AirbusA322
Question About Size To Shoot In/Settings
Fri Aug 13, 2010 11:13 pm
Hey guys.
I got a 1000D (18/55 and 75/300) last week and am heading out to the airport today and try and get some basic shots. Just talking side on views, the easy stuff first.
I dont want to go all the way there and back knowing that I have done something wrong, example being wrong size. At the moment I have the current settings:
-Shooting in RAW 10M, 3888x2592? I wont be zooming too much obviously as there is plenty of room to crop, but is this too big? I do have Photoshop 8.
-AF
-ISO 400 (its cloudy today, no blue sky)
-AL focus is on.
-Picture Style. 3,0,0,0
Anything else? or is this wrong?
I am looking for advice or "compulsory" settings for me to get a shot uploaded.
Appreciate the help. Thanks
dlowwa
RE: Question About Size To Shoot In/Settings
Sat Aug 14, 2010 2:51 am
Hi, I'll try and help you out best I can.
Quoting airbusa322 (Thread starter):
Shooting in RAW does take up a lot more memory, but gives you a lot more flexibility when fixing exposure and color issues. If you shoot Jpeg only and get the colors/exposure perfect, there's not much, if any, difference in terms of quality vs. shooting RAW and then converting.
No such thing as plenty of room to crop. Always do the least amount of cropping possible, as the more you crop, the more you magnify the flaws in an image. Cropping from 3800 to 3300 vs. 3800 to 2300 makes a huge difference. A general rule for my own uploads is that as a cropped image approaches 2000pix in size, the less chance there is that I'll be attempting to upload it. Anything under 2400pix means either the quality is crystal clear perfect, or I'm desperate to see the photo uploaded. This is partly because I have high standards for myself, and also because I upload at 1200pix.
-AF
Yes.
No. If your aim is for upload here, never go higher than you have to. ISO100 or 200, whatever is your base, should be good enough. And I hate to dissuade you, but if it's cloudy, I stay home unless I'm really really bored. Poor light is the death of many many attempted uploads we see here.
AL focus is on.
Not sure what AL focus is. Maybe you mean AI?
Have no idea what that is, must a Canon thing. If you're shooting RAW, I doubt it matters.
Anything else?
I would recommend shooting in Av mode, and either getting a good photography book or at least doing some research to find out why that would be a good idea.
Good luck, and have fun!
Dana
coninpa
Sat Aug 14, 2010 6:21 am
Quoting dlowwa (Reply 1):
Yes this is Canon. Do not use that value, as the first setting (3) is the sharpening setting that the camera uses to produce your JPEG and can cause jaggies right from the beginning. Use 0,0,0,0 instead and process the sharpening in photoshop or other editing software.
Correct. Doesn't matter in RAW.
Good luck
Patrick
Patrick De Coninck
AirbusA322
Sat Aug 14, 2010 10:40 am
Yeah thanks for the info. I am completely new to this part of the industry, hence only taking basic shots, like those on approach.
I headed out to the airport before the first reply so the first thing that really let me down was the high ISO, left it on 400. So my shots are quite grainy, but I understand you can eliminate this via GIMP. I also found alot of my shots too big when I went to crop them. I cropped these down a little, still too big for Anet though, and I have basically done no editing at this point so be nice! Still learning the whole editing thing too.
[Edited 2010-08-14 03:43:46]
dlowwa
Sat Aug 14, 2010 10:53 am
I can only tell two things from the images you've posted: they're the wrong size ratio, and they look dark/backlit. Size ratio needs to be within the 3x2 to 4x3 range. Perhaps you should take a good look through the rejection guide and the upload page before you go any further, and then come back to ask specific questions.
Any other comments or criticisms can't be made of your photos because they're much too small (640pix) to judge quality issues.
JakTrax
Sat Aug 14, 2010 10:58 am
There are two ways of photographing aircraft - the A.net way or your own personal way. Never use this website and potential acceptances as guidelines. You should be doing it for you, not A.net; and if you are doing it for A.net then you're doing it for the wrong reasons.
Quoting coninpa (Reply 2):
Use what you feel is best for you. I have always used (with four Canon DSLRs) the default sharpness setting of 3 and have never had issues with over-sharpened images. In fact most of my rejections these days are for soft. I also like the look +1 saturation gives me.
I agree that cloudy skies can ruin your images but on the other hand I've taken some very unique shots under such conditions. I regularly use ISO400 (without noise reduction) to upload here - although I admit that grain will be less evident in a nicely-balanced sunny shot. Sometimes, if you want the shot, ISO400 is your only safeguard. I'm never discouraged from using it.
Finally, those images certainly aren't bad for a newbie. Only trouble is they are backlit, which occurs when either the sun is in your face (i.e. behind your subject) or there's a bright sky behind, but no sun falling on, your subject. Always ensure the sun is at least 100 degrees over either shoulder (behind you).
Karl
flipdewaf
Sat Aug 14, 2010 11:43 am
I have only 2 pics on here and don't really have it as my aim to get them on here but I would say that ISO400 is fine. Maybe for this site it isn't the thing that they are looking for but for general photography then it matters not. Personally (and I think many people into photography would agree with me here) that grain looks substantially better than blurred images, hell I'd shoot ISO6400 if it was dark. Just keep practicing (learning how a camera works is easy) and remember that no one gets good pictures sat at their computer screen  .
Fred
JakTrax
Sat Aug 14, 2010 6:34 pm
Quoting flipdewaf (Reply 6):
You may only have two images here but that's the best piece of advice I've heard all week!
If I want to guarantee the shot I'll shoot at ISO400 no problem - whether A.net likes it or not. Indeed, it's a question of, "Do I want the shot or not?". Worry about Airliners.net later.
Karl
Kukkudrill
Sat Aug 14, 2010 8:22 pm
I agree with this 100 per cent
Quoting JakTrax (Reply 5):
And with this
But shots that are neither blurred nor grainy would look better still in my opinion. Like flipdewaf says photography is a matter of practice, and if you practice taking long-distance shots at ISO100 to 200 you will learn to track your subject while holding the camera steady enough to get good shots. You never will if you keep shooting at ISO400 just for insurance.
I am assuming normal light of course.
Make the most of the available light ... a lesson of photography that applies to life
JakTrax
Sun Aug 15, 2010 4:42 am
Sorry, perhaps I should have made my stance clearer. I don't prefer to shoot at ISO400 but sometimes you simply have no choice - and when presented with the 'no choice' option it doesn't particularly bother me upping the ISO. I can work almost as well with 400 as with 200.
If the light has dropped, I'm at 200mm (on my 70-200), already down to f/6.3 and the shutter isn't sufficient, then ISO 400 it is...
Karl
Users browsing this forum: Baidu [Spider] and 1 guest
