sandromederle
Imperial Hill At LAX With 300mm Enough?
Wed Dec 16, 2009 6:08 pm
hi guys,
i will be in LA at the beginning of February next year and was wondering if 300mm on a full frame body is a good focal length for spotting at LAX's Imperial Hill?
Are there any objects in the way that limit photography to a certain angle only? Any input for spotting from said point would be nice!
Sandro
sandromederle
clickhappy
RE: Imperial Hill At LAX With 300mm Enough?
Wed Dec 16, 2009 6:17 pm
300mm full frame will be a little on the short side for all but the big heavies (747, A346).
INNflight
Wed Dec 16, 2009 6:49 pm
2nd that Sandro, 300mm on a FF camera will have you miss quite a bit of stuff. For smaller acft (320s, 737s, 757s) you'd need about 500mm on a FF, 400 will do fine if you can use a 1.3 or 1.6 crop cam.
Drop Jorge Chavez & Paul Paulsen a line if you're going, brilliant guys and take one or two OKish photos too  Wink
Jet Visuals
ake0404ar
Wed Dec 16, 2009 7:15 pm
Quoting Clickhappy (Reply 1):
Then there is Samy's where you can rent a 600mm f4.
http://www.samys.com/common/pdf_files/2009_rental.pdf
Just for 150 bucks (a day or the w/e) you will be "king of the hill"
V.
[Edited 2009-12-16 11:16:25]
