pilotalltheway
Canon 50D Vs Nikon D90
Fri Sep 10, 2010 7:48 pm
Heya folks,
Just an interesting discussion I've been having with a friend - what are your thoughts? What's better? Let's not bring up the 60D and just say 'Get the 60D' as it is around £500 more expensive.
Have fun and happy debating!
I look forward to hearing from y'all!
-Alfie
[Edited 2010-09-10 12:48:32]
Dude - where's my plane?
iamlucky13
RE: Canon 50D Vs Nikon D90
Fri Sep 10, 2010 8:13 pm
I think the 50D still costs a bit more. Image quality shouldn't be radically different. The 50D is physically larger and has a few more external controls.
There's not a huge amount to differentiate them. What's important to you? Have you handled them both to get a feel for whether one feels more natural or more intuitive to you? Do you have an idea what lenses you will want? Nikon and Canon have similar, but not identical lens lineups.
FYI, rumors are flying that the D90 replacement is expected to be announced, possibly next week. It should be very comparable to the 50D in terms of overall design, but obviously have a newer sensor. It might actually end up slightly nicer than the 60D, since Canon seems to have pushed the XXD line down towards the consumer end a little bit. Price should be $1200 (US) for the body only, although I know UK prices are wildly different.
clickhappy
Fri Sep 10, 2010 8:46 pm
My opinion would be that the 50D is more of a "prosumer" camera, while the D90 is an amatuer camera. That is not to say that one camera is better image quality-wise over the other, but I would say the 50D is built to a more robust standard, with more advanced features.
Some of these would be:
Higher absolute shutter speed
Higher FPS (shooting speed)
Faster Synch speed
One strong suit in the D90's favor would be a superior rear LCD.
The 50D (or D300 if shopping Nikon) will be more durable and have better weather sealing than the D90.
zbot69
Sat Sep 11, 2010 12:12 am
I lost in faith in Canon after becoming sick and tired of the problems with my 40D, and I don't relish the prospect of purchasing another Error 99 machine that can't shoot above 125 ISO. That said... I've seen some Nikon lenses take a thorough trashing in similar threads, so I'd be interested in hearing some views either way. At this point my bias is in favor of Nikon, but I'm at a loss what lenses to match up with it.
cpd
Sat Sep 11, 2010 12:23 am
Quoting zbot69 (Reply 3):
Don't know what you are referring to - I'm thoroughly happy with the results of even the modestly priced Nikon lenses I have (300mm F/4). And even the kit-lens I had on my old D80 - the 18-135mm F/3.5-5.6G ED provided great results every time I used it, even opened up to F/5.6.
Nikon does have some poor lenses, but they have more than enough good ones too. Look beyond the obvious 'spotters' lenses like 80-400mm and investigate lenses like 300mm F/4.0 for a reasonably priced and rather pleasant surprise. I think a D90 with a 300mm F/4.0 will give superb results.
I don't see much difference between D90 and Canon 50D. Canon has more megapixels and is maybe more rugged -but otherwise both are excellent cameras.
[Edited 2010-09-10 17:24:50]
zbot69
Sat Sep 11, 2010 12:38 am
Quoting cpd (Reply 4):
Don't know what you are referring to...
Come on Chris... give yourself some credit...
Look beyond the obvious 'spotters' lenses like 80-400mm...
How do they say that again... nail... head... hit something or other.
That's actually not a bad idea though on the 300. Probably have to pair it with a 70-200 though. I'll look into it.
clickhappy
Sat Sep 11, 2010 2:07 am
While some Nikon lenses are dogs (80-400) in reality the Canon 100-400 isn't that much better. Many copies are soft, suffer from build quality issues, and are huge dust pumps.
