yerbol
Crew
Do You Photoshop Every Photo?
Mon Jan 24, 2011 9:17 pm
Dear all,
Kindly asking you this question.
brgds,
Yerbol
With best regards from Almaty
Chukcha
RE: Do You Photoshop Every Photo?
Mon Jan 24, 2011 10:20 pm
Depends on what you mean by that. To 'photoshop' in everyday talk often means 'to alter'; if so, then it is no photography any longer.
[Edited 2011-01-24 14:22:10]
JakTrax
Mon Jan 24, 2011 10:40 pm
For acceptances here every image has to be 'Photoshopped' - in the sense that all images need 'adjusting' to suit the requirements here. If it's a high-quality image to begin with all that's normally required is a slight crop, perhaps a little levelling and some sharpening.
I've heard people telling how they never sharpened an image and got it accepted here but I find it quite hard to believe unless we're talking full-frame, top-end cameras (with which I have little experience). Another way I suppose it could be possible is by selecting the exact sharpening necessary in camera, although it would involve flukes rather than genuine consistency. I very much doubt you could go out and take ten shots tomorrow and get them all on without any sharpening or other editing.
Karl
ckw
Tue Jan 25, 2011 12:29 am
If you shoot RAW, then yes, sharpening (at least) will always be necessary - though some may not be aware of this if the RAW convertor used has built in pre-set sharpening.
If shooting jpg, then things are a little different. In essence, a jpg is nothing more than a RAW file processed automatically in camera. Depending on the camera, you have varying degrees of control over the processing parameters.
Since the jpeg output has already been processed, this immediately limits how much post processing in Photoshop can be done without degrading the image, creating artifacts etc. You are in effect already one step removed from the original.
Think of it this way - all image editing is destructive ... you can never add data to an image, only modify it, and each modification changes the data (and throws some away).
In an ideal world, a jpeg should not be edited in Photoshop as the image has already been partly "destroyed" by in-camera processing. If you go the jpeg route, it is important to get the camera settings (white balance, sharpening etc.) spot on. Theoretically, a correctly setup shot taken as jpeg should look no different to a carefully processed RAW file saved as a jpeg.
In practice though getting everything right in-camera can be tricky. In my opinion it is actually easier to achieve best quality by shooting RAW and accepting that post-processing to fine tune is part of the 'fun'.
In some ways, shooting jpeg is like shooting slides - you just have to get it right. RAW is a bit more like shooting negatives - you much more scope for corrective or artistic adjustments in producing the final image.
Contrary to what many seem to think, shooting RAW is actually much easier than shooting jpg - but it is more time consuming!
Colin
Colin K. Work, Pixstel
photopilot
Tue Jan 25, 2011 1:28 am
Photoshopping for A.net images.
Gee, I thought the policy was "Don't Ask, Don't Tell"
Seriously, I think every image needs adjustments for level, crop, contrast, levels, etc. I don't know if I'd call it Photoshopping per se, or merely "tweaking" the quality issues necessary for acceptance.
megatop412
Tue Jan 25, 2011 2:34 am
Hell no- that would be insane
Chukcha
Quoting photopilot (Reply 4):
That's what I meant in my previous post. 'Photoshopping' is a totally incorrect word. The question should have sounded something like, "Do you post-process every photo using image editing software e.g. Photoshop?"
The answer to such question would be 'yes', as long as it is the post-processing is 'mild', such as brightness-contrast adjustment, leveling, cropping, colour adjustment, etc.
Quoting ckw (Reply 3):
Maybe in ideal world it shouldn't, but in practice... I've been always shooting jpeg; it just takes practice and a little skill to make editing jpeg files in the Photoshop or the like as non-destructive as possible.
cpd
Tue Jan 25, 2011 3:39 am
You have to do a certain amount of post-processing, especially if you've got dust spots on the sensor.
They won't go by themselves - and even a blower sometimes won't get rid of them. I've also done some ISO12800 images that do need some photoshop work to clear away noise. No other choice for one of those images - the plane came in super late after 9:00pm and was nothing more than a dark shape with some lights on it.
The toughest image I ever tried to edit was this:
It was really dark at 9:00pm, even with the moonlight (camera made it look brighter than it was) - the focus wasn't quite right, and it ended up noisy too. I think it was impossible to get that image - and I was very unhappy with the results.
