dan330
Possible Camera Problem
Tue Apr 05, 2011 11:19 am
Just had a rejection for a shot - the shot in question is here:
http://www.airliners.net/procphotos/...00988470.6974110323-g-civc-lhr.jpg
Screener comments note: lines in sky below tail
The lines are something I can't see in the original picture but was something I noticed when equalising the shot to check for dust spots. Thing is that these lines show on all pictures (well ones with a single colour / non detailled background, not noticeable on detailled shots) straight out of the camera, before any processing. A couple of examples that show the lines clearer (just equalise / resize):
The rejected shot:
http://www.plane-mad.com/pictures/camera-prob.jpg
Another from the same day:
http://www.plane-mad.com/pictures/camera-prob1.jpg
The camera is a brand new Canon 7D, this was actually just the 2nd time using it. Any thoughts on what this could be, or is this a faulty sensor that needs to go back?
Thanks in advance,
Dan
damien846
RE: Possible Camera Problem
Tue Apr 05, 2011 11:26 am
Does not look good...first have a look at the lens? Could be dirty? If no the lens then I would send it back to get it looked at.
wilco737
Tue Apr 05, 2011 11:27 am
As those line are pretty much identical in both pictures it could be something with the sensor.
Have you checked the pictures from the first time when you tried it? Have you changed the lense to see if there is something with the lense?
I'd suggest, take it back to the store and let them check it.
Sad that the shot got rejected, nice one of the BA 744...
wilco737
lgw340
Tue Apr 05, 2011 11:39 am
Put it on AV mode at go to the smallest aperture possible (f/22 or f/32, whatever your lens will let you do) and take an out of focus picture of a plain white wall. This will show up any marks on sensor/lens etc. Then post a link to the pic!
Live life from the window seat...
dan330
Tue Apr 05, 2011 12:49 pm
These were taken with the 100-400mm, the shot below with the 24-105mm both bought at the same time as the camera (insurance replacements), so appears not to be the lens.
Couldn't find a white wall but did manage to find something on the ground white, the equalised version:
http://www.plane-mad.com/pictures/camera-prob2.jpg
Must have blocked the sun out the right side but still the lines are clearly visible. As said above this was a different lens to the aircraft shots. Looks like it may have to go back!
lgw340
Tue Apr 05, 2011 1:02 pm
Quoting dan330 (Reply 4):
Agreed. Enjoy the new one!
wilco737
Tue Apr 05, 2011 1:14 pm
Yes. And looks like a huge dustspot is on the sensor as well already...
wilco737
dan330
Tue Apr 05, 2011 1:19 pm
Thanks all, will nip it back tomorrow.
Quoting wilco737 (Reply 6):
Yep, that'll be 3 days shooting at Alicante with dust everywhere, save a job of cleaning it when it goes back anyway!
wilco737
Tue Apr 05, 2011 1:25 pm
Quoting dan330 (Reply 7):
Good way to see it the positive way. But still annoying a brandnew camera with such a flew. It's a shame. Keep my fingers crossed that you get a proper one now.
wilco737
yerbol
Crew
Tue Apr 05, 2011 5:42 pm
Dan,
BA Queen of sky looks amazing!
Lines on your test photos are obvious.
Good luck with new
Yerbol
With best regards from Almaty
JakTrax
Tue Apr 05, 2011 6:35 pm
It almost looks like a smear, as though the sensor has been (badly) cleaned. It could be anything really, but you did the right thing in sending it back.
I doubt it was ever going to be a lens fault, looking at the way the marks/lines appeared.
Karl
dan330
Tue Apr 05, 2011 7:16 pm
Cheers all,
Took it back this afternoon actually and managed top show them the lines on a shot taken instore. They agreed to swap it (only 3 weeks old) but hadn't got any stock! Short drive tomorrow to a local branch and should be able to get it sorted though.
Dan
JohnKrist
Crew
Tue Apr 05, 2011 7:19 pm
My first thought was that it was an early version that suffered from ghosting. But I can't imagine anyone of those are still in shops. And that was fixed with a firmware later on (like mine). But the position of the lines is consistent so my guess is that the screen in front of the sensor is faulty. Hope you get a replacement fast!
Airliners.net Crew-Head Support
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
