Stealthz
Adobe Camera RAW, Not Just For RAW!
Tue Aug 17, 2010 9:07 am
Have not seen much written about this, here or elsewhere.
ACR since V4 has been able to correct exposure, lighting and colour temp issues in JPEGs as well as RAW files.
Has anyone used it this way and if so what successes or issues have you experienced.
FYI ACR V4+ is available for PS CS3 onwards, PSE 5 onwards and all versions of Lightroom
viv
RE: Adobe Camera RAW, Not Just For RAW!
Tue Aug 17, 2010 10:50 am
Nope. I try to get exposure, lighting and colour temperature right when I shoot, not in post-processing. I mostly succeed.
Tue Aug 17, 2010 10:53 am
Quoting stealthz (Thread starter):
I've tinkered around with it a little. Although the functions are the same, you're still slightly restricted as to what you can do with a JPEG compared with a RAW but reasons for this are quite obvious. I wouldn't say I've succeeded in doing much with it but I think the functions of controlling 'black' and 'fill light' come in handy when trying to get something out of a near pitch black picture compared to the normal functions on Photoshop. These have been my deductions anyway.
White balance has to be changed manually as it doesn't give generic values for daylight/cloudy etc, even as just a reference but I guess the eyedropper white balance tool might be useful. It also remembers that you opened the JPEG with Camera RAW and will open Camera RAW up if you go back to re-edit the picture, as if it were a RAW itself.
JakTrax
Tue Aug 17, 2010 11:54 am
Surely if ACR could manipulate exposure, colour temperature, etc. RAW files would become obselete?
It may be able to tinker with JPEGs in a more advanced way than Photoshop but I'm sceptical about its ability to process JPEGS like RAWs.
I'm all for eating humble pie if it really can though.....
Karl
Kukkudrill
Tue Aug 17, 2010 12:12 pm
A JPEG is basically a RAW file which has had a lot of data thrown away and the rest compressed to a certain extent. So I don't think Karl need worry about RAW files becoming obsolete. It's only logical that you should be able to apply the same software tools to both formats, but the RAW file will always be more editable than a JPEG.
Charles
Make the most of the available light ... a lesson of photography that applies to life
coninpa
Tue Aug 17, 2010 12:14 pm
Quoting viv (Reply 1):
   This is the best way to start a good photo.
However, to reply to your question if your shot was not that good, you will never get the same (usually good) result with Camera Raw on a JPEG image as with a RAW image. Sorry to be a bit technical... A JPEG image is digitally encoded using 8 bits and is already compressed by your camera body, a RAW image is encoded most of the time using 12 bits (14 bits on high-end cameras) with no compression. So, even if ACR permits to act on JPEG images, it is only "trying" to apply corrections on an image which contains a lot less informations than a RAW image, so the quality and the result can only suffer.
Hope it helps
Cheers.
Patrick
Patrick De Coninck
jid
Tue Aug 17, 2010 12:15 pm
ACR 4+ can edit jpegs and you can use your jpeg as a smart object if you wish. ACR does not manipulate your jpeg in the same way as a RAW file however, for instance if your jpeg is slightly over exposed ACR can not help you like it would a RAW file. But again the question is why would you want to edit a jpeg? Shoot RAW, try to get everything right straight from the camera. Process in ACR first and finish in PS and save as a jpeg - done. If you need to do any re-working go back to your RAW file and start again.
Good luck .. Jid
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
757MDE
Tue Aug 17, 2010 5:05 pm
I actually managed to fix the colour on a jpg that had been rejected twice for colour (a night shot) by processing it like RAW.
Quisiera volveraamartevolveraquerertevolveratenertecerrrrcaademígirl! Mis ojos lloran porrr ti...
Dehowie
Wed Aug 18, 2010 2:46 am
What Jid says works well..ACR works well with JPG's and keeps things similar if you also shoot RAW...
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