Quoting Chukcha (Reply 6):
You probably convert the layer to a smart-object as the very first step that you do. Or maybe after you've cloned out dust spots if there are any. But definitely do it before any resizing of the image or other destructive edits. They have other benefits too, especially when applying filters since they are no longer destructive.
Otherwise, I do very little editing on images.
Don't find RAW more time consuming. Maybe the files are larger, but then I've got a monster of a computer.   I also had a very good workflow sorted out which gives me great (and consistent) results. Doing the sharpening in Camera Raw, using the screen-sharpen, then opening the image as Smart Object seemed to solve the oversharpening issues I used to get.
epten
Tue Jan 25, 2011 8:55 am
If by "photoshop" you mean altering the foto (removing/adding elements and so on...) then no, I never do it, and it is forbidden by a.net rules.
If by "photoshop" you mean levels, sharpen, leveling, sometimes noise removal... then yes, every single photo you'll see here is photoshopped.
JakTrax
Tue Jan 25, 2011 4:06 pm
It's a myth that RAW is better quality than JPEG - they are two different types of file, with the former simply allowing more flexibility. As Colin says, you could process a RAW to its maximum potential and it could still end up looking exactly like the original JPEG you snapped at the same time. This has happened to me on a number of occasions.
As for me, I rarely edit the RAWs (unless I totally screw up the JPEG - which sometimes happens!), instead choosing to edit the JPEGs. Since a RAW file must at some stage be converted to a JPEG I'm not really fussed. As Colin points out again, there is less scope for error when shooting JPEG only, but most of the time I nail the exposure pretty well. There is enough flexibility to correct the image providing it's only a fraction out with regard to white balance, colour, contrast or exposure.
I have a general rule - if the subject is rare, unusual, in an odd livery or if the light is tricky, I shoot RAW; however if the light's perfect and the subject boring I shoot JPEG. Each to their own. As long as the photographer's happy with the results, that's all that matters. For applications other than A.net I edit my images in a different and much less scrutinising way.
Karl
dvincent
Tue Jan 25, 2011 4:23 pm
Every photo certainly gets "lightroomed."   The only post I do in Photoshop for this site are dust removal and sharpening (with masking). At least, for this website.
From the Mind of Minolta
Moose135
Tue Jan 25, 2011 5:12 pm
Quoting JakTrax (Reply 9):
No, a JPEG is the end result of processing a Raw file - whether by a human, using some software program, or by the camera, using setting programmed into it.
I don't post-process every photo I take, but every photo that I display on my web site, forums, or other places that will be seen by the world, gets processed. It may be a quick rotate/crop/tweak or a full-blown edit (HDR, panorama, edited for a special effect, etc.) but I don't show off anything right out of the camera. And that applies not only now that I'm shooting Raw, but even back when I shot JPEG.
JakTrax
Tue Jan 25, 2011 5:55 pm
Quoting moose135 (Reply 11):
Where did I say it wasn't? They are still two different types of file (according to my PC anyway), with one offering the user more flexibility. I did write this piece of text in my post...
...with emphasis on 'at some stage'. I didn't say when or how.
Karl
spencer
Tue Jan 25, 2011 8:05 pm
Well, depends how you look at things. I'd even go as far to say a JPG is of better quality, straight out of the camera!
But for tweaking the qualities both files contain, the RAW can be done twice as sensitively.
If you're getting things right from the get-go, and see no need in retaining the added info a RAW file contains, and have limited space on memory cards and your PC, then JPG is the way to go.
IMO
Spence.
darreno1
Wed Jan 26, 2011 1:07 am
I consider my DSLR as merely a data capture device and an extension of the data processor (my computer / Photoshop). I don't use in- camera processing and only shoot raw. Once the data is captured, I then process it in the computer.
For me, editing is a lot of fun and sometimes I can go 4-5 hours at a time doing it.
I've shot some pics that were close to 'pefect' in that they were very sharp, level, with good contrast and little noise, but it's pretty rare. The majority usually needs and benefits from some amount of processing. Thankfully the camera I shoot with has excellent auto WB and color accuracy so I rarely find myself needing to adjust those.
