vishaljo
Super-Tele For A Dusty Environment :-s
Thu Apr 22, 2010 3:11 pm
People calling the 100-400 as dust-pump    scares me as there's plenty of dust everywhere here in BOM.
Would a conventional twist-zoom be better than a push-pull due to the reason mentioned above or am i just overcautious ?
Here are the 2 lenses i'm looking at Sigma 50-500 OS vs Canon 100-400 IS
I've used the 100-400 a few times & while the push-pull takes a little getting used to, its not at all a problem for me.
The quality is nice indeed, not as good as some of the f2.8 glass i've used but fine nevertheless.
I've never used a Sigma before.
Their legendary reputation when it comes to getting the right lens first-up is also a bit troubling as i would be ordering it with a friend or relative of mine from the US.
Next concern with the Sigma is the AF & the short shelf-life Matte Finish which would make me look like a photographer from Iraq or Afghanistan within a few months if i bought it that is.
Only reason of me considering the 50-500 OS is because of its beginning focal length of 50mm which is ideal for my primary spotting location (which right now is a No-Go Zone to put it mildly) but besides, 50mm is just a handy length to start with !
I would value your opinions on this subject
[Edited 2010-04-22 08:13:02]
[Edited 2010-04-22 08:17:45]
dazbo5
RE: Super-Tele For A Dusty Environment :-s
Thu Apr 22, 2010 4:17 pm
Given the large extension of the 50-500, it's as much as a 'dust pump' as the 100-400. I've been using the 50-500 for 5 years how and had it cleaned internally when it went back to Sigma for a focussing problem after 2.5 years. It has some dust inside again, but it's not really a problem. What concerns you about the AF? It's as quick as anything I've used and pretty accurate.
Darren
p2philip
Thu Apr 22, 2010 6:58 pm
Hello,
I owned the 50-500 and I was able to get some good photos with it. However, it lacks AF speed, sharpness at 500mm and vignetting was quite obvious. I used the non-OS version.
I never regret the decision to switch to Canons 100-400, quality is overall better. The only thing I sometimes miss is the possibility to use 50mm. Also I do not have problems with dust at least not more than with other lenses.
@Darren: the 100-400 is often refered to as 'dust pump' because of the push-and-pull mechanism is said to suck dust into it, not because if the extension.
-Philip
TupolevTu154
Thu Apr 22, 2010 7:23 pm
I don't know about anybody else but twisting the Sigma 50-500 is practically impossible if you want to go from 50-500 in one movement. I have the 80-400 and don't bother using the zoom ring, I just push and pull the lens hood and it does the job so much easier than rotating it. The amount of air that i can feel being expelled out of it when zooming out quickly is probably more than the 100-400!
The AF on my 80-400 is also extremely frustrating at times and needless to say I have lost many decent photographs because of it's irritating habit of focus hunting at extremely inappropriate moments.
I wish Canon still made the 35-350mm L , now THAT would be the perfect all rounder!
vishaljo
Thu Apr 22, 2010 8:16 pm
Quoting dazbo5 (Reply 1):
This
Quoting TupolevTu154 (Reply 3):
And
Quoting p2philip (Reply 2):
Thankfully you reside in the UK.
I agree with you Tom.
I have a fine wide-to-midrange lens in the EF 28-105mm f/3.5-4.5 II USM,
therefore my dream lens is the Sigma 120-300mm f/2.8 EX DG APO HSM
[Edited 2010-04-22 13:25:48]
TupolevTu154
Thu Apr 22, 2010 8:19 pm
Consistency is clearly Sigma's strong point
MHO
Thu Apr 22, 2010 9:22 pm
Interesting - Did yours make a grinding noise and refuse to autofucus? I have a Sigma 70-300 with that problem, and it's just over 1 year old.
How was Sigma about repairing it - costly or reasonable?
Thanks.
It's better to be a little behind than a big ass
dvincent
Thu Apr 22, 2010 9:28 pm
The focus speed on the 50-500 is serviceable. It's not blazing fast, but most of the time it'll get the job done.
Where it falls down is if it has to rack from infinity to minimum. A focus limiter would help this lens out a lot, and it is a feature you get on the Canon 100-400.
From the Mind of Minolta
cpd
Thu Apr 22, 2010 10:39 pm
Lacks AF speed? Mine was very fast. Mine was the non OS version as well (the classic Bigma). I didn't notice any dust problems with it.
But Vignetting was a huge problem at 400mm or above, and the image quality overall was pretty soft. Sigma repairs (mine was done in Japan) are quite good, the result coming back looked and otherwise worked like a brand new lens (hence why I got 80% of the value back after nearly 2 years of moderate use).
