wilco737
Questions About Double Rule?
Thu Sep 03, 2009 9:45 am
Hello fellow photographers,
question about the double rule... This rule is sometimes difficult Big grin
I was approaching SEA airport last week and I took some pictures while we were on downwind and some picture while we were on final to 34C.
Will that be a double? I mean the motiv is different, but the same day, same airport?
Another question. If I have a nice cockpit shot from SEA departure at daylight and later an approach shot of LAX at night, but on the same flight, is that a double as well? Same day, same aircraft, but different airport?
Thanks for the help...  Smile
wilco737
oly720man
RE: Questions About Double Rule?
Thu Sep 03, 2009 9:59 am
Quoting WILCO737 (Thread starter):
From the rules....
We only accept multiple cockpit shots if:
They clearly show different parts of the cockpit.
When the outside view is showing a different airport.
When one is taken in daylight and one taken at night.
So probably double for this one
But the SEA/LAX day/night.... depends on which bit of the cockpit in each by the looks of it.
aussie18
Crew
Thu Sep 03, 2009 10:00 am
Should be fine,pretty sure 2 inflight window view/cabin/cockpit shots can be accepted from same flight long as there is a noticable difference in the view/scenery and being 2 different airports that should be fine.
Probably better to post examples of the shots,Are they cockpit shots or showing overviews of the airport itself which are quite similar but taken from different angle/altitude?
Cheers Mark.
wilco737
Thu Sep 03, 2009 10:06 am
Quoting Aussie18 (Reply 2):
Ok, thanks. Sounds good. Looks like the one to LAX is too blurry anyway because of complete darkness.
Being on downwind like here, but in SEA:
Photo © George Canciani
And the other one like this, but again in SEA:
Photo © Wilco737
wilco737
Jalap
Fri Sep 04, 2009 8:04 am
This rule often is difficult indeed. In the rejection guide there is a mix of very hard parameters (like "2 window shots per flight") and soft parameters (like "if motive is sufficiently different"). Also, some hard parameters have a soft one attached to it while other hard ones don't.
e.g.: 2 window shots if motive sufficiently different. BUT 2 shots from same side of aircraft only acceptible if one during take off and other during landing (but what about taxiing or during ground handling?). No exception in the rules about different motive there even though in certain circumstances a dramatically different motive would be possible.
This makes uploading shots with a certain risk for double rejection a bit of a coinflip for us. And I guess also causes trouble and discussions for the screeners. I'm sure that a certain set can be rejected for double the one day while it would get through the other day.
I realise that the double rule is very much needed but you can't exaggerate with hard parameters here, since that would cause rejections on shots that are very much worth being in the database. But the current situation creates a bit too much uncertainty for the photographers. Considering that often real doubles are in the database (same shot by different photographers) I would argue that some more slack should be given to us when motive is sufficiently different. Increasing weight of motive and reducing weight of the hard parameters I think would make the double rule easier for interpretation and would do good to the variety in the database.
just my  twocents
jan
wilco737
Fri Sep 04, 2009 8:48 am
Quoting Jalap (Reply 4):
I wasn't questioning the double rule although I had double rejections which really annoyed me. I have a full frame shot of an MD11F and then a head on shot, I mean standing on a truck, being head on with the nose section of the MD11F and looking at her face to face. It is a double because I have the full fram shot already accepted... The motiv was something out of the ordinary but it is double. I mean how often do you stand at the height of the cockpit window of an MD11F? I only once... But this will be a shot which will never make it to the database due to the double rule...  Sad
This are the ones which I got accepted:
Photo © Wilco737
Photo © Wilco737
And this is the shot wihich got double:
Big version: Width: 682 Height: 1024 File size: 520kb
That's why I asked for the one here now in SEA to avoid such a double rejection.
Thanks.
wilco737
ThierryD
Crew
Fri Sep 04, 2009 9:41 am
Quoting WILCO737 (Reply 5):
Hey, the copilot is missing! Now where would he be...?? Big grin
Thierry
"Go ahead...make my day"
wilco737
Fri Sep 04, 2009 9:43 am
Quoting ThierryD (Reply 6):
Sorry, don't know... He must be gone or in the galley Big grin
wilco737
Moose135
Fri Sep 04, 2009 7:38 pm
Looking for a ladder to clean the windscreen?  Big grin
Those are all great shots, Wilco! Sorry that last one isn't in the DB...
wilco737
Fri Sep 04, 2009 7:42 pm
Quoting Moose135 (Reply 8):
Exactly Big grin
Many thanks. I appreciate that. Maybe in a couple of years when the double rule has changed Big grin
wilco737
