Rotate
Calibration Prog
Fri Jan 14, 2011 3:42 pm
Hi Guys
I am getting tons of rejections with dark. Well, I am using new monitors   Could anyone give me again this good calibration programm for monitors ?
Thanks very much !
Robin
ABC
teopilot
RE: Calibration Prog
Fri Jan 14, 2011 4:08 pm
Calibration program... sounds new to me (sorry for that, I'm still a newbie!), as the monitor calibration sound new to me as well.
Could you please tell me what is it and what is it for?
I suppose is something to calibrate the monitor, by what Rotate said,... but what are the benefits?
NicolasRubio
Fri Jan 14, 2011 4:10 pm
You should get a calibrator (hardware). The Spyder3s are on sale now. Check Adorama, the Express is U$D 73 and the Pro around U$D 130!
Gripped 7D + Sigma 10-20mm + 17-40L + 50mm f/1.8 II + 70-200mm f/4L IS + EF 400mm f/5.6L + 580EX II
othic
Fri Jan 14, 2011 7:11 pm
go whit the Pantone Huey Pro 89USD at adorama
A boy learn's much more at the airport then he do at school
ckw
Fri Jan 14, 2011 8:32 pm
There are 2 approaches to monitor calibration. One is to use a software program - if you have Photoshop, Adobe Gamma is perhaps as good as you can get for software, but I think there are a number of freeware packages available as well.
These are not too bad for setting the black and white points of your monitor, and may address the problem you are having with dark images.
But software alone is not very good for getting colors spot on, as although they allow color adjustment, the process is very subjective. For color you need one of the hardware devices mentioned above which are capable of setting colour in absolute terms.
In terms of investment, monitor calibration is not a one off task - probably should be done monthly, so the hardware actually works out as good value for money over time.
Colin
Colin K. Work, Pixstel
Granite
Sat Jan 15, 2011 12:04 pm
Hello
I've been using a Spyder calibration device for some years now. Works great for me.
On-screen pop up every month to say calibration is requiring update/check.
Gary Watt - Granite
Airliners.net Head Screener
www.airliners.net
http://twitter.com/airliners_net
Rotate
Sun Jan 16, 2011 2:28 am
Ui! Thx vm for all the Suggestions ... I might go with the spyder.
Robin
ABC
Users browsing this forum: Kaphias and 1 guest