[Edited 2010-04-22 15:39:57]
dazbo5
Fri Apr 23, 2010 9:45 am
What I meant was the amount of air the lens displaces when you zoom in and out is pretty much equivelent as the push pull mechanism of the 100-400. In that way, in my experience, they are both on par with each other. When you zoom with the 50-500, it draws air in, it's not sealed. I used my 50-500 in Kenya last year that's a very dusty environment when you've pointing it toward a herd of elephants and driving through the wilderness. I had no problems when taking a common sense approach.
That is not my expeirience with the 50-500. Of course it's not the sharpest of lenses at 500mm, it's a super-zoom with a 10x ratio so you can't expect it to be. However between 50 and 400mm, it's pretty good and still very usable at 500mm (I've plenty of examples on the database). I can't say I've noticed too much vignetting, certainly not enough to cause problems. If all you want is a good (not exceptional) versitile lens, you can't go wrong with the 50-500. For me, the 100-400 is too long at the short end.
I'd have one tomorrow! I tried to get one second hand before getting the 50-500, but they were like rocking horse droppings at the time.
Quoting mho (Reply 6):
No, it didn't make a grinding noise at all. It was a problem of not focussing between 200-300mm. Longer and shorter than that, it was fine. Sigma said it was a problem with the auto focus motor and said it needed replacing. It was about £70 all together, including the cleaning. A few months later, it did it again so I sent it back and they diagnosed the same problem, with the same quote. I pointed out it had already had that repair carried out so they did it under warrantee the second time. It still does it every now and then, but only in colder weather. It's fine when the lens is warm and in summer
vishaljo (Reply 4):
This
I can't say I've ever had that problem on the 50-500. I'ts not perfect by any means, but I can't remember the last time it hunted, other than when I was using it in the dark or when the contrast was so low, I bet any lens would have struggled.
Darren
p2philip
Fri Apr 23, 2010 1:29 pm
Right, maybe I put that the wrong way. It lacks AF speed compared to all Canon lenses I used. Overall AF speed was OK, but nothing special at all.
dazbo5
Fri Apr 23, 2010 2:46 pm
Quoting p2philip (Reply 10):
In my experience, it's much faster than the lower end Canon lenses, eg 75-300 IS USM, and on par with some of the higher end USM Canon lenses. I would say the 24-105 L is marginally quicker, but it's certainly no slouch and perfectly adequate for use with aviation photography.
Both these were taken at 500mm for example:
Photo © Darren Wilson
And these panning at relatively close distance (they are moving pretty fast!) and the AF copes just fine:
It's ultimately personal preferenance and comes down to your budget, the focal lengths required and your overall needs.
Darren
[Edited 2010-04-23 07:52:17]
p2philip
Fri Apr 23, 2010 4:11 pm
Darren, yeah you are right of course it is adequate for aviation photography, I never put that in doubt. Still, I was not that impressed. I could also plug some of my shots taken with it at 500mm but the majority of shots taken at this focal lenght were clearly not A.net quality. So if I had to decide between Canons 100-400 and the Bigma, the choice would be an easy one. The other two examples of yours are not really hard to shoot, these could have been taken with many other cheaper lenses as well. We also seem to have different definitions of 'panning'. The Piper photo above is more of a panning shot than the two airliners below in my opinion...
vishaljo
Sun Apr 25, 2010 11:49 pm
Quoting cpd (Reply 8):
Chris couldn't that be because you're a Full-Framer ?
Quoting dazbo5 (Reply 9):
+1
That's EXACTLY why i'm pushed to look at an alternate
What i gather from all the responses yet is, there's a very mixed opinion about the Bigma whereas General Unanimity about the L.
There's a Canadian Gentleman who's put-up my Dream Lens on sale at FM for $1750/- i'd pick it up in a heartbeat but for the price
Yes it starts at 120mm but its such a different animal altogether, imagine putting a 1.4x on it & yet have an incredible 168-420mm at f4
I wouldn't mind using my mid-range lens to cover everything uptill 105~120mm & then change lenses IF if was getting it for a low price, although i think $1750/- seems extremely reasonable for whats on offer.
Just that i desperately need money for other important purposes & therefore cant buy the f2.8, not yet atleast.
Which brings me back to 4x vs 10x
cpd
Mon Apr 26, 2010 3:37 am
Quoting vishaljo (Reply 13):
No, that was back on the old D80. I never paired the 50-500 with the D700, so I have no idea how they work.
Users browsing this forum: KPDX and 12 guests
GZIP: Off
