SAA738
Canon 100-400mm Problems
Tue Apr 20, 2010 1:50 pm
Hello there !
I've been having problems over the past few days with my Canon 100-400mm. Like today when I went to my local airport and took some shots of three arriving aircraft (A319, B734 and a B732). They were all taken at around 250mm. For some reason my Canon 400D wasn't focusing correctly. I used the following settings in what were almost perfect conditions, usually I get good results from them.
Camera settings :
Av mode.
F8.
ISO 100.
Metering mode : Evaluative metering.
White balance : Auto.
AF mode : AI SERVO.
Drive mode : Continuous shooting.
AF point selection : Manual (centre).
Lens settings :
Stabilizer : On.
Stabilizer mode : 2.
1.8m or 6.5m : 6.5m.
AF or MF : AF.
Here's an example of the best shot, please click it for the 1024x version :
http://i879.photobucket.com/albums/ab359/SAA738/015.jpg
As you can see the contrast is low and the image is blurry/out of focus and even slightly grainy.
I am in no way new to Aviation Photography, but I haven't had the 100-400mm IS long, I used to use a very old 100-300mm lens (non IS).
I also shoot in JPEG, should I maybe try RAW ?
Any help would be greatly appreciated. I'm going to the Control Tower tomorrow so I would really like to get it fixed by then.
Thanks in advance
Daniel P Fretwell
''To fly as fast as thought you must begin by knowing that you have already arrived'' - Richard Bach
Martas
RE: Canon 100-400mm Problems
Tue Apr 20, 2010 2:28 pm
Hi,
from the 1024px picture you posted above is impossible to tell if there is something wrong with your lense. As resized original it seems to be quite normal. Try to link a full size photo or 1:1 crop.
Best regards, Martin.
sovietjet
Tue Apr 20, 2010 2:30 pm
Maybe try posting the original size of the photo. From what you posted it looks fine. I had some much more serious focusing problems with this lens earlier this year. Even though the red light blinks it would generally not be focused. Here's an example of how bad it was. It doesn't look like yours is that bad.
http://xs.to/image-A7B4_4B7B548D.jpg
I sent it to Canon service center and they fixed it.
SAA738
Tue Apr 20, 2010 3:21 pm
Quoting sovietjet (Reply 2):
Here's a full version of one taken from the Control Tower on my last visit, even at 220mm the quality is poor. Some how dust had gotten into the camera, could this be one of the reasons ? As for the lens, that shouldn't have any dust in/on it.
http://img249.imageshack.us/img249/6500/038jj.jpg
Compare it with this good quality one taken at a full 400mm two months ago :
Photo © Daniel P Fretwell
I know the 732/Adv and A319 shots don't look as bad as your AA example, but the quality is still not good enough. And the red light did blink, but it didn't focus properly.
My lens has a European Guarantee but I live in Port Elizabeth, South Africa. Do you know how much it would cost to get it fixed in this Country (that's if it does need fixing) ?
dazbo5
Tue Apr 20, 2010 4:10 pm
What were the shutter speeds on those shots Daniel?
Darren
SAA738
Tue Apr 20, 2010 5:23 pm
Quoting dazbo5 (Reply 4):
Darren
Hello Darren !
Today (with exposure bias at 0) :
A319 : 1/640
B734 : 1/500
B732 : 1/1250
And from the other day (with exposure bias at -1/3) :
B732 : 1/640
dazbo5
Tue Apr 20, 2010 7:04 pm
That rules out any camera shake / motion blur then.
Darren
NIKV69
Tue Apr 20, 2010 9:35 pm
Clean your sensor! Jesus.
You all have ignored the fact that the shot in reply 3 is shot in perfect lighting and the shot in the original thread starter looks like it's taken at midday in the worst possible light and looks like it has a little heat distortion. Before we condemn the lens let's get some good test shots. Get out at sunrise and get some captures at F8, with no Ex comp and put your WB on direct sunlight. I would also get outo of auto mode and pick your own shutter. Hold it steady and when the sun becomes just right 1/500th or 1/640th should work to get perfect exposure and we can go from there. How can you get good contrast on a white fuselage when it's blown out?
The Juice is loose and he is in Vegas!
Silver1SWA
Wed Apr 21, 2010 12:01 am
Quoting SAA738 (Reply 3):
http://img249.imageshack.us/img249/6...j.jpg
You know, I have expressed my disappointment with the lens here a few times and I can say that both of your examples are nothing I haven't seen before. They are actually typical from my copy. However, I can get a perfectly sharp photo as well. I can take a series of shots of the same plane landing or departing and in that series, half might appear similar to your examples and the other half...well maybe one or two...will be keepers. Because of that, I just figured it was an issue with technique and just learned to live with it. But I dunno.
Quoting SAA738 (Reply 5):
Darren
Hello Darren !
A319 : 1/640
B734 : 1/500
B732 : 1/1250
With my lens, I have found some of the worst results coming from images taken at really fast shutter speeds. I can't figure it out...
Some things to consider though. Atmospheric conditions...was it warm and hazy? IS...try shooting without IS to see if that it causing the problem. I have read a lot about the IS system going bad.
Quoting NIKV69 (Reply 7):
Nick, remember last year when I met you and Dave in LAS to try out my new 100-400? The examples here look very similar to my images that day.
I can understand the conditions playing a huge role in color and contrast, but sharpness I dunno. I have seen razor sharp images taken with the 100-400 in all kinds of conditions.
cvervais
Wed Apr 21, 2010 1:22 am
Here are some 1600pix shots from my 100-400 so, it's not a design flaw with the lens or anything but, something could be wrong with your copy......
