captain777
All The Basic Shooting Tips In One Thread
Wed Oct 20, 2010 11:53 pm
Hi I know this subject has been discussed many times in this section of the forum but i thought it would really be helpfull if all you pros out there would give us all the tips for shooting in all kind of conditions:
*taxiing aircrafts (Cloudy/Sunny/Night)
*aircraft on approach (Same as above conditions+angle pref)
*Cockpit shot ( Night/Daytime/Full moon/Dark cockpit+Night)
*Departing Aircraft (Same conditions as above)
*Tail Shots ( Same conditions as above)
*Airport shots INFLIGHT ( Night/Day/Hazy/Cloudy)
*Any other condition :p
If you guys could help with shutter speed, ISO setting, light setting etc,,,, in each condition above........
My camera is a Canon Rebel, standard lens, no tripod ( i just use a small one for cockpit shots, i don't know the name its the one that you could bend to clamp on nearly anything )
THAAAAAAAAAAAANX ALL
[Edited 2010-10-20 17:12:05]
the sky is the limit.............actually FL410 is the limit
ghajdufi
Crew
RE: All The Basic Shooting Tips In One Thread
Thu Oct 21, 2010 5:11 am
There are no settings you can use without adjusting to the current conditions. Such a list would not help you. Practice as much as you can.
I'm no pro but:
f8 iso200 -1/3EV should work in most cases. If the light is not enough for these settings either make the f number smaller or the iso number higher. If your background is brighter the the acft you need to overexpose a bit if the background is darker you need to underexpose.
Most importantly especially if you want to upload to this site, !Get your editing right!
I hope this helps,
HGabor
Your photos are like your children, you will always find them perfect.
sulman
Thu Oct 21, 2010 8:16 am
Quoting ghajdufi (Reply 1):
I think one has to be careful with this. Learning your camera body's exposure behaviour is really handy. For example, if I used such a blanket settting I would probably underexpose by up to a stop, depending on the light, because the metering is fairly conservative anyway.
I used to routinely shoot -1/3 on my 300d and looking back at those images, a large number are underexposed.
James
viv
Thu Oct 21, 2010 8:42 am
Such a list would be useless, because the light for every shot is unique.
You would benefit more from learning the basics of photography - colour temperature, exposure, composition - and how your camera settings - white balance, ISO, metering, shutter speed, aperture - affect those basics and interact with each other.
ZakHH
Thu Oct 21, 2010 9:06 am
Quoting viv (Reply 3):
Exactly. Understanding these basics is the key to photography. There are no predetermined checklists for taking photos (unless for stuff like "take the lenscap off" and "make sure there is a memory card in the camera"   ).
Quoting sulman (Reply 2):
Not only that. Different lighting conditions require different exposure corrections. Always shooting with -1/3 EV will often just add noise to the darker parts of the picture.
-1/3 or -2/3 is helpful under bright conditions, and with white or bright aircraft, as it helps preventing blown highlights.
But when it's overcast, or while shooting in the dusk, I'd use +2/3 instead (like here - shot taken with +2/3 EV, while an hour before, I was shooting with -1/3).
And when I was shooting at an airshow this spring, and tried to catch the Blue Angels against a very bright sky, I used a full +2 EV, to avoid ending up with completely underexposed aircraft against a correctly exposed sky (and it worked).
Always using -1/3 EV is a bit like always using a shutter speed of 1/200, no matter if I shoot a static object at 20mm or a moving object at 400mm.
Tired of a.net? Join a friendly aviation community!
ghajdufi
Crew
Thu Oct 21, 2010 9:29 am
Let me correct James' quote before you all "kill" me:
JakTrax
Thu Oct 21, 2010 9:36 am
Again, not necessarily. It depends. A good way to shoot white aircraft against a dark sky is to meter the subject only (centre-weighted or spot).
There are tips that work in a good number of situations but, as has been said, each scenario presents its own lighting uniqueness. Even the type of cloud around and how the sun is shining on/through it (if shining at all) can be a factor.
Karl
cpd
Fri Oct 22, 2010 12:31 am
Quoting ghajdufi (Reply 5):
Watch out, the violent mob is coming after you!
I find I'm most often underexposing by -0.3EV. I can generally get away with that in most situations without exciting noise in the dark areas of an image, the beauty of the Nikon 36x24mm camera format - such low noise.
Otherwise, there are very few common things that can be done. In daylight (sunshine) I set 4550K for white-balance, everything else is on a shot-by-shot basis. Sometimes I will use F/22 in broad daylight just to reduce the shutter speed - there is little else I can do with the lenses I use. On some lenses, you can stack filters together to reduce the light getting to the sensor, but on my lenses, it's not possible since they are all very big.
Normally that might cause softness, but in the best of lenses, it's usually okay.   But it does expose dirty camera sensors very well.
If I'm photographing something very fast moving (Mach 0.8 or better at low altitude), I'll generally put ISO400 and use F/6.3 aperture to get a high shutter speed of 1/3200second or better. Sometimes you have to do that in order to get the photo sharp enough.
