spompert
Pre-screening-soft (spompert)
Sun Oct 25, 2009 10:33 pm
I had a photo rejected for being soft.
http://www.airliners.net/addphotos/r...g/20091022_i1255809702.4305dhl.jpg
Now I have sharpened it more. What do you think, is it better? I have uploaded it again and hope it will pass.
http://www.airliners.net/addphotos/big/ready/t1256416630.8649dhl.jpg
Stefan
dlowwa
RE: Pre-screening-soft (spompert)
Sun Oct 25, 2009 11:51 pm
Quoting Spompert (Thread starter):
Quality is not better unfortunately, as the sharpening you have applied is easy to see in the jaggies that are now appearing all over. You can see them in the red cheat lines, the gear, the leading edge of the wing, etc...
You're going to have to do a better job at selective sharpening, i.e. sharpening only the areas that need it, and not the areas where it will show up most obviously.
I don't think there's much point in keeping your new version in the queue.
Dana
spompert
Mon Oct 26, 2009 4:19 pm
Thanks for your feedback. It is only that I don't really see these jaggies. Do you think the first one hasn't them? And wich parts need sharpening? Do you think there is a posibility that I can fix the first photo anyway?
Stefan
dlowwa
Mon Oct 26, 2009 5:25 pm
Quoting Spompert (Reply 2):
Really? Look at the three red lines that run along the fuselage. Notice how they are not smooth, but rather look like blocks linked together? Those are jaggies. Look at the wheels, notice how they are not round and smooth, but also have a very block-like appearance? Those are jaggies. Notice how the letters 'DHL' do not have a fine border, but are also very blocky? Those are jaggies. Basically all over the place.
It's not looking very good now, but without seeing the original, I can't say if it's because the original is of low quality (i.e. not possible to fix) or because of your editing (possible to fix).
Dana
spompert
Mon Oct 26, 2009 6:05 pm
Thank you. I have some trouble seeing the jaggies on all the parts you say they are. I am not used to look at photos that close. This was the original how I took it. I only cropped it and resized it to 1200x800.
http://i215.photobucket.com/albums/cc41/pompie79/original.jpg
Are there any jaggies in this one already? For me the quality was pretty good but I can understand for more experienced photographers it can be different. Please let me know if it is fixable. Any advice is welcom, thanks.
Stefan
dlowwa
Mon Oct 26, 2009 7:12 pm
Quoting Spompert (Reply 4):
if you want to get some photos accepted here, you'd better get used to it!
By original I meant before re-sizing. That way we can see where the sharpness problem is - with the original or your edits.
This one has fewer jaggies than before, but it is soft. The problem is sharpening the proper areas enough that they look good, but not the areas where that sharpening will be obvious, like the red lines and gear mentioned before. It's a fine balance, and will take some time to master. The quality of your shot is ok, but it may be too soft for here. We will need to see the original (before re-sizing) to know for sure.
spompert
Mon Oct 26, 2009 9:29 pm
Here is the original.
http://i215.photobucket.com/albums/cc41/pompie79/IMG_1570.jpg
I have to admit it is not that sharp but I tought that when you resize it you won't notice this so much. But can this be the problem for the softness? Or do I have to sharpen some parts first and then resize it? Thanks Stefan
dlowwa
Mon Oct 26, 2009 9:46 pm
Quoting Spompert (Reply 6):
Actually, that's not bad, so the problem is with your editing. Did you re-size at all? You use a 40D, so the dimensions should be 3888 x 2592, but this photo is only 2031 x 1354. You either cropped already or re-sized it. If you cropped it, that's part of the problem, as you've had to crop a lot off the full-frame. It might be possible to edit this to acceptable standards, but that will depend on your skills (yes some sharpening will be required). If you have re-sized it, start with the full (3888pix) version.
spompert
Wed Oct 28, 2009 12:54 pm
Finnaly I achieved in placing the original photo on a photosharings site. Here you can see the original. Please give some advice. Is this photo fixable? Stefan
http://www.mijnalbum.nl/GroteFoto-RTHLVJHJ.jpg
conoramoia
Wed Oct 28, 2009 3:56 pm
I did a bit of an edit,
I taught this 1024 pix picture looked slightly better for light and contrast.
http://img340.imageshack.us/img340/4536/grotefotorthlvjhj.jpg
Conor
jmrebes
Wed Oct 28, 2009 4:16 pm
Good job, Conor ! But I can see some grain now in the plane's belly, on the right. It isn't?
Jose
Jose M. Rebes
dlowwa
Wed Oct 28, 2009 4:53 pm
Quoting Spompert (Reply 8):
Yes, your original should be of good enough quality, I just think you need to work on your editing. Be careful with the sharpening, and make sure you get rid of the colour cast (red) that is present. You should be able to get it accepted with a good edit.
spompert
Wed Oct 28, 2009 7:46 pm
Quoting Conoramoia (Reply 9):
Thanks a lot, but is this photo not a bit soft as well? I still find it hard to see when a photo is good and when not.
Quoting Dlowwa (Reply 11):
Thanks, it is good te hear that I made a photo that can be accepted after editing. I'll try it again.
Users browsing this forum: No registered users and 21 guests