But the notion that Nikon lenses are behind those offerings of Canon aren't as true as they used to be. Glass like the 14-24 and 16-35 are far ahead of similar offerings from Canon.
cpd
Sat Sep 11, 2010 2:22 am
Now that I've remembered it - I'd suggest to hold off on buying a Nikon D90 at the moment. The replacement should be announced next week.
zbot69
Sat Sep 11, 2010 3:23 am
Quoting cpd (Reply 7):
I don't know... that actually seems like a more compelling argument to act now. I had a chance to use a friend's D90 and it frankly blew me away. The noise handling on the Nikon was impressive; then again I apparently had a defective 40D that was incapable of low noise performance at all. I also shot with a 1D Mk II, but I was surprised how badly the AF was in low light. The real area where the Canons excelled vis-a-vis the D90 was frame-rate. Goes without saying that the 1D was phenomenal. Covered some local events and you hardly miss a thing at 8-some fps. Come to think of it, the low frame rate on the D90 would be the only drawback I can think of. If a D90 successor had a higher frame rate, maybe that would be a reason to hold out a bit longer, but other than that, I can't think of anything. And the 12mp is more than adequate for my photography needs.
aviopic
Sat Sep 11, 2010 7:11 am
Quoting pilotalltheway (Thread starter):
What's better?
Sigh...... "better" is not the question you have to ask yourself.
"Better" is relative to your needs(and your budget).
So what do you "need" is the question you have to answer.
If the answer is big prints the 50D is probably the better option, if you don't the D90 probably is.
The D90 is pretty forgiving with (relative)cheap glass, the 50D not so much.
If you have the budget for L glass(or EX sigma) the 50D will suite you fine, if not it's a waste of money.
Good luck,
Willem
The truth lives in one’s mind, it doesn’t really exist
trvyyz
Sat Sep 11, 2010 1:53 pm
The dynamic range of D90 is superior.
Silver1SWA
Crew
Sat Sep 11, 2010 7:34 pm
I've said it here before and I will say it again. If I had to start all over again, I would choose Nikon and start with the D90. A friend owns one and I am always amazed at how incredibly clean and vibrant the images are. The IQ, even with the mediocre lenses he owns often has me quite jealous. The D90 is a sweet camera from what I can tell.
NIKV69
Sat Sep 11, 2010 9:26 pm
Quoting Silver1SWA (Reply 11):
Ryan as a member of Nikon nation I can say we will welcome you aboard with open arms! Craiglist, ebay come one you can move that Canon and get with the program. Hell even Royal may attend the party!
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
Silver1SWA
Crew
Sat Sep 11, 2010 11:05 pm
Quoting NIKV69 (Reply 12):
Ah, but I said if I had to start over again. Thankfully I have no need to start over. (knock on wood)
zbot69
Sun Sep 12, 2010 3:11 am
Just curious Ryan, and if you had... what lenses would you have gotten for it? I recently did just that... I sold off all my Canon gear and am switching to Nikon. After 6 trips to the Canon Service Center I'm calling it quits. It's very nice to be on a first name basis with the wonderful ladies at the TST service center, but I can think of cheaper ways of meeting women than buying defective camera gear.
NIKV69
Sun Sep 12, 2010 3:35 am
Quoting zbot69 (Reply 14):
Welcome aboard!
First piece of glass you need is the 80-200 2.8.
zbot69
Sun Sep 12, 2010 3:58 am
Quoting NIKV69 (Reply 15):
Thanks Nick. Yeah, I'm kinda leaning in that direction. I'm still undecided on whether to pair the 80-200 with the 300 prime or gamble on the 70-300 VR. It's nice to have better quality glass on the 200 and 300 end, but the gap in the middle will be sorely missed. Not to mention the thought of carrying both lenses, and/or ultimately getting a second body to go along with them. It's all good though. No matter which way I end up going, I look forward to it. As I said before, I was really blown away by the D90's performance on our walk around. Especially considering it's marketed as a consumer camera. Certainly delivers professional results. And the prices at the moment are eye-popping.
Thanks again.
JakTrax
Sun Sep 12, 2010 5:00 am
Quoting Aviopic (Reply 9):
That is a downside to the 50D. Even some medium-range glass has a hard time adapting to it. Many of Sigma's lenses just don't seem to give good results on the 50D - and even some of the more expensive ones.
Back to the debate.....
I would plump for either Canon or Nikon if I had to start over again. I know people who've swapped their systems over in both directions and been happy with the change, so I doubt anyone can really say which brand is better. With very similar products you're always going to get some happy with one and others satisfied with the other. By the same token, you'll always get a dodgy copy of something, or a copy that doesn't quite live up to expectations - no big deal, and this certainly shouldn't be reflective of the brand.
