pilotalltheway
Nikon D90 Vs Canon 500D
Mon May 10, 2010 5:15 pm
Heya guys.
Just wanted to hear what you guys with the cameras have to say and I would like to find out which is best for all round perfromances like Filming and most obviously, modelling, nah, joking, of course photography!
Cheers folks!
-Alf
Dude - where's my plane?
JakTrax
RE: Nikon D90 Vs Canon 500D
Mon May 10, 2010 5:55 pm
The D90 is in a higher class than the 500D but whether it's better or not I don't know. Both have had very good reviews so I'd suggest trying them out in a shop to see which best suits your style.
This C vs. N argument is always null in my opinion as both manufacturers make excellent (and equal) cameras. Either or and I'm sure you'd be happy.
Karl
757MDE
Mon May 10, 2010 6:13 pm
I agree with Karl.
If it helps you though, I am a happy D90 user.
[Edited 2010-05-10 11:14:59]
Quisiera volveraamartevolveraquerertevolveratenertecerrrrcaademígirl! Mis ojos lloran porrr ti...
pilotalltheway
Mon May 10, 2010 7:23 pm
Hi,
Ok, great, so I'm sure I won't be disappointed with either! Which camera has the best/ widest range of excellent lenses available? I assume Canon with their L lenses....
-Alf
Silver1SWA
Crew
Mon May 10, 2010 7:56 pm
A buddy of mine has a D90 and it's impressive. Sometimes I tell myself if I had to start over, I would go with the D90. And I'm a Canon guy.
JakTrax
Mon May 10, 2010 8:05 pm
I'm of the opinion that Nikon build slightly better bodies, however Canon's lens line-up is second to none. It's a matter of personal preference as opposed to one being superior to the other.
Perhaps unfair to compare the D90 to the 500D however as they are not in the same market sector. A fairer comparison would probably be D90/50D.
Karl
pilotalltheway
Mon May 10, 2010 8:22 pm
Quoting JakTrax (Reply 5):
Karl
Hmmm.... I would say the Canon 550D....
Anyway, looks like the Canon 500D is the way to go!
-Alf
JakTrax
Mon May 10, 2010 9:42 pm
The 550D is essentially a 500D replacement and although spec-wise it's superior to the D90 the D90 is still in a class above. As the 40D did with the 50 the 500 will sit next to its better sibling until Canon pull it. Try comparing the speed of the D90 or 50D to that of a 500 or 550D - you'll soon notice the difference.
Karl
pilotalltheway
Tue May 11, 2010 4:13 pm
Okay. But, money doesn't grow on trees so I'd say the Canon 500D is my best choice....
-Alf
JakTrax
Tue May 11, 2010 5:09 pm
The Canon may be your best choice irrespective of money. The D90 may be in a class above but that doesn't necessarily mean it's better overall. There are many very happy EOS 500D users here.
Don't forget also that what lens you attach is equally (if not more) important than the camera itself; and Canon certainly can't be knocked for their lens selection.
Most importantly, image quality is ultimately down to how good the photographer is. Equipment can only ever be as good as its operator.
Karl
Silver1SWA
Crew
Tue May 11, 2010 5:27 pm
Two things I like better about the D90 versus my Canon 40D are the D90s ability to produce some very vibrant and colorful images out of the camera and the D90's amazingly clean images, even at high ISOs. It's a sweet camera and in my opinion (keep in mind I'm a Canon shooter), if you are starting out fresh and you are choosing from the cameras mentioned in your post, if you can afford it, get the D90.. But if you are already a Canon or Nikon DSLR shooter, stick with your current brand since you probably already have compatible lenses.
JakTrax
Tue May 11, 2010 5:46 pm
I have said that I feel the D90 is probably the better camera but can we bear lenses in mind here as they're pretty important too? Clean and punchy images are perhaps more to do with good glass than the camera body, and getting similar images with a Canon would simply require a few of the parameters changing. Images straight from the camera are judged by personal preference so what one person likes may displease others. I'm not trying to put anyone off the Nikon but fact is we have to make sure any advice is fair and impartial.
I will say again - ultimately one is not better than the other. This whole C vs. N thing is not only pointless but carries absolutely no weight. The 'better' one is whichever feels right in your hands; whichever has the most comfortable menu system; and whichever delivers the type of default images you want. Additionally, your budget is also a factor. More often than not recommendations here are pretty conmfusing and if anything will lead to a rushed and ill-informed decision.
Having said that, I'm sure you'd be happy whichever you chose.
Karl
pilotalltheway
Tue May 11, 2010 6:50 pm
Many thanks guys.
I think I'll go for the Canon 500D!
-Alfie
Silver1SWA
Crew
Tue May 11, 2010 7:31 pm
Quoting JakTrax (Reply 11):
Karl, the points I made were judgements on the bodies. If Canon lenses were far superior to Nikon's then I would agree with you. But it's not like Nikon doesn't make quality glass. I'm often just as impressed with photographs taken by Nikons as I am with Canons. In addition, third party lenses can also produce mind-blowing results.
I believe the only lens argument in favor of Canon is that they have a larger variety. That's more to do with finding the right lens for the job than about quality. But Nikon is well covered in the most commonly needed focal ranges anyway so that's not a big factor. Nikon guys....is it?!
Like I said earlier, if you are someone that is starting out fresh with no background using either brand, it does not matter which you choose and it's not limited to Canon or Nikon. Just, whatever you do go with, that's who you will most likely want to stick with because as you grow as a photographer, you will become invested in that brand. You can have equal success with whichever brand you ultimately choose.
Well since I'm a Canon shooter, I thought I was being fair and impartial by recommending a non-Canon camera.