[Edited 2011-01-25 17:09:35]
Nikon D7000 / Nikkor 105mm AF f2.8 / Nikkor 35 f1.8G / Nikkor 50 f1.8D / Nikkor 85mm / Nikkor 300mm f4 AF
ckw
Wed Jan 26, 2011 6:39 pm
One thing that is worth mentioning regarding RAW is that "perfect" image preparation should take into account the final purpose. High end publishers will often prefer an unsharpened image as they will process it themselves to match their own printing service. Similarly, with jpg, you are pretty much stuck with the sRGB colour space, while some uses will require CMYK or AdobeRGB.
Although you can convert a jpg to other color spaces this is not the same as producing the image in the required colour space. Of course as most people's monitors are themselves sRGB devices, it is not possible to see what really happens to the image when you convert it.
Colin
epten
Wed Jan 26, 2011 9:06 pm
Quoting ckw (Reply 15):
Hm...
no camera will capture the picture in "additive" system (eg CMYK). CMYK is equally "far" from sRGB and AdobeRGB spaces.
On the other hand, AdobeRGB is pretty much a "subset" of sRGB and both are more-or-less interchangeable. No photo in this world will ever be ruined because of sRGB to AdobeRGB conversion.
Anyway, if the photo is wrong in such way that fixing is possible only if it is RAW - then it's too wrong to begin with. similary, if exposure, focus, everything... is done properly on the first place, then the resulting jpeg will be perfect.
stevemchey
Wed Jan 26, 2011 9:40 pm
Quoting epten (Reply 16):
As mentioned before, a perfectly exposed JPG image out of the camera is always as good as what you can do with a RAW image... but that's a big "if". I shoot a lot of weddings and while I wish all my shots were always perfect, that is just simply not the case. Light situations change quickly and sometimes I just end up with an under- (or over-) exposed shot. If I were to shoot in JPG, I would have very limited possibilities afterwards. Because I shoot RAW, correcting the exposure is much more likely to produce a picture that I can offer the client. And with a wedding, you never get to redo the shot.
There have been a lot of comments about whether JPG or RAW is better... and that depends heavily on how you define "better". What's better, a Ferrari or a Ford Focus? They are both equally good if all you care about is getting from A to B. They both do that. If speed is important to you, the Ferrari might be better. If gas mileage is more important, the Focus is...
Same with RAW vs. JPG. They both can get you perfect images. But if you only have a 2GB card and need to send the images to your publisher 2 minutes after you took them, then JPG is the better choice. If you want to keep every information that the camera saw the moment you took the picture, then RAW is clearly better.
I am pretty sure sRGB is a subset of AdobeRGB and not the other way round. So you certainly end up with less information if your camera assigns sRGB to your JPG instead of AdobeRGB... if that ruins your picture is another discussion.
The nice thing about RAW is that it does not have any color space assigned to it. You define the color space only at the time when you export it.
[Edited 2011-01-26 13:59:20]
ckw
Thu Jan 27, 2011 1:15 am
That's sort of correct, however, using RAW you can select a very wide gamut color space (such a ProPhoto) which will avoid the limitations of sRGB and therefore render the CMYK conversion more accurate.
No, adobeRGB has an extended gamut - or put another way, it can describe more colors. Whether this is of any value for most uses is a point of debate, none the less, if an art editor requires AbobeRGB you can't simply convert a sRGB jpg to adobeRGB ... well you can, but it won't be as accurate as a RAW to adobeRGB conversion.
Colin
ua935
Fri Jan 28, 2011 5:25 am
No it is not.
How can you even suggest that a 20 + mb RAW file is not better quality than a 5 mb or less JPEG?
The moment you take a JPEG image there is compression, edit and save, yet another layer of compression.
Live every second like you mean it
JakTrax
Fri Jan 28, 2011 8:03 am
Quoting ua935 (Reply 19):
No it is not
We could go on about this all day. What do you have to convert a RAW file to ultimately? A RAW being five times bigger than a JPEG only means that it's preserving more data. As has been said, if you can get a perfect shot in JPEG, the same RAW image will not look any better after processing/conversion.