It's also about learning to get the most out of your gear. Some people have this 'tried for 5 minutes and it wasn't as good as my last set of gear' attitude. They will slate something simply because it wouldn't do exactly what they wanted when they wanted it.
For the record, I came over to Canon from Minolta years ago and have been (almost) 100% happy 100% of the time.
It's a personal preference thing - both manufacturers offer products which will always suit different types of users. Some will always be more comfortable with Canon, others with Nikon. These "Which is better?" debates are I'm afraid always pointless, rarely prove anything and have a habit of getting us all to act like 6-year-olds.
Karl
NIKV69
Sun Sep 12, 2010 7:37 am
Quoting zbot69 (Reply 16):
300 prime. No question.
pilotalltheway
Sun Sep 12, 2010 7:18 pm
Right.
The the 550D used to be a contender but I didn't like the way it felt in my hands. I spoke to somebody from Jessops today and he told me how he has the the D90 and his mate who he shoots with has the 50D and whenever they compare shots after shooting the 50D always has the more vibrant colour in the shots whereas the D90 wins in lower light conditions. I prefer the build of the 50D, but the setup of the D90. I'm really suck as to what to get. Oh, and apparently the Nikon 18-55mm lense is really rubbish compared to Canon's.
What would you do if you were in my position?
Many thanks,
Alfie
JakTrax
Mon Sep 13, 2010 4:03 am
I guess the 550D is still a contender but if it doesn't feel right then I'd say it's outta the window. Like I said earlier, the best is whichever feels right in your hands, and whichever feels natural to you. Asking others is often pretty useless as you'll always get a mixed bag of results.
I chose the 50D and am chuffed to bits with it. The colours tend to lean a little more towards red straight out of the camera but it's nothing that can't be easily addressed post-capture. Nikons on the other hand tend to have a slight blue bias so all's equal really.
I guess you've looked through the database for shots taken with both and you'll have seen that, once processed, the images look the same. You can't tell which is which. Both the 50D and D90 will do exactly what you want them to do, providing you take the time to learn their features and how best to operate them. I can't give advice on the D90 as I've never used Nikon (well; I once borrowed a friend's D70 for a day) but the 50D is a damn fine piece of kit and despite what some might say I've not bumped into any disgruntled users. The 15MP sensor is great if you don't quite have enough reach with your lens as you can crop much more without losing too much quality (although I do this VERY infrequently!). It's also very low noise - I have quite a few shots uploaded here taken at ISO400 with no noise reduction applied.
Finally, you should really consider what lenses you'll want to be using. Seeing as lenses are more important than camera, it's best to check who does what so that you don't end up desiring a lens your brand doesn't do. Many Nikon users complain that they don't have a proper 100-400L equivalent - although that lens isn't without its drawbacks.
Quoting pilotalltheway (Reply 19):
I don't know about that - the Canon kit lens isn't stunning! It's not bad for the extra you pay for it though, especially when you consider it has IS.
P.S. If you want to see what the 50D and some decent glass are capable of, feel free to browse some of my images:
http://www.airliners.net/search/phot..._id+desc&page_limit=15&thumbnails=
I can't stress enough though how the 50D only performs with good glass!
Karl
cpd
Mon Sep 13, 2010 6:14 am
Quoting JakTrax (Reply 20):
I would have thought that with 15mp and ISO400, that would be a given - especially if you frame the subject as close as possible and then resize down to 1024px or 1280px wide.
The D90 I hear is much the same - it also has very good high ISO performance (better even than the D300 according to some).
What they did have was 70-200mm F/2.8 VR lens and the ability to use a teleconverter with it. That seemed to work reasonably well on the old D300 from the results I've seen - though of course it's not relevant anymore since the new version of the 70-200 F/2.8 lens (VR II) is more expensive.
But it's maybe a better option than using the 80-400 on its own, especially if you also take photos in very low light (where the F/2.8 lens should be useful).
I personally don't think the 50D is as bad as some people claim it is either.
JakTrax
Mon Sep 13, 2010 6:55 am
Quoting cpd (Reply 21):
I think perhaps the first batch wasn't great, however the later batches and firmware update corrected all issues. I also think that people were struggling to properly adress the 15MP sensor - after all, it was at the time 5MP more than any other crop-factor DSLR. Very much like the negative things initially said about the 7D I guess.