What other people do with ISO settings and apertures might be different because of how their camera equipment works. On shutter speeds, I can't tend to reliably use less than 1/50sec - that's the limit for where I can get sharp photos.
But in general, there is very little you can share from photo to photo.
[Edited 2010-10-21 17:39:25]
[Edited 2010-10-21 18:04:29]
captain777
Fri Oct 22, 2010 12:46 am
Now what very limited skills i have shooting I lack in editing...
Can you Give me tips on editing
and if you guys wouldn't mind keeping the pro phraseology limited since i barley no the basics :p
Thanx again for all the help guys just the kind of tips i need....
cpd
Fri Oct 22, 2010 12:58 am
Quoting captain777 (Reply 8):
Just as well you put the huge grinning face!   Anything to get another budding photographer up and running.
Airliners.net made it very easy for us this time - they have an editing guide online:
http://www.airliners.net/faq/editing_guide.php
That's referencing what appears to be a very old version of Photoshop (or maybe it is Elements).
If you use modern Photoshop CS3/CS4/CS5 versions, try Scott Kelby's Photoshop for Digital Photographers books - they are extremely good, and Scott Kelby writes them in a very simple way and fills them with useful practical information that you can readily apply to your own photo editing process:
http://www.bookdepository.co.uk/book...CS5-Book-for-Digital-Photographers
Some books are very heavy and filled with useless waffle - not Scott Kelby's ones.
That's the CS5 version, but he has older versions of the book as well. I can't help you with Photoshop Elements, I've only ever used the full Photoshop versions.
[Edited 2010-10-21 18:02:42]
[Edited 2010-10-21 18:05:36]
[Edited 2010-10-21 18:06:44]
captain777
Fri Oct 22, 2010 1:11 am
Thanks for the help....
I had to put that huge grinning face so that you pros don't say "well what the hell is someone like you doing with a digital camera in the first place "
cpd
Fri Oct 22, 2010 1:56 am
Quoting captain777 (Reply 10):
Hey now, don't be intimidated - everyone has to start somewhere, and I'm sure that many of us had less than glorious starts.   I'm glad to help out when and where I can.
javibi
Fri Oct 22, 2010 9:22 am
Quoting cpd (Reply 7):
You are getting into the realms of diffraction there; why don't you use ND filters?
j
cpd
Fri Oct 22, 2010 12:00 pm
Well not that I've noticed. I'd use them, only I don't think any exist for the giant lenses.
javibi
Fri Oct 22, 2010 2:07 pm
Quoting cpd (Reply 13):
Don't your lenses take drop in filters??
j
clickhappy
Fri Oct 22, 2010 2:17 pm
Chris - curious to what you are shooting at F/22 in broad daylight? That would be a shutter speed of about 1/30th of a second at ISO 100.
JakTrax
Fri Oct 22, 2010 2:36 pm
Speaking of diffraction, what aperture would you say would start to show the signs? I tend not to go above f/11 just in case. I suppose it depends on lenses but I've often thought, "Should I go to f/12 and above?".
I also notice that CA can occur when using very fast shutter speeds with mid-sized apertures.
Karl
dazbo5
Fri Oct 22, 2010 3:11 pm
Quoting clickhappy (Reply 15):
I can't speak for others, but I'll often use this sort of aperture if I'm after motion blur on a sunny day, for example when shooting props or panning (I don't have any ND filters). I can't say I've ever had too much of a problem with diffraction at these apertures. If you have a certain amount of heat haze causing you problems, by using a small aperture and therefore slow shutter speeds on a moving subject, It's possible to get a sharpish shot when using a faster shutter speed would just results in heat hazed photos. It doesn't always work, but I've been able to shoot a few rare arrivals and get good enough results when the usual shooting technique would fail.
Darren
cpd
Fri Oct 22, 2010 7:52 pm
1/30th is the whole idea. Slow shutter speed - blur some things. Fortunately it's only needed at daytime, dusk isn't a problem.
Quoting javibi (Reply 14):
I'll have a look again, but I don't remember seeing that kind of filter as a drop in on sale here.
Plenty as front mounted (with a special filter holder so you can stack them), but only for the smaller lenses.
[Edited 2010-10-22 12:56:06]
clickhappy
Fri Oct 22, 2010 9:09 pm
Got it. Was confused by your earlier comment that you can't reliably use anything less than 1/50, was thinking you meant you would thus avoid anything slower than 1/50.
photopilot
Sat Oct 23, 2010 12:13 pm
If you want to bake a cake, you need an exact recipe of ingredients, time and temperature. But you're not baking a cake. You're taking photographs and unless you're shooting in a studio under controlled conditions, photography is a dynamic activity with ever changing conditions.
There is simply NO SUBSTITUTE for practice, practice, and more practice. You also need to STUDY and learn the basics of photography. The inter-relation of shutter speed, ISO, Aperature and light value. In this fast-food world of instant gratification, people think that there's some magic instant formula to get great photos. Sorry, it simply doesn't work that way. If you're not willing to put the WORK into your craft, then you simply won't get the results.
