Silver1SWA
Crew
Pre-Screening - Question About Crop (Silver1SWA)
Sun Oct 25, 2009 7:09 pm
Hi,
Previously, I have always tried to include the entire aircraft in every photo. I have no experience with motivated crops that exclude portions of aircraft, so I'm not sure how to tell if "it works" or not.
I see similar crops/motives in the DB, but usually of much larger aircraft. I don't know if the size and shape of the 737 doesn't fit well. Does it look unbalanced or awkward? Or does it work? This is pretty much full-frame with the exception of some trimmed off after levelling so I can only crop tighter. Thoughts?
http://www.airliners.net/ufview.file...=536884036&filename=phpJ3P1Dr.jpeg
Thank you,
Ryan
RonS
RE: Pre-Screening - Question About Crop (Silver1SWA)
Sun Oct 25, 2009 7:33 pm
I like it, but I'm interested in seeing the right wing cropped off too, so the crop is closer to the nose. It might be more balanced that way, not sure. I would be interested in comparing. Real sharp shot. Love the background and overall lighting. I don't think this SHOULD be a problem, but you never know...
All opinions expressed by me are my own opinions & do not represent the opinions in any way of my employers.
waketurbulence
Sun Oct 25, 2009 7:36 pm
Great looking shot. I do know what you mean about the crop, it does feel a little unbalanced to me as well. It also seems a little low in the frame for my taste. Personally I would like to see what it looks like tightly cropped to the nose. The light is great and the effect of the captain holding on would be accentuated if you were to crop further. My  twocents
-Matt
alevik
Crew
Sun Oct 25, 2009 7:43 pm
I think you can either way on this angle. Whether you leave the left wingtip in or crop closer to the nose, I don't think you'd get a motive rejection for a poor crop.
It is a bit low as Matt noted.
Improvise, adapt, overcome.
Silver1SWA
Crew
Sun Oct 25, 2009 9:04 pm
Thanks for the replies. I did two more edits, the first one includes the wing and I raised the sunject in the frame as much as I could. There isn't much room to play with and this is as low as I can go with the crop.
http://www.airliners.net/ufview.file...=536884036&filename=phpvHhw5f.jpeg
The second one is a crop closer to the nose. Personally I prefer to include the wing, but maybe this just looks more balanced?
http://www.airliners.net/ufview.file...=536884036&filename=phpSi7BC5.jpeg
Thanks again for your help.
Ryan
FX772LRF
Sun Oct 25, 2009 9:12 pm
Quoting Silver1SWA (Reply 4):
It seems that the crop with the winglet has less grain/no grain on the underbody.
-Noah  wave
Cleared to IAH via CLL 076 radial/BAZBL/RIICE3, up to 3k, 7k in 10, departure on 134.3, squawk 4676, Colgan 9581.
conoramoia
Sun Oct 25, 2009 9:13 pm
IMO definitely the closer cropped one but still seems a litlle low in the frame.
Stunning pic!
Conor
Silver1SWA
Crew
Mon Oct 26, 2009 7:25 pm
Again, thanks to everyone for the comments. I'm still not sure which one I want to upload. I like the first one but maybe the tighter crop is safer.
whisperjet
Crew
Mon Oct 26, 2009 9:05 pm
I like the 2nd one better. Both could do well with some careful noise reduction.
Stefan  Smile
Nobody is perfect - not even a perfect fool.