Photo © Chris Vervais
It's the only lens I've used since I started this hobby. When I first started though I was getting similar results to yours. What I was doing wrong though was I was gripping the lens near or on the focus ring. Since this lens is a full time manual focus lens just tracking the plane was causing me to bump the focus ring enough to put the image out of focus.
It took me awhile to figure this out since I could not explain why with shutter speeds of 1/1200 I was getting any kind of blur. How I figured it out was watching how Ben Wang held his 100-400 when I ran into him at SJC once. I noticed he was holding his lens really close to the end of the lens and then it dawned on me. Once I adjusted my grip I got MUCH sharper images.
Something to think about. If this is not your issue though then I highly recommend sending in the lens to Canon to get serviced.
sovietjet
Wed Apr 21, 2010 1:39 am
Quoting Silver1SWA (Reply 8):
I have found out it is not a good idea to be at the extreme of any setting on the 100-400 in particular. For example it is a well known fact that the 100-400 is soft at f5.6. I tend to avoid that aperture unless it's really getting dark. On the other hand shooting at f20 will not get you impressive results either. Someone posted a thread several months ago on the effects of diffraction at high apertures. I also have noticed that excessively large shutter speeds yield poor results. If someone can explain this I'd be glad to hear it. My lens was not focusing right at all and the MD-80 shot I posted shows this. As a comparison here's how sharp it should be. I am posting an MD-80 shot with the lens when it was about half a year old before I had the focusing problem (which is now fixed).
Before: http://xs.to/image-87FF_4B7B548D.jpg
After: http://xs.to/image-A7B4_4B7B548D.jpg
Another example
Before: http://xs.to/image-AEB7_4B7B5F06.jpg
After: http://xs.to/image-C680_4B7B5F06.jpg
Although I don't think yours is as bad you can try sending it to the nearest Canon service center for repair. It cost about $300 to get mine fixed
cpd
Wed Apr 21, 2010 9:25 am
This looks like heat distortion, rather than a lens issue. Can you try more photos in later afternoon light that is less severe?
But looking at Sovietjet's examples - it reminds me how good the really high end (and very expensive) lenses are. I can use settings like F/18 or F/22 with no problem. It does show up dust badly, but otherwise, the results are still sharp. I have to do that sometimes as I have no practical way to stack filters (and otherwise reduce the shutter speed).
The difference between the mega-zoom lenses and others that are less extreme I guess.
Quoting sovietjet (Reply 10):
Heat haze or pollution perhaps? I've seen it sometimes with my equipment (mostly top-end stuff, see signature), and that's about all I can suggest. Because other times, the results are superb - especially at 1/2500sec (which I use at very long distances).
dlednicer
Editor
Wed Apr 21, 2010 3:04 pm
Quoting cvervais (Reply 9):
I noticed the same thing with mine. Now, I try and remember to support it by the base of the lens hood.
Please clarify - I remember that it was Royal (Clickhappy) who made the post and he said that the 100-400L was sharpest at f5.6!
clickhappy
Wed Apr 21, 2010 4:34 pm
I've never shot with a Canon 100-400, I think that was someone stating that in a thread I participated in.
Photozone.de is a good resource, but I would have a hard time believing that a large zoom would be sharpest wide open.
dlednicer
Editor
Thu Apr 22, 2010 12:32 am
Quoting clickhappy (Reply 13):
I found it - it was in the thread Diffraction: F/8 Vs. F/22 (by Clickhappy Dec 4 2009 in Aviation Photography)
Royal said (and I remembered the f-stop incorrectly):
Most lenses achieve uniform sharpness (center and corners) at f/8. Take for instance the popular Canon 100-400 - it achieves it's sharpest results at f/8.
RCoulter
Thu Apr 22, 2010 1:36 am
FWIW, my 1D MKII N/100-400L combo gets the best results around f/9-f/10 YMMV though
Bruce
Thu Apr 22, 2010 2:36 am
I have had focus issues with my 100-400 also. In fact, in 2009 it was so bad that I sent it to Canon. I shot an air show out west and got very few focused shots. Got the lens back for Airventure and it was a little better, but I'm still not completely convinced.
From the date code on mine, I figured it was manufactured in 2000. I bought it in 2005. Maybe mine isn't a perfect copy? It seemed to be sharper I think, back in 2005, but by last year it had drifted a bit.
I wonder if Nikkor lenses have these issues?
Bruce
cpd
Thu Apr 22, 2010 2:58 am
Quoting bruce (Reply 16):
None of mine have. All have been good. Even the cheap 18-135 Zoom-Nikkor (a kit lens) has been very sharp, all the time, even at F/5.6.
sulman
Thu Apr 22, 2010 8:11 am
I think you're just falling foul of the conditions on that particular day. I've seen this before with my 70-200 F4. Hard, overhead sun, poor atmospheric conditions (including haze) and the lens struggles to resolve much detail. You get an effect not unlike very mild camera shake; i.e degraded contrast & resolution. No single frame quite looks right.
I'd try another couple of sessions and see what results you get.
James
ArturJarosz
Thu Apr 22, 2010 10:09 am
Hi All,
I use 100-400/L IS as a back-up lens.
It's obvious that you cannot compare that lens to the prime but you can get really nice results when shooting af f/8.0-f/9.0. As RCoulter said I also get the best results at f/9.0. I like the versatility that this lens adds to my backpack.
Regards.
Artur
cvervais
Sat Apr 24, 2010 3:56 am
I should add that the shots I posted were both shot at F/9, in fact I always shoot at F/9 during the day.