An Amateur keeps trying until he gets it right.
A Professional keeps trying until he never gets it wrong.
Happy studying.....
JakTrax
Sat Oct 23, 2010 2:11 pm
To be fair, I think light is that temperamental that all of us - irrespective of skill or experience - get it wrong occasionally. I know I do.
Mother Nature isn't one to be tamed and until we can do that our images are never going to be 100% spot on all of the time.
A good example from my own experience is when the sun suddenly and unexpectedly streams through a thin layer of cloud. Not much time - what do I do? How do I meter? Do I account for sun or not? The light can change dramatically from one second to the next.
Karl
captain777
Sat Oct 23, 2010 10:58 pm
Quoting photopilot (Reply 20):
Thats what i've been trying to get from starting this thread....
I don't mind trying till i get my photos the way i want them to be but my biggest problem is the SET-UP every time i snap a photo in the cockpit they scene is always boring with no action or fun in it, so thats my other problem beside knowing what setting to use for each different condition and situation, I can't seem to get a LIVE FUN INTERESTING pic
eg of my pics :-
[Edited 2010-10-23 16:00:28]
captain777
Sat Oct 23, 2010 11:01 pm
am sorry the second photo is not up right... no clue how to rotate it
cpd
Sat Oct 23, 2010 11:14 pm
Hi again,
For those flight deck photos (it's an A300 Airbus, isn't it - very nice), you should be using an external flash.
You need to set the camera exposure to be correct for whatever is outside the window, and then set the flash power to fill the inside of the flightdeck with light so that it too will be exposed properly.
So what I do in these situation is:
- manual exposure on the outside of window, take multiple shots until the exposure is right (look at the histogram display in the camera to check that)
- now set the flash power and take a few shots with different power settings for the flash until you get the right exposure inside the flight deck.
This is much easier for these kinds of photos since the plane is going nowhere and you usually have enough time to get it right. And some pilots are quite interested about the methods to get these kinds of photos - so are very willing participants to the whole thing.
The rest is just working out appropriate motives. Generally, just try normal straight ahead wide-angle flight deck photos of the whole panel and glareshield until you become more confident about taking more unusual shots with things like fisheye lenses.
captain777
Sat Oct 23, 2010 11:22 pm
thanks very much for the tip....yup it is an A300-605R
these are the kind of shots i'd like to be capturing, so do all cameras have the ability to change the FLASH power ?
and how about if it was night shall i still use flash then ?
thank you for your help
cpd
Sat Oct 23, 2010 11:49 pm
Quoting captain777 (Reply 25):
If you have an external flash (eg, Nikon SB-600 / SB-800 / SB-900), It's very easy to do. It's easy to do any camera, but on the built-in flashes, they are usually useless for these purposes -because the bulky wide angle lenses (particularly F/2.8 lenses) often gets in the way of the built in flash. So you need to use an external add-on flash.
On Nikon, you press the button labelled with the "electrical spark" and then rotate the command dial. It's just like changing exposure compensation in the way you adjust it. I can't offer advice for Canon since I haven't used Canon for a long time.
At night, use a tripod (or one of those Gorillapod grips, which is what I think you have already), and you won't need to use a flash. Have some nice soft glareshield lights turned on in the plane - and with the displays on, you'll get a nice effect.
Watch when using the flash that you don't reflect the light of the flash off the displays in the flight deck. You can often angle the head of the flash upwards and bounce the light off the ceiling for a more diffused light. This will also stop things like the throttle levers casting a shadow onto the panels behind them.
[Edited 2010-10-23 17:00:08]
[Edited 2010-10-23 17:01:19]
photopilot
Sun Oct 24, 2010 12:06 am
Quoting captain777 (Reply 22):
You need to learn......
ISO – the measure of a digital camera sensor’s sensitivity to light.
Aperture – the size of the opening in the lens when a picture is taken.
Shutter Speed – the amount of time that the shutter is open.
It is at the intersection of these three elements that an image’s exposure is worked out.
Most importantly – a change in one of the elements will impact the others. This means that you can never really isolate just one of the elements alone but always need to have the others in the back of your mind.
Exposure
http://www.digicamguides.com/learn/exposure.html
Aperture and Depth of Field
http://www.digicamguides.com/learn/aperture.html
Shutter Speed
http://www.digicamguides.com/learn/shutter-speed.html
ISO
http://www.digicamguides.com/learn/iso.html
captain777
Sun Oct 24, 2010 12:12 am
thanks to all you guys really needed all these basic info and you really made all the stuff i wanted to know real clear to me........ hopefully you'll be seeing some of my pics here at airliners.net
viv
Sun Oct 24, 2010 6:39 am
This text should be permanently engraved at the top of Anet.
If you do not UNDERSTAND what you are doing, you will - of course - sometimes produce some good shots. But, even when you do, you will not know why. LEARN first, then PRACTICE.
This takes time and effort. If the time and effort needed are too much for you, do something easier than photography.
