yerbol
Crew
Sigma AF 150-500mm F5-6.3 APO DG OS HSM For Canon
Sun Jan 16, 2011 9:57 pm
Dear team,
What do you know and think about this lens? You may show me some photos taken with this lens on Canon 550D/500D.
brgds,
Yerbol
With best regards from Almaty
dazbo5
RE: Sigma AF 150-500mm F5-6.3 APO DG OS HSM For Canon
Mon Jan 17, 2011 8:35 am
Yerbol,
This lens will be fine for the longer range work you would use it for. As I've mentioned previously though, atmospheric conditions may be an issue for you when using long focal length lenses. Refer to your previous posts. I use a 50-500 as you know and it's a great piece of kit for what it is. The 150-500 is similar, but a littler sharper at the longer end and has OS. The only problem with it is, it's 150mm at the shorter end so it's not a lens you can use for closer work.
Darren
