Astro777lover
Tripod Heads: 3 Way Or Ball?
Fri Nov 27, 2009 5:35 pm
I am going to get a manfrotto tripod soon and I want to get a good head for some money.
I am looking at the 3 way pan head and a ball head. Would do you guys think would be the best choice? I've read good things about both so i am not sure what to do.
-Austin
Speedbird2025
RE: Tripod Heads: 3 Way Or Ball?
Fri Nov 27, 2009 6:21 pm
Hi Austin..
I personally prefer a three way pan head.. Makes it very easy to make quick adjustments.
Not too sure what city in FL you are in, but my advice is go to a good camera store and mess around with the different tripod heads. You will know what is comfortable for you.
I know in Houston we have a few camera stores that have most of the good tripod heads on display.
--Nate
Astro777lover
Fri Nov 27, 2009 8:22 pm
Quoting Speedbird2025 (Reply 1):
Yea we used to have a camera store right here in the mall but it closed down so the closest one is like a 30 minute drive. I have a slik tripod now with a 2 way pan head but it was like 30 dollars so i have an idea what it is like. I probobly will go to a camera store soon cause i really want to get one soon.
Austin
P.S. I live right outside of orlando
JRadier
Fri Nov 27, 2009 8:25 pm
Quoting Astro777lover (Thread starter):
The first question is what are you going to do with it (what kind of shots)?
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
Astro777lover
Fri Nov 27, 2009 8:44 pm
Quoting JRadier (Reply 3):
Pretty much everything, aviation, night photos, landscape, wildlife, macro.
bertoli
Fri Nov 27, 2009 9:23 pm
Hi,
It depends on what you're planning to do. Ball heads are less bulky and quicker to set up than pan & tilt heads , but are less precise on adjustments. If you need precision adjustments (like adjust precisely a horizon on a photo) , pan & tilt is the right one for you. If you look for a compact head and quicker to adjust, go for a ball head.
I personally have chosen a 484RC2 for my setup and I'm very satisfied with that.
Cheers.
JRadier
Fri Nov 27, 2009 9:52 pm
Quoting Astro777lover (Reply 4):
that's a tough one....
I got all 3, ballhead (mainly for on the monopod or quick-action shots), a 3-way (not really used anymore) and a geared 3-way which absolutely rocks for aviation night shots as you can be extremely precise in adjusting the head.
Astro777lover
Sat Nov 28, 2009 2:16 am
Quoting JRadier (Reply 6):
Yea i heard the geared head is great for macro and like you said night shots, well i heard they were also expensive.
Quoting Bertoli (Reply 5):
I will probably go with the 3 way pan head for now and if i save more money i can get a ball head to have both.
cpd
Sat Nov 28, 2009 2:40 am
3 way is the better bet for aviation photography, due to the precision with which you can set up the head for things like panning.
I have Manfrotto 055XPROB and 808RC4 combination.
Astro777lover
Sat Nov 28, 2009 3:17 am
I was thinking of this combination:
Manfrotto 055XWNB + Manfrotto 804RC2 (3 way pan)
hias
Tue Dec 01, 2009 12:39 pm
Quoting Cpd (Reply 8):
I have to agree to Cpd. I have almost the same tripod (055 PROB) with the same head and its just great for night shots, especially with heavy weight lenses.
Mathias
[Edited 2009-12-01 04:40:50 by hias]
dvincent
Tue Dec 01, 2009 1:42 pm
Keep in mind that a good ball head with a pan axis lock (like the 488RC2) will give you a single pan adjustment when you need it and be overall faster to use because to adjust a ballhead you just need one control to adjust. Three way heads are better for video, IME.
From the Mind of Minolta
whisperjet
Crew
Tue Dec 01, 2009 4:43 pm
Quoting Dvincent (Reply 11):
Good point! I mainly take nightshots of planes right after pushback which makes a very short time frame of ~ 90 seconds. The faster I have the head adjusted the more shots I can take.
I don't think precision is very important for aviation photography.
Stefan
Nobody is perfect - not even a perfect fool.
Astro777lover
Wed Dec 02, 2009 12:48 am
I think i will get the 3 way pan because i have used it before and am used to it, and if i ever find a camera shop near me i can go in and try a ball head or find someone that has one i could try out.
Austin
