Ilovebelugas
Tamron 55-200 Mm Lens?
Tue Apr 27, 2010 6:44 pm
I'm still pondering about lenses guys! I am able to buy, nearly new, a tamron 55-200 lens for 70 pounds. Is this a good lens for aviation, or shall I save up another 100 quid and get the canon 55-250? ie- for the price is it worth it, or are there some major flaws in it? thanks
ANITIX87
RE: Tamron 55-200 Mm Lens?
Tue Apr 27, 2010 7:53 pm
What camera are you using? How much is the Canon 55-250? You may want to save up even a little more and get the cheapest Canon 70-300 or Sigma 70-300.
TIS
Ilovebelugas
Tue Apr 27, 2010 8:11 pm
i'm using a canon 450d. the canon is around 180 pounds, canon 70-300 (is) is around 400 pounds- so it speaks for itself really. the 70-300 is obviously a better lens, but perhaps I could try and get a 70-300 non IS- although reviews say that the 55-250 is better than that. what i really want to know is the competition between the 55-250 (canon) and the 55-200 (tamron). I know that the canon has IS, and the tamron has a macro feature, but how do they both perform in comparison to each other? in terms of aviation photograhy and other uses as well?
ANITIX87
Wed Apr 28, 2010 1:29 am
I'm not at all familiar with the Tamron line of lenses, sorry.
If you DO go with Canon, the 70-300 non-IS (don't forget there is also a 75-300 series of lenses for a bit cheaper!) is definitely light enough that you can use it easily without the stabilization.
TIS
dvincent
Wed Apr 28, 2010 1:32 am
The 55-200 is actually a fine little lens, provided you won't miss IS and don't mind a lot of plastic in the construction. The optical quality actually seems quite good from what I can see.
From the Mind of Minolta