I fail to see how RAW can be better quality when it's a totally different type of file. It allows for better quality in the long run but in itself isn't better quality.
Karl
cpd
Fri Jan 28, 2011 12:34 pm
Quoting JakTrax (Reply 2):
Even by resizing the image down to a size small enough for it to be uploaded here, some editing happens - and some form of manipulation/sharpening is performed by the software, even if you aren't doing anything yourself.
That said, a reasonable camera and a good lens will deliver a good result. It doesn't necessarily need to be a 36x24mm format, it can be a 24x16mm - but it's all down to the lens and the person operating the camera to use the correct settings and to not get motion blur.
I took that at 1/125sec, F/5.6, 5250K and 250mm in fading light, but still only ISO200. Just resized it down to the usual 1024px wide resolution, nothing else done on it. Even if it isn't sharp enough for this site - I'm perfectly happy with it (even more so the one before it without the lights in the way). Most people here would nail images like that one every time, given the talent here.
If you really push the limits of your camera, then you must do some editing - no option. 1/4sec panning shots don't normally appear perfect sharp right across the frame. Add extreme ISO settings that you might use in total darkness to capture a fast moving subject - and the need to edit the image is obvious, you have no other choice. But if it works out - the result should be good.
[Edited 2011-01-28 04:44:02]
[Edited 2011-01-28 04:45:08]
trvyyz
Sat Jan 29, 2011 2:32 am
Quoting JakTrax (Reply 20):
No it is not
If the jpg of the paricular shot is not that good, you could get a better jpg from the raw file of that shot.
If you nail the jpg perfectly when you take the shot, then your point is valid. But in real world exp could be a bit off, then the raw will yield a better result ( in jpg created from raw). For A.net jpg is more than enough, for non av raw can do a lot more stuff and get more dynamic range than a jpg IMO.
XT6Wagon
Sat Jan 29, 2011 2:40 am
Lightroom3 is... basicly manditory now. Not only is it great for organising your collection(s), but it has great tools for basic corrections. Best of all it doesn't actualy alter your origional file, so if you come back later with better tools, or more experience you can start with the same exact RAW or JPG you did today. Only its output has the changes made.
I'd say that or something comparable should be the first stop for any photo you wish to show to another.
condor981
Wed Feb 02, 2011 1:12 pm
I shoot RAW, and then of course use Photoshop for minor color and exposure adjustments as well as sharpening required for Anet shots.
Then yes, my answer for your question would be, yes, I photoshop every photo
paulinbna
Thu Feb 03, 2011 9:05 am
I can't tell you have times I have shot pictures for people and they wanted me to burn a disk BEFORE I process them. The person asking is mystified when I tell them I am not going to that.
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
jfarango
Thu Feb 03, 2011 8:07 pm
The images need a basics adjustments, and are most necesary when uploading it to A.net when you expose your work
yerbol
Crew
Sun Feb 06, 2011 12:05 pm
Dear all,
The reason why I've asked this question is many rejected photos of mine. I would like to learn more to make-up my photos in order to get them accepted by Airliners.net. I agree that every photo needs adjustment.
Thanks for replies!
Brgds,
Yerbol
dlowwa
Sun Feb 06, 2011 12:22 pm
Yerbol, you can use the Feedback Forum to get advice about how to improve your images enough to make them acceptable for here. Just remember that editing can only do so much, and you need a good quality image to begin with - if an image is poor to start, no amount of magical 'photoshopping' is going to save it.
JakTrax
Sun Feb 06, 2011 1:09 pm
Quoting dlowwa (Reply 28):
Always a good debate Dana - I have a couple of digital images which are so poor they look nothing like the accepted images here. As long as there are no blurry or major exposure issues I personally think a poor photo can be tarted up enough in Photoshop to actually make it look reasonable (or even good).
In the film/slide days I think it's fair to say that the quality really did have to be there in the first place, however in my (nearly) seven years' experience with digital I've found it very forgiving if I do make a mistake. I think many of us remember how many slides we used to put in the bin because we failed to get it exactly right. With digital it's so much easier.
But I guess this is a debate for another time eh?
