bmibaby737
Let's Talk About Manual
Tue Nov 24, 2009 12:24 pm
So I have a Nikon D80 that I shoot with, normally (unless shooting propeller aircraft) I use aperture priority F/8 which seems to be the norm around here. However, I've started noticing that my shutter speed becomes quite high... to a point where it really doesn't feel like it needs to be.
A clear winter's day, the sun is shining, there is no haze, and the aircraft are steadily coming in to land. I get results ranging from ISO 100 F8 1/1000s to ISO 200 F8 1/750s
So, my question is; should I be considering manual for aviation photography? What sort of settings can I use to get to grips with manual? Is there any difference in quality if the settings are correct vs. aperture priority?
An example here, ISO 200 F8 1.750s
Photo © JRC
bmi
Stealthz
RE: Let's Talk About Manual
Tue Nov 24, 2009 12:54 pm
Quoting BmiBaby737 (Thread starter):
Until you understand metering you can't get to grips with manual.
How were you planning to meter your exposure?
Theoretically no... but that depends on your skill at metering and exposure setting V the accuracy of your camera
JeffM
Absolutely. Your images will be far more consistent. You said it, the light isn't changing, so why is your camera changing things on every shot? You can chimp like a fool to get the settings you want to dial in manually, or, you can get a meter, press a button and be done with it.
NIKV69
Tue Nov 24, 2009 1:04 pm
I switched to shooting mostly Manual couple of years ago and love it. Sure you have to go through a ton of trial and error with the exposure but once you get an idea what spots and what sun it's not that hard. I think the results are much better. I mean if you are sitting at a spot with good light and 10 B6 320s go by for you to test shoot you can't get the right settings by the time a heavy you want comes by?
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
Stealthz
Tue Nov 24, 2009 1:14 pm
Quoting JeffM (Reply 2):
When I first saw this thread I wondered if I should respond or just wait for JeffM to chime in... knew it wouldn't take long.
What he and Nik says is true, once you come to grips with manual shooting(and Jeff is correct in his continual evangelizing of incident metering) the consistency will amaze you.
[Edited 2009-11-24 05:32:22]
unattendedbag
Tue Nov 24, 2009 1:21 pm
I might suggest turning "ISO auto" off.
Slower traffic, keep right
dvincent
Tue Nov 24, 2009 1:46 pm
I would consider using the auto exposure lock feature on your camera once you've metered something you like. This should help you get a feel while still having the metering system around. You will naturally want to meter slightly differently on some planes to keep highlights from blowing out, and you can still use your exposure compensation on the locked value.
From the Mind of Minolta
Trackcharlie
Tue Nov 24, 2009 2:39 pm
Does also depend what metering mode you camera is set to. I personally have got better results using Aperture Priority, as the light may (or may not) be fairly consistent but some liveries bounce more light than others making it hard to quickly choose a shutter speed. American vs United for example. I'm quite happy for the cameras sophisticated systems to decide for me, coupled with any exposure compensation. Plus I shoot RAW so I can tweak exposures after the event at home. Another point for me is that my LCD can look dark on a bright day leading me to overexpose a little.
No I don't believe so. Same lens and sensor. What you dial in might have been selected by the camera anyway. If you feel your shutter speed is too high use the lowest ISO your camera has, this will drop it some.
Maybe I've been photographing at the wrong times, but at f/8 I dont ever remember being concerned about my shutter speed being too high!
TC.
clickhappy
Tue Nov 24, 2009 4:13 pm
Quoting Trackcharlie (Reply 7):
Just to clarify, "Metering Modes" are Zone, Spot, and Center-Weighted (might be called different names on different camera brands).
JakTrax
Tue Nov 24, 2009 4:55 pm
Quoting Clickhappy (Reply 8):
Canons generally have four - evaluative, partial, centre-weighted and spot. At least my 30D does anyway.....
I started with Av (aperture priority), then turned to manual and have now come full-circle back to Av. Why? The consistency I'm getting with Av is very good, with far less hassle. Idle? Yes. Happy with it? Yes.
Manual won't get better results but will perhaps be more precise; but as someone already mentioned if you shoot in RAW it's often pretty irrelevant.
Having used the same camera/lens for nearly three years now I'm quite capable of knowing exactly how to use it in Av mode, without the need for incident metres or grey cards. A combination or metering modes and stop compensation is all that's needed. Having said that, I'd definitely have a go at manual - I certainly enjoyed it (until I got too lazy!).
At the end of the day, if you're getting the results YOU want (i.e. for many good enough to upload here) there's no need to change settings. If it ain't broke, yadda-yadda-yadda.....
I switched to manual because little things weren't quite right. I've now learned exactly how to iron out those 'little things' in Av mode.
On a final note, once in a while I'll pull off a shot I think would've been better taken in manual - but after a little tweak in RAW converter........
Karl
cpd
Tue Nov 24, 2009 9:56 pm
This I can assist with.
Use the highlights/shadows display, and the RGB histogram view to determine the right exposure. Start with F8 or F9 as a baseline, and work out the exposure from there. The highlights/shadows display will show you any detail that is blown out by exposure not being correct, and the histogram is an added benefit.
Also, try using pre-set white-balance (WB), this will also allow you to get much more consistency. In sunny conditions, the WB should be cooler, around the 4550-4700K range. In cloudy conditions, it should be warmer, around the 4900-5200K range.
The Nikon D80 might be older, but it is still an excellent camera and will get you great results if you use it right.
[Edited 2009-11-24 14:09:41 by cpd]
Users browsing this forum: No registered users and 9 guests
GZIP: Off