More megapixels on a small(er) sensor will give the illusion of excessive softness. Couple that with the 50D's hunger for top glass and it's really no wonder it fell foul of the criticsa when it first appeared.
Karl
5J
Mon Sep 13, 2010 2:07 pm
Not being biased here, but i believe Nikon has better kit lenses actually. I'd say Nikon's 18-55mm is a little bit better than Canon's equivalent.
One piece of advice, don't get the D90 with the 18-105mm kit lens. I heard that the images tend to be quite soft at high zoom levels. I'd suggest you'd get a D90 body only, and then get another lens.
A.net chat squatter
Dehowie
Tue Sep 14, 2010 6:13 am
Quoting 5J (Reply 23):
Mmmm i think they call that a contradiction....and thats with 12MP versus 15.
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
757MDE
Tue Sep 14, 2010 11:23 pm
I had the same dilemma early this year (even posted a thread here about it).
Finally I decided to go for the D90, which I paired with a 70-300VR and later a Tokina 11-16 and I don't regret my choice at all.
I can't really say anything about the 50D since I haven't had extensive experience with it other than a few tries, but sure can vouch for the D90!
Quisiera volveraamartevolveraquerertevolveratenertecerrrrcaademígirl! Mis ojos lloran porrr ti...
Dehowie
Wed Sep 15, 2010 5:41 am
Be interested to see what all the Nikon fanboys have to say bout te new D7000..
Wonder if we will hear the diatribe about squeezing 16.4MP into a crop sensor giving crap image quality rubbish thats been unloaded on the 7D for over a year.
Specs look good from here and i use Canon. Midway between the 60D and 7D in specs and performance so more decisions to be made for entry level buyers.
Oh took this with my better half's 550D a few weeks ago. Pretty good colors and rendition from where i'm sitting.
http://www.vortexaviationphotography.com/Civil-Aviation-Photography/Cairns/IMG4351/1008592007_FyTgY-X2.jpg
[Edited 2010-09-14 23:08:08]
pilotalltheway
Wed Sep 15, 2010 5:14 pm
I think I shall go with the 50D as all these new cameras are quite pricey.
Thanks for the help guys,
Alfie
dvincent
Wed Sep 15, 2010 6:12 pm
Quoting Dehowie (Reply 26):
The 16 MP sensor is about equal to a 14 MP Canon sensor in terms of pixel density because it's 1.5x crop, not 1.6x crop. It's still not in the ballpark of the 7D, and still less dense than the 50D.
From the Mind of Minolta
iamlucky13
Wed Sep 15, 2010 6:59 pm
Quoting pilotalltheway (Reply 27):
Alfie
Sounds like a plan. Enjoy!
People who rank either one as giving crap image quality are themselves full of crap. Nikon seems to pull off slightly better high ISO performance (except for the D3s, which is amazing), but the differences are hardly night and day, and there's plenty of Nikon users vocally pining for higher resolutions like the Canon's offer (without paying $7000 for a D3x).
alasdair1982
Wed Sep 15, 2010 9:30 pm
I don't like the 18-105 lens at all, and when I can be bothered, i'll revert to the 18-55 VR lens.
cpd
Thu Sep 16, 2010 12:42 am
Don't have much to say at all - it's not really the camera I'm interested in. That said, it looks interesting. Have to wait and see how it goes and I'd like to try one for a weekend.
Quoting iamlucky13 (Reply 29):
But Canon has 1D Mk.IV which does pretty much the same, and is cheaper by quite a margin here. I don't get all this favouritism of one brand of camera over the other - as long as the camera isn't complete junk, it's down to the photographer to know how to get the best out of it.
I still get amazing quality images out of my old D80 with a fairly ancient 300mm prime lens, they are so good that you'd never be able to tell that they came from an older camera/lens combination unless you looked at the EXIF. For most conditions, we are never really pushing the limits of our cameras. Okay - the old D80 is slow as a wet week, but it does the job. I'm keeping it for those times where I don't want to take a bigger, more expensive/flashy camera.
Dehowie
Thu Sep 16, 2010 2:39 pm
Lol since when are you a fanboy Chris...far to balanced a viewpoint to be included!