Karl
yerbol
Crew
Sun Feb 06, 2011 1:12 pm
Dlowwa, understood. Thanks for advise!
trvyyz
Mon Feb 07, 2011 6:08 am
Quoting JakTrax (Reply 29):
Then why do you call it poor? do you mean cropping and levelling?
yerbol
Crew
Tue Feb 08, 2011 7:13 pm
dear all,
which version of photoshop is more suitable for airplane photos adjustments?
thanks in advance for replies!
dlowwa
Tue Feb 08, 2011 8:06 pm
Any relatively recent version of Photoshop is more than enough to edit airplane photos, and you could easily argue that Photoshop would actually be massive overkill if you only intend to use it for that kind of editing.
I currently use older versions (CS4 on my home computer, and CS3 on my laptop), but they are both still more than enough for a.net. The only relevant question about which version to get is if you use ACR to convert from raw, be sure you get a version of Photoshop that supports an ACR release that supports your camera. More recent releases of ACR are not supported by older versions of Photoshop. If you're simply editing Jpegs, or converting from raw with something else, it doesn't really matter.
yerbol
Crew
Tue Feb 08, 2011 8:55 pm
Thanks for advise Dana!
Stealthz
Tue Feb 08, 2011 10:26 pm
Yerbol,
There are some that say you will not be able to post process an image unless you have Photoshop CS5, they are the same ones that say an EOS 5DII or 1 series is required to take an image suitable for A.net. Both statements patently false!
Photoshop Elements 9 is available for under a USD$100(indeed right now Adobe offer a $20 rebate so make that $80) and there is very little one would need for editing that is missing from this version.
It supports RAW files and has layers with most if not all the other options and toolsrequired for photo processing.
Much cheaper than the PS CS
Chris
yerbol
Crew
Tue Feb 08, 2011 10:39 pm
Thanks for advise Chris!
As I see photos of airplanes need more adjustment than photos of people, portraits, nature, animals etc.
Architecture require good adjustment. I have to learn   and I will!
epten
Wed Feb 09, 2011 11:44 am
Quoting yerbol (Reply 32):
Frankly - just about any. I still use Photoshop 5.5, now about 13 yrs old. It still does the job admirably.
yerbol
Crew
Mon Feb 14, 2011 9:00 am
Dear all,
Finally I got photoshop installed on my computer!
And today is 1year since I've joined Airliners.net!
Thanks to all for help and advises in the past.
Brgds,
Yerbol
JakTrax
Mon Feb 14, 2011 6:25 pm
I still use Photoshop Elements 5.0 and it's more than enough to edit images for here. As has been said, Photoshop CS5 et all are complete overkill unless you're a pro doing pro work.
Quoting trvyyz (Reply 31):
I suppose a truly poor shot is a blurry or badly-exposed image, however if the levelling is too far out or I have to crop too heavily I deem it a poor shot. So depending upon which way you look a things, poor (or perhaps a better description would be 'mediocre') images can be made good enough for here. Don't forget, resizing to 1024x683 can mask a good number of 'sins'!
Like many here, I came from flim/slide, where if it wasn't right to begin with there was no Photoshop to save your backside. I still shoot similarly as better quality in always equals better quality out. I'm not too big a fan of cropping, although sometimes I do admit that I get the aircraft so tight in the frame that there's no room for even the slightest rotation if it's required. And like everyone else I have off days, where I take a couple of real stinkers!
I've always maintained that composing the shot correctly in the first place is far more important than what you can subsequently do to it in Photoshop. I know of great photographers whose editing skills are pretty awful and I've also known great editors who can make their terrible images look amazing. I suppose it harks back to the old 'photographer or editor' debate........
jrowson
Tue Feb 15, 2011 12:24 pm
I've just changed from CS3 to Elements 9 recently after trialling it and have to say that 99% of everything I used from CS3 is available in PSE9. The only thing I'm missing is the ability to save different size crop box presets but that's really not a major biggy. I very quickly adapted to PSE9 as most things are in the same place. I try and keep my editing as basic as possible so I'm not so far missing any of the extra bells and whistles of CS. Oh and to top it off it's rather good value if you purchase it off places like Amazon. And if you ask, why did I change from CS3?, the answer is RAW integration for my 7D as the raw converter I was using needed upgrading when I changed to my 7D and wouldn't work with CS3.
James Rowson
