour adjusted slightly, and is a bit soft. Should be relatively easy to fix with editing.
Got your mail with the BA 757 btw, and I'll have a go at editing it when I get home, although doesn't look too promising (the colour/lighting/etc...) at this point.
Dana
EGTESkyGod
Mon Aug 31, 2009 7:51 pm
Quoting Dlowwa (Reply 20):
Ideal! I will get on with it now and see what I can come up with.
OK no worries... Thank you so much for looking for me. Just email me back when you've had a play.
Edit... after having had a play with the Thomas Cook 757, hows this?
http://i268.photobucket.com/albums/jj8/EGTESkyGod/ThomasCookManchester-1.jpg
[Edited 2009-08-31 13:20:12]
dlowwa
Tue Sep 01, 2009 8:02 am
Quoting EGTESkyGod (Reply 21):
...no, going in the wrong direction. Now too dark. still has a bit of a yellow cast too, and some jaggies in some areas.
Needs a bit of work, but I still think it should be salvageable. You can send me that full-size too if you want.
Dana
EGTESkyGod
Wed Sep 02, 2009 8:39 pm
Quoting Dlowwa (Reply 22):
Sorry, had a couple of days away... Have had another play, attempted to smooth the leading edge of the fin, have hopefully got rid of the yellow cast and have played with the contrast and brightness a bit. How's this? I need to keep practising my editing, I know, but eventually I'll get it right, I promise!!!
http://i268.photobucket.com/albums/jj8/EGTESkyGod/ThomasCookManchester-2.jpg
whisperjet
Crew
Wed Sep 02, 2009 9:40 pm
Not too far off, apply a tad more sharpness, contrast and noise reduction.
Stefan
Nobody is perfect - not even a perfect fool.
EGTESkyGod
Wed Sep 02, 2009 9:47 pm
Quoting Whisperjet (Reply 24):
Thank you, Whisperjet... Sharpness to which bits, and how do I go about noise reduction? How's this?
http://i268.photobucket.com/albums/jj8/EGTESkyGod/ThomasCookManchester-3.jpg
[Edited 2009-09-02 15:09:05]
whisperjet
Crew
Wed Sep 02, 2009 10:30 pm
Looks quite ok for me, there are some jaggies visible, so be more careful with sharpening.
For the noise reduction you'll have to get a special software. Google for Neat Image or Noise Ninja and download a trial version.
Stefan
[Edited 2009-09-02 15:33:01]
EGTESkyGod
Thu Sep 03, 2009 12:46 pm
Quoting Whisperjet (Reply 26):
Roger and Wilco...
I went to play with my new camera this morning for the first time with planes... How's this for a good old Flybe Dash 8 on the morning run from EXT to MAN?
http://i268.photobucket.com/albums/jj8/EGTESkyGod/FlybeQ400DKEXT.jpg