[Edited 2010-05-11 12:32:16]
JakTrax
Tue May 11, 2010 8:03 pm
Quoting Silver1SWA (Reply 13):
Where did I say that Canon's were better? I simply said that image quality is more determined by glass than by the body - irrespective of whether one uses C or N. Where one produces better results at the default settings there'll always be a way for the other to emulate it with a few adjustments. 'Straight from camera' results are often down to personal taste and can't be properly compared between lenses, let alone brands. Let's face it, both C and N produce fabulous images and with both there's the need for at least a little tinkering to get them to a satisfactory standard. Are you saying you don't agree with this?
Fact. And I've never claimed anything but this.
Fair and impartial advice isn't just about recommending what you don't shoot with.
Quoting Silver1SWA (Reply 10):
I may be being a little picky here but doesn't a camera's ability to produce good default images rely heavily on the lens? I dare say the 40D could be set up to give almost the same results?
I'm really not slating your advice - it's good but I think folks new to this need to be given the whole picture without any bias whatsoever. That's why I ultimately recommend going into a shop and trying them. The best camera and quality will be determined by the individual's own preferences, and the best camera will be the one they leave the shop clutching.
Finally, I do agree with you that the D90 is a great piece of kit and betters many equivalent Canons. I still don't think that such an observation is good basis for opting for that particular model without considering others however. Similarly, it's my opinion that C's entry-level cameras (especially the current line-up) wipe the floor with their N counterparts, but again that doesn't mean that a budget N isn't the best option for someone.
Karl
pilotalltheway
Tue May 11, 2010 8:07 pm
Ryan and Karl, thanks very much for the excellent feedback! I shall go into a shop and see what feels best in my hands.
Many thanks again,
-Alfie
Silver1SWA
Crew
Tue May 11, 2010 8:15 pm
Quoting JakTrax (Reply 14):
I apologize Karl. I misunderstood your point. I thought you were saying that lenses matter more and that Canon has the better lenses.
I agree with that.
You may be correct. But my feelings toward the D90 come from my experience with helping a friend who started from nothing, no photographic background, who purchased the D90 as his very first camera. He got with it, a standard kit zoom and right from the get go, I was really impressed with what that camera was producing. After spending a lot of time helping him shoot and edit photos, I came to the conclusion that his camera produces much cleaner images overall and things like color have so much pop that I cannot produce similar results without tinkering with my images in post-processing. And that's with a 40D and a couple of L lenses.
Silver1SWA
Crew
Tue May 11, 2010 8:16 pm
Quoting pilotalltheway (Reply 15):
Ahh, many here would be proud. Good answer!
No prob man, let us know what you choose.
JakTrax
Tue May 11, 2010 10:15 pm
Don't forget though that many people may argue that clean and crisp images are too 'over-processed' straight from the camera. All DSLRs these days are designed to take advantage of post-processing with the likes of Photoshop et al. The 1000D produces outstanding results by default and I personally like them but I know people who have found them a little too 'processed'. On the other hand, I believe N's kit lenses are of a better quality than C's so it could well be down to the lens(es).
I'd imagine there is some way to make your 40D images comparable. I've always managed to tinker and find ways of making default images similar. You can probably tell I have way too much free time on my hands.....
Karl
Fly2HMO
Wed May 12, 2010 5:43 am
I have a D90. Extremely pleased with it. My best friend has a Canon 50D (just about equal to the D90, except for a few more MP and less features overall), and we compared photos side by side of the same subjects. Photo quality was pretty much equal.
However, I found the Canon (and all the other C's I've handled for that matter) very heavy and much bulkier than the D90, it seems very poorly balanced, even with a small lens. I've found Nikons in general to be much lighter, more ergonomic/comfortable and better balanced, without feeling any cheaper built or more flimsy at all (quite the contrary). The Canons, specially the upper level models, just feel too 80's, IMO.
JakTrax
Wed May 12, 2010 12:51 pm
The comparison to the 50D I think is a fair one - it has more MP but less features. See now I on the other hand like the bulkiness of Canon's mid and upper-level bodies - they feel substantial in my hands. Guess it's each to his (or her?) own but | do admit that Canon's entry-level cameras, although currently market leaders, do feel a bit naff to hold.
Karl
pilotalltheway
Wed May 12, 2010 3:43 pm
Quoting JakTrax (Reply 18):
As a DJ, I'm sure there are times when you do!
Quoting JakTrax (Reply 20):
A he in this case.  I am assuming you are not classing the 500D as en entry-level camera? Or are you? It being the third cheapest of the current cameras (1000D, 450D, 500D)...
-Alf
JakTrax
Wed May 12, 2010 4:19 pm
Alfie,
Yes, the 500D is essentially one of Canon's four entry-level cameras, despite the specifications of something much more grand. The others of course are 1000D, 450D and 550D; although the 1000D is Canon's true beginners' model.
While the 450/500/550D have pretty high spec's for semi-budget models they do feel less solidly built than their bigger siblings, however build quality luckily doesn't affect overall performance. Do bear in mind too that budget models (regardless of who makes them) are never going to be as fast as their more expensive counterparts. Then again if you've never been used to the speed of something like a 40D you're not going to miss it! If you're coming from a P&S compact then even the slowest of DSLRs is going to feel lightning quick!
You seem to have the 500D at the back of your mind so follow your instincts and go with that (once you've had a play with one of course). Usually your gut feeling is the right one and you can't go wrong with the 500D. Do however consider also the 1000D and 450D, as the savings you make could be put towards better glass.
Two very good friends of mine (who also happen to be fellow A.net uploaders) use the 1000D and 450D respectively. Some of their pic's can be seen by following these links...
http://www.airliners.net/search/phot..._id+desc&page_limit=15&thumbnails=
Just bear in mind that they both use decent glass.
Karl
Users browsing this forum: TUSAA and 11 guests
