eksath
Crew
Night Photography: High Speed Landing In The Dark
Tue Jun 08, 2010 3:40 pm
Photo results of high speed engine off shuttle night landing (almost pitch darkness)
I was runway side for STS:123 return. It was pitch dark and there was mosquitoes,assorted other bugs,gators and snakes around. It sure was a memorable landing. The photo result of the experience is here:
http://www.atapattu.net/sts123landing/atapattu00.html
At the end of the gallery, I put a day landing shot as a reference to contrast with the night landing.
Sample picture attached.
http://www.atapattu.net/sts123landing/image02.jpg
World Wide Aerospace Photography
Dazed767
RE: Night Photography: High Speed Landing In The Dark
Wed Jun 09, 2010 2:12 am
Wow great set Suresh! What's up with the Nasa G-II with the nose gear up??
vishaljo
Wed Jun 09, 2010 3:40 am
Lens: Canon F/2.8 50mm
What lens were you using Suresh
Dazed767
Wed Jun 09, 2010 4:53 am
Quoting Dazed767 (Reply 1):
Nevermind looked at one of your photos:
The STA flies at the same speeds, dive angle and approach trajectory as the Shuttle. To do this, the main gear is lowered (not nose gear) and the aircraft engines are thrown into reverse in-flight.
eksath
Crew
Wed Jun 09, 2010 1:15 pm
Quoting vishaljo (Reply 2):
This one. I meant focal length of 50mm at the time of the shot. I should have been more clear with the details. Sorry!
I used this:Canon EF 24-70mm f/2.8 L USM Lens
USM-Lens-Review.aspx" target="_blank">http://www.the-digital-picture.com/r...-70mm-f-2.8-L-USM-Lens-Review.aspx
Quoting Dazed767 (Reply 3):
Sure. Let me add some more context.
For up and down on each mission, the STS plays an important role as there is an astronaut shooting approaches at the SLF making sure that in case of an abort (for up) or in a landing that the SLF is visible and that there is no rain clouds,fog etc cutting into the safety magins. Launch Control and Mission Control relies on the STA to give real time feedback of weather to supplement what the USAF weather squadron is providing from other sources.
As the orbiter rolls to wheels stop, the STA has traditionally flown above her to check her out and also as a welcome gesture. On this particular mission (currently billed as Atlantis's last), this final gesture was very poignant. As the orbiter's last seconds of flight ticked down, there was a heightened sense of reverence watching the standard operations unfold. Atlantis emerged out of the last heading alignment circle opened air brakes and put her nose down to start her dive for the runway. At the same time, on the corresponding opposite side of the runway threshold, I picked out the STA turning in a slower and delayed version of the shuttle path. So moments after Atlantis whizzed by me, I started tracking the STA coming in right after her in the same flight attitude. The two images you see are her chasing after the orbiter which is still rolling down the runway at this point. Just at about wheels stop (perhaps the final one for Atlantis), N946NA gave her customary salute to Atlantis.
walter2222
Thu Jun 10, 2010 7:56 pm
Quoting eksath (Thread starter):
Lovely pictures! I was almost writing "as usual", but these kind of pictures should not be described that way, they are awesome!
Quoting eksath (Reply 4):
Thanks for that extra explanation! Most welcome!
Wow! Is this flying, gliding (or falling like a brick)?? That must be a hell of an experience!
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
eksath
Crew
Fri Jun 11, 2010 8:33 pm
Quoting walter2222 (Reply 5):
Thanks Walter. Anytime.
The STA is in kinda of a skydive in which the person is trying to get maximum speed in a forward direction instead of falling straight down. It is amzing to see it hang in the air at altitude. I have some shots of her in flight and I will try and dig them up.
JeffM
Sun Jun 13, 2010 3:34 pm
Suresh,
Your images never fail to amaze me. By far the most interesting photos on the site imo!
Jeff
eksath
Crew
Tue Jun 15, 2010 10:21 am
Quoting JeffM (Reply 7):
Jeff
Thank you Jeff. I will try to make it even more interesting as we countdown to the end of the program
