bustin
Nikon D90 - RAW And Photoshop CS3
Thu May 20, 2010 7:26 pm
Hi:
I have problems to open RAW/NEF images with Photoshop CS3 Extender from my new Nikon D90 in my PC. I don´t know if it is a camera setting error or a software configuration. I also tried with a D60 camera and same problems. Is this a SDHC card problem?. Some plugin necesary?
The problem is only with CS3. Another software (Nikon or Picassa) no problems.
I have not problem to open RAW images with my D70 / Compact flash card in my PC (Window XP Proffessional).
I would like some help please.
Bustin
FX772LRF
RE: Nikon D90 - RAW And Photoshop CS3
Thu May 20, 2010 9:36 pm
http://nikonimglib.com/nefcodec/
Download and install.
Lemme know if you have anymore issues.
-Noah
Cleared to IAH via CLL 076 radial/BAZBL/RIICE3, up to 3k, 7k in 10, departure on 134.3, squawk 4676, Colgan 9581.
bustin
Thu May 20, 2010 11:30 pm
Quoting FX772LRF (Reply 1):
I have install http://nikonimglib.com/nefcodec/ but my problem is with Photoshop CS3. I don´t understand because I can open camera D70/compact flash 4GB raw images but not D90/ SDHC 8GB raw images. I have Windows XP sp3. I have tried with D60/SD 4GB raw and have the same problems.
Look how a SD cards problem con CS3
Bustin
Elmdon
Sat May 22, 2010 11:09 am
bustin,
You need to download and install the Adobe Camera Raw plug-in version 4.6, this version is for CS3 and supports raw files from your D90. It's absolutely essential that you follow the installation instructions in the read-me file.
http://www.adobe.com/support/downloads/detail.jsp?ftpID=4034
Elmdon
777jaah
Tue May 25, 2010 8:31 pm
I had the same issues. I took the easy way and upgraded to CS5......
Next flights: AV BOG-ADZ-BOG, AV-UA BOG-IAD-ORD-IAD-BOG, BOG-FLL-BOG, LA BOG-MIA-BOG J
