rol
Lens Advice Needed For Nikon D 90
Thu Dec 31, 2009 12:31 pm
Fellow photographers,
I'm considering to buy a new lens for my D 90, which should be a notch above my lens which I have since 2001: Sigma 70-300 1:4-5,6 D APO Macro Super (at that time about 250-300 %u20AC). But the quality is too low to achieve a reasonable standard for this database now.
So I'm veering between:
Nikkor AF-S DX 18-200mm 1:3,5-5,6 G ED VR II (850-900 Euro) or
Nikkor AF-S VR 70-300mm/4-5,6 G IF ED (550 Euro)
or yet a Sigma lens? Perhaps
Sigma 4,5-5,6 120-400 OS APO HSM? (750 Euro) or the new one
Sigma 4-5,6/70-300 DG OS (400 Euro)?
The price could be in a range between 500 and 900 Euro.
Thanks for any advice and comments.
Roland
dazbo5
RE: Lens Advice Needed For Nikon D 90
Thu Dec 31, 2009 1:01 pm
Roland,
You need to consider the focal lengths you use most of the time, that will aid in assessing the best lens for you. You've listed a pretty wide range of focal langths there from 18mm - 400mm!! If you want something that wide, the 50-500 will be ideal (I use one) but if most of your shots are taken at say 100-200, then a 70-200 might be best.
Darren
rol
Thu Dec 31, 2009 2:10 pm
Okay, I make it more precise:
How is the quality of the Nikkor AF-S VR 70-300/4-5,6 G IF ED compared with the Sigma 70-300?
Roland
dlowwa
Thu Dec 31, 2009 5:51 pm
Quoting Rol (Reply 2):
You can check these links. The Nikkor got a pretty good review, although it gets a little weaker at the very long-end (300mm)
Nikkor AF-S 70-300mm f/4.5-5.6 G IF-ED VR - Review / Lab Test Report
The same site has a review of the Sigma (albeit on a Canon body).
Sigma AF 70-300mm f/4-5.6 APO DG macro - Review / Test Report
If you don't mind the price difference between the two, then it would seem the Nikkor would be the better bet.
Dana
ruudb
Thu Dec 31, 2009 7:49 pm
I don't know about the quality of the Sigma, but the Nikkor 70-300 is a great lens considering the price, it is true it becomes softer at the high end but it is the same for nearly all zoom lenses. The Nikkor 18-200 isn't worth considering in my opinion, it is not the sharpest lens Nikkor made in it's history.
rol
Fri Jan 01, 2010 3:45 pm
Thank you for the responses. If a screener says, the Nikkor is a grest lens, I will most likely take this one. And thanks for the review links.
Rol
kanepjk
Fri Jan 01, 2010 7:15 pm
Rol,
I've got a D90 as well. I use the Sigma 70-200 f2.8 and add the 1.4 tele extender when I need a little more range. I have been very happy with that combination on the D90. I've considered moving up to the Sigma 100-300 f4 but haven't convinced myself yet.
Pat
Users browsing this forum: Borut, solro, vikkyvik and 1 guest
